Karen's Imp Sport
Re: Karen's Imp Sport
Don't know what I'm doing just make it up as I go along.
No Hall sensors just VR and it used a shielded twisted pair wire and ground at the ECU. I did have a issue with the Clan when we came back from Holland when it wouldn't start on the Ferry and although it started once off it lead to a series of issues which ended in the ECU being sent back to Emerald who reconned the issues were cause by interference such as non resistor spark plugs which I was using but had been for a number of years without issue, personally I blame the fact that we were parked beside a huge extraction fan but who knows.
Using Canems on this one so having to learn a new system and ways of working.
- Been thanked: 209 times
Electronics in cars, putting sensitive parts in nasty places, it is the devils work sed to get enough problems on some encoders and halls on just mounting them next to stepper motors with brakes never mind spark.
And you are being modest
Good luck with the new system
Focusing on getting the physical fuel injection done.
Absolutely loving this Scott, excellent work. Keen to see how you progress!
Steel discs for the intank fuel pump arrived and any excuse to avoid doing the bodywork got stuck into turning them into something useful.
- Been thanked: 207 times
Cracking on there pal. "
"Moose
No oil pressure warning light wire ?"
You are right i had to go out and look as i was convinced it is only a three way plug. I was right the starter is on a separate single wire so the three are points, Alt and oil warn.
Need to get back to working and rallying mine forgotten what i did to it
"Moose
Finally feel I've made some progress, got some epoxy primer on the shell.
Get the floor hopefully done tomorrow and then that's it sealed from any moisture wanting to turn it back to rust again.
Colour looks good as it is.
I concur on the colour so much so that I've been thinking about painting GLS (viewtopic.php?p=150420#p150420) one of the Greys that are popular at the moment but be a while yet.
You could do it in Platinum Silver which some Imps were done in and have maroon leather upholstery
GLS was indeed Silver although looking at the paint it was hard to tell, Chrysler seemed to have had issues with the Metallic paints on the couple of cars I've had. I also have a red leather interior if needed.
Nice one Scott,
That's looking smart as it is. Do you still need to look at the doors for it? How are they looking?
Just don't look too close, still a lot of bodywork to do but making progress.
Just ordered door skins for it today, only Six months to wait.
- Has thanked: 18 times
- Been thanked: 69 times
Very true... I used to have an N-plate Platinum silver Imp Super that had been returned to the dealer under warranty because the lacquer peeled off. They sprayed it grey instead!!
Like the 68 Silver Fox Metallic Cortina 1600E the lacquer peeled off that after a few months, something to do with the top coat not being compatible with the base, thankful today's metallics are quite robust.
Pretty sure the Metallics used were single stage - no laquer but they certainly didn't stick very well to the primer.
More prep and primer
Not liking the crank sensor mount so had another go, the problem is all the mounts on the timing cover are at different heights.
In the end I changed one of the studs for a longer one and tapped more of it, fitted a nut and fitted the bracket over it and retained with another nut. On the other end is a simply dog legged step.
Fuel tank also needed redoing, despite trying everything I could to minimise the length of the fuel pump it was just a few mm too long so cut a bigger hole and welding in a deeper sump. Didn't need to be as large as I ended up with but reconned it would help with surge on a near empty tank which Karen always seems to leave her cars when I borrow them It's OK I have trial fitted and it clears fine.
- edgedj
- Car Model: Davrian mk6
- Has thanked: 11 times
- Been thanked: 51 times
Nice work on the injectors, the aim you’ve got there straight at the valves should be great. Where are you taking the vac signal from (assuming you are running sd injection) I’ve used the vac takeoff on my sport manifold as it joins them all and should provide a decent average.
Dave Edge, BS Nymph
Dave, if you look on at the pic of the manifold and injectors you can see a small nipple to the right of the servo take off - this is the take off point (cunifer pipe with flared end and loctited 648). The servo take off will be used for the air idle contol valve.edgedj wrote: ↑Sun Oct 31, 2021 11:26 pm Nice work on the injectors, the aim you’ve got there straight at the valves should be great. Where are you taking the vac signal from (assuming you are running sd injection) I’ve used the vac takeoff on my sport manifold as it joins them all and should provide a decent average.
With a new map it fired up first time and "idled" , didn't get any further as manifold not sealed properly so drawing air. The outer two mounts, the ones on the long studs were removed to fit the fuel rail which is part of the problem, solution is to fit longer dowels and use them to help locate the inlet manifold (on order). Once that's sorted I can start mapping.
