The Nun wrote: βSun Dec 24, 2023 4:39 pm
The smaller ones were for an alternator I believe, if you fit the large one as per that on the dynamo it doesn't spin the alternator fast enough for it to kick in and charge at low road speeds.
Thanks, that I did not know.
Happy Christmas to you!
Some practice works on the Maximat VP10 S lathe, I have had it nearly a year now and slowly I am making more sense about what it can do, right more its more about what I cannot do?
In this picture I was using the chuck jaws that allow me to hold the pulley on the outer edges, this was not a success, as the center showed a wobble, I then machined an alloy nipple, fitted that in the center hole, reversed the pulley and it spun up fine then!
Note the SKF Speedy Sleeve, it was on the cars original engine and has done many hours and miles, its not worn at all, they are 0.025mm thick.
I am preparing to remove the center out of the steel pulley and for use in the new pulley made from alloy.
