Rubén’s on the Road, after 25 years
- Car Model: Super
Re: Rubens Painted suspension and clean nuts and bolts !
Jeff,
do you do the chemical blacking yourself - if so can you give me a clue on what you use, suppliers etc?
I've got a few bits i could do with doing.
I don't think I'd get away with that.
Re: Rubens new pipes
- sammy the sturgeon
- Car Model: GLAddis an August 1963 Imp De Luxe
Re: Rubens Rebuild. More Date Stamps
HARTWELL MK1 wrote:having sandblasted and painted the original, but badly pitted rear brake back plates, i am now glad I saved the originals, as I found a date stamp on them from april 63 Thanks noddy for pointing out date stamped parts
You know I'm going to have to look at mine now don't you!
Paul Holmes, Rotherham
Vectra C 2.2 SRi - Daily
and a garage on the garden!
- Car Model: 02 07 63 Hartwell IMP
Re: Rubens Rebuild. Pipes all fitted ready to build
What do I fit first
Complete with trolley jack dents!
Only could find the konis
Rear wheel bearings are cleaned and regreased originals with new seals
JEFF DAY
5948 RU Hartwell Imp Still not finished
nice work jeff did you stonechip the floor and then paint it
- Klaus
- Car Model: Imp chamois sunbeam 1966
Re: Rubens Rebuild. Rear suspension goes on
Hi Jeff
I have the same disc conversion, but missing the grease caps. Do you know where to get a pair? I took a measure, think they have to fit 45 mm.
Klaus
Klaus
Re: Rubens Rebuild. Front suspension on
Only got half a day on it so only managed the front suspension on, along with pedal box, and pnematic throttle and hose. Choke lever is ready to fit, and sorting through parts I have found 20 clips to hold the headlight seals (need 8 per car) on but no seals. Any NOS out there, before I buy new ones!
Photos tomorrow night
JEFF DAY
Jeffs correct , three white clips with push in centers and three rectangular metal pieces that the clip locks into per seal.
You learn something every time, but i have the excuse that there were no headlight seals and no clips holding the luggage covers in anyway so i havent seen them!
Re: Rubens Rebuild. picture progress
engine bay
front end
viva hc hub machined to reduce track increase
pedals in
wipers
Pedal box complete from rj grimes bought in 1986! cylinders overhauled
tempted to fit a rally dash
JEFF DAY
Seen the bottom type a few times , my Singer has one , no idea on the top one
- Has thanked: 18 times
- Been thanked: 69 times
On Skye's original clamp, there is a spacer between the head of the bolt and the clamp. It too has the "Mickey Mouse Ears" type end on it - 1964 car.
Ok I have the relevant car service buliten on rear tyre wear, (rear wheel alignment! Its 6 pages of A4. Whats the best way of reproducing it on the forum? Its 3 pages of text, and 3 of diagrams!
JEFF DAY
Re: Rubens Rebuild.Roary escapes from the white witches cast
If ruben is finished in time, roary will need a driver to get to perth! William is tooooooo youngThe Nun wrote: I believe there is a policeman on the forum you might get a ticket to go with your trophy at Perth
JEFF DAY
You cant win 2 trophies Jeff, thats not fair.
Re: Rubens Rebuild. Rubens Turn for some attention
Sounds good great
Any pictures of the refurbed dash, or when its done?
Looking for some inspiration for my mk1 dash which is in need of an overhaul.
- Cally
Inkjet transfers need to be sealed with lacquer before being applied by using water to slide off the backing paper.
Laser ones better as heat seals ink and becomes wareproof, but only if your laser printer will accomodate the special papers
- greenbeast
- Car Model: Imp Sport Rally
Re: Ruben comes home, to live with roary again!
Excellent news Jeff.
Good to have a a base and stability for all your little ones...
Jon
Jon
Jon Manning
1972 Sunbeam Imp rally
In case you not worked it out, the stub axels are on the wrong king pin carriers!
JEFF DAY
Roary wears a ribbon
Well a year has passed and a lot of things have happened in my life including getting remarried and a lots been done on the house and nothing on ruben . However roarys done a 1000 miles. He's been behaving himself although I have found some bits that need welding on this scuttle edge behind the bonnet so it time for another rebuild, I guess his turn will be behind Rubens and I suppose I could run the 1150 with its twin 40's on a pneumatic throttle. And that will save me a job on Rubén engine.