Longer dowels certainly helped in locating the inlet but only partially helped, the other issue and maybe the bigger one was the aftermarket exhaust manifold stopping the inlet seating properly, a bit of filing later and both on.
Fired it up and already idling much better, spent a bit of time balancing the Strombergs in anticipation of starting mapping.
Have done a bit more work on the engine, working on the mapping at idle.
Done some more filler work and reprimed the interior and applied the sound deadening, slow progress but progress never the less.
Some colour on Karen's Imp
Very nice Scott, is that still to have clear coat applied?
Looks very much like a Vespa I used to own in colour.
Will it be ready for ~Imp Ecosse?
Lotus Sunbeam Moonstone Blue?
Col is closest but then he knows which manufacturers colour it is, they don't do 4 wheels but do vehicles with 2 and 3 wheels.
This is the same colour that it was painted when originally restored.
Col - yes it has been clearcoated, cheeky bigger. Yes it will make Imp Ecosse just not this year door skins on order from Expressed Steel but due early April but know they are delays with them so no chance it will be finished.
Interior painted
Under bonnet area painted.
looking really good Scott, Fantastic work.
- Car Model: Clan Crusader Singer Chamois Sport Audi A4 Quattro
- Been thanked: 2 times
Thanks for the nice comments, it's going back as a daily driver so willing to compromise on the level of finish inside as most of it will never be seen when everything's back in besides got too many other projects to get on with, can't spend forever chasing perfection.
The colour by the way is Piaggio Azzuro Fjord Metallic.
I believe the Shelby Cobra Daytonas were painted a shade of Fjord Blue, probably not the Piaggio version though!
I've decided to put other work aside and concentrate on Karen's car for the month of May, fortunate that I have the flexibility to be able to do that.
Yesterday started on sorting a Sport boot lid using the original slotted area from Karen's Sport and a modified standard lid off some competition car so it already had extra holes for cooling and mounting. Both needed a lot of work but would both have ended in the scrap pile if I hadn't put the work in.
Ran out of Argon yesterday so did some more work on the fuel line plumbing and found I need yet more fittings
After picking up more gas this morning got the boot lid welded up and dropped it into the acid tank to remove the rest of the rust , then started taking the headlight surrounds back to bare metal. Awkward shape so has to be done by hand sanding
|Scott
|Scott
Started sanding the bonnet, only did half as the vibrations go for my hands. Still in pretty good condition but it has a few dings that I'll pull/knock out this time rather than just filling.
Finished off the fuel lines and then installed the ECU and its wiring only to find the multiplug wouldn't go through the hole in the inner rear wing which meant demounting the wiring. Grabbed a spare loom and tidied it up a bit and took the auxiliary wiring harness that was in it previously and removed the insulating tape as it will have a lot of custom wiring partially because of the engine management but also custom dash (still to decide what to do with it) and other goodies.
Last build it had remote central locking with light on warning, auto courtesy light delay, two speed intermittent wiper etc, this time were going keyless entry and start stop with auto coming home/leaving home lights. Still looking at tunes, last time 6 cd multichanger this time bluetooth to phone, sat nav, android auto with single din pop up screen, if I can find something suitable.
Concentrating on getting the initial run of the wiring in, all very time consuming and then just as I was connecting the Ecu wiring to the front of the car spotted a wire with a bare end flapping about One of the wire had come out of the multiplug to the ECU without putting any strain on it, can only assume that it wasn't properly crimped. Not a happy bunny.
Looking really good Scott. What sound deadening did you use?
- Has thanked: 464 times
- Been thanked: 171 times
One fine day, Scott, you'll have to share how you did your central locking. I'd love to see it one day.
AndyUncle Henry wrote: ↑Sun May 08, 2022 9:58 am One fine day, Scott, you'll have to share how you did your central locking. I'd love to see it one day.
Clan has a similar set up but key operated central locking because I hardly ever lock it due to type of usage, it will be at the National. I'll also post up details when reassembling.
I'll post up details as I do it especially for you replicated same system on Clan so you can see it in operation only difference is its key operated as hardly ever locked.Uncle Henry wrote: ↑Sun May 08, 2022 9:58 am One fine day, Scott, you'll have to sharehow you did your central locking. I'd love to see it one day.
