I won't miss the Action Day, I organize the clubs attendanceImpManiac wrote:Bad luck, Graham. Sorry to hear you'll miss the Action Day. Still, your new deadline sounds achievable.
Racing Puma will be on duty instead
Brilliant!long_gone_John wrote:
Thought you were just on the deck... with shock!!... still holding the camera
LGJ
I know, flipping Rolls Royces they spend more time in workshops than IMPS, cant be as reliable, obviouslyDogsbody wrote:As soon as my mates get their Rolls Royce out of the main workshop, the car can have its final coats of paint and be reassembled with lights and bumpers
Yes, bl***y Silver ShadowThe Nun wrote: I know, flipping Rolls Royces they spend more time in workshops than IMPS, cant be as reliable, obviously
Thank you very much for the praiseganderson888 wrote:Hi Graham,Dogsbody wrote:Not going (to National) Lewis, too far for me.
I was quite surprised to read that you aren't coming to the National and I'm sure many of your followers on here will be just as disappointed as me.
Yours is one of the very few alternative engine projects that has succeeded in turning a pipe dream into reality, and it is one of the best we have seen in recent years
Is 132 miles really too far to go to show all your admirers on here and the 500 other people who will be there on the Sunday the fruits of your labour?
Graham
But before you do cut the front away, and maybe to preserve your currently very appealing front aesthetics, it might be worth trying another fan position/cowling design and also increase (or move) the exit in the bonnet, because the devil is in the detaillewisparrot wrote:Hi Graham on mine which has the zzr radiator as you know, I have completely cut away the front of the car where the radiator is, so looking to the front of the car you can clearly see the whole radiator. I don't have any over heating problems at all. Lewis
I have two temp gauges, the original fed from a original sender in the Kawasaki engine and a after market digital on on a pod beside the 11,000rpm rev counter.colimp66 wrote:This may be a silly question but here goes.
What temp gauge are you using with the Kawasaki engine? Is it the Imp one or the original form the Kawasaki clock set?
Ok that's two questions, Apologies if you have already mentioned this in the thread.
I did think about doing a no bonnet run out, but i'm 99% air out is my problem, so disk cutter at the ready tomorrow when I get back from Swindon in the morninglewisparrot wrote:Hi Graham before cutting your car try a quick run without the bonnet if it still overheats then you need to look elsewhere also on my car I had to drill a 6mm hole in the thermostat which allowed water to flow enough for the thermostat to respond quicker, just a thought. Good luck Lewis
MattThe Nun wrote:someone has put a Helicoper gas turbine in their MINI and they are still looking to make it go faster??