Well hers some pictures of roarys camshaft, Any ideas on the cam, there is no marking on the end!
And Another one of roary looking smart with a ribbon
And with 3 other imps !
JEFF DAY
Ruben is still waiting
The kitchens is finished and the house is for sale, so I might get some jobs done on the imp soon! I keep lifting the cover, saying hello and finding and making parts for him
JEFF DAY
Re: Ruben wants his turn
Put reply on your IMP Facebook page Jeff, as it wont let me post photo here, says board quota is now full?
IMP Range
And the Hunter range too! For all the Bazza's out there
- Car Model: Sunbeam Imp Sport
Hi, you mention JWD998L. I am the original owner of this registration, a 1972 Sunbeam Imp Sport in Tango metallic. I notice that this number is still registered to this vehicle and would love to know what happened to it or anything about it's history.
Many thanks
Graham
Many thanks
Graham
Thanks, that would be great. I called myself '2imps' because I had two, back in the day. Don't have any now sadly.'
Still not finished, I have a new house and workshop since 2017, and Ruben has a few new German Friends. Watch this space
JEFF DAY
I didn't rebuild those swivels Jeff, i seem to recall they were painted in blue hammerite, something I would never do, they were given to me by someone getting rid of imp parts with the comments are these any good to you, they don't appear to fit mine, but I never did anything with them, I left them on the shelf and then gave them to you with my Sport. Someone obviously mixed up the parts once they were dismantled, I always keep stripped assemblies in their own box so there's no chance of mated parts not going back with their matched components, old ice cream tubs are great for this.
We have a local aluminium foundry, so with my background in brake development at the old girling site, I decided that Ruben has waited long enough for me to finish off the brakes, so I made a pattern box and got these cast.
JEFF DAY
Re: Ruben chooses to get aluminium brake calipers
Didn't Mike Dent, Moose, recently develop an alloy caliper kit based on the Viva hub design for the IMP that he's tried and tested? Save you lots of work if ones available now ready to fit straight on?? Though I quite understand if you want to try it for yourself for the challenge
Also how does it or might affect your insurance when you say brake calipers I've made myself, do you have to show official test and cert paperwork for them?
Hi Peter, There are several reasons why I want to develop my brake conversion, the main one being now is that I want a 1960’s looking aluminium caliper, that doesn’t necessitate having to widen the track too much, that preserves the original pedal feel, and does not alter the front rear brake balance.
At the moment, I have found a production 35 mm opposed pot caliper, A stock disc that I can remachine,to fit the imp hub and that leaves some brackets to get laser cut and zinc plated. This new kit will be photo ready and tested in January. I have a car ready to evaluate it on !
I want to make the Best Imp disc conversion.
The D12R caliper was aluminium, pictured above, was used on imps, with pads available from imp specialists at the time, however with a either a 43mm or a 48mm piston size, this caused a front rear brake inbalance. At the moment my prototype is in 2 halves, whilst I get the shape correct. Once this is achieved, the caliper will be cast in one piece, and manufactured from heat treated aluminium, and be interchangeable with the D12R
Pistons and seals will be from another 1965 rear engined classic, that I might have one or 2 off in the workshop.
Regarding liability sign off, I have tested a large number of brake calipers, for strength and durability, and I will test my caliper, and I still have contacts in component test.
Additionaly the D12R does not have a dust boot on the caliper piston, making it unsuitable for a road car At the moment,
However I have found a production 35 mm opposed pot caliper in cast iron weighing 2.1 kg, the aluminium D12R weighs 1.1 kg A stock disc that I can remachine,to fit the imp hub and that leaves some brackets to get laser cut and zinc plated. This new kit will be photo ready and tested in January. I have a car ready to evaluate it on !
JEFF DAY
Chosen some 30mm cast opposed pots calipers
JEFF DAY
Re: Rubén’s on the Road, after 25 years
After 6 weeks of work, he took his first powered run on the road last Saturday.
Still loads to do, but I can treat him as a rolling restoration now
JEFF DAY
