68 stiletto Restoration
- Car Model: stiletto restoration
- Has thanked: 3 times
Re: 68 stiletto Restoration
Started to make footwell section don't have any fancy bending tools so just use what's to hand , find something about the same dia .A 2.5lt. paint can seems to be ok
Rough piece of sheet cut from cardboard template
No serving wenches here much too cold only an old mop bucket joking apart it couldn't be I better fit
The edge just formed by hammer and dolley
Front floor section remade I could have just welded I flat piece in but wanted it to match the other side the front is not right should be round not tapered altered it but no photo at this stage as didn't notice till it was tacked in Big mistake had to grind it out and redo well p****off
Bit more to do but getting there
This is the kind of postings that makes me realise a) how much I have to learn and b) how much I have to do to two of my cars.
It's quite inspirational though and doesn't put me off as I'm a great fan of the "learning by doing" philosophy.
Got a couple of hours today finishing off the floor .I had cut out the frilly edge as just didn't like it more places for rust to take hold I wanted I smooth piece all the way round the foot well
Made up 2 pieces and wielded them together
Fitting and marking floor to grind back for welding
Got a few hours today was hopeing to weld it but didn't happen final fit took much longer than I thought to get gap right but happy now with fit
Also forgot about plug welding needed so will also require weld through primer so weld tomorrow now
Floors done got fed up with welding today so decided to paint, the zinc primer is very hard if you get it too thick it chips so rubbed it down 400grit just to key and put a coat of red oxid on. A bit old school now I suppose but it drys softer and dents when knocked rather than chipping ,the different colours also make it easy to see if you miss
just stone chip then when inner wheel arches done
Re: 68 stiletto Restoration (SRC 527F )
Last week started on ns front inner and outer wing cut out all that was rotten back to good had to cut some good section out to get to the front cross member corner that was rusted out bought a new wing corner but decided not to use it all as it was not a good fit
Once I had got acsess to it cut out crossmember corner and stated to make a new one
Lower front panel was not to bad but the spotwelds had swollen due to corrosion in the seam so cut it back about 40mm wide
Have made this to same profile as sample I think its original can anyone tell me if the cut out at the end of the curve is left open for water to drain out are does the inner wing weld into it ?
Hi Noddy thanks for that it hard to know when you don't have an unmolested imp as reference I would think the inner wing just bridges it so leaving it open to drain thanks for the speedy reply
Cut new corner panel up used outer wing edge with original middle mocked everything up to check gaps for welding
Have also been pushing along as much as I can reconditioning at home instruments posed a small challenge as all the pointer's were very faded and needed to be taken apart and the bezels were all scratched and some type of sealer between the glass had hardened and gone to dust
I also tidyed this bit up as didn't like how it had been repaired and didn't know what was underneath its taking longer than I thought but am not prepared to cut corners
Thanks malc that's very kind of you I'll e-mail address
- Has thanked: 72 times
Youre doing a grand job, it should turn out to be a lovely car once done and be well worth all the effort youre putting in to researching into getting it looking right and done properly.
- pbergs
- Car Model: stilletto
Saw this on eBay nos the car came without any although do have the Lucas numbers plate lights the old girl diserves a treat
I recognise that packaging!
I hope he was pleased with his I was with mine unfortunately mine won't be fitted for a while yet
This one is for ImpManiac welded bottom of a post to sill and let in a small rectangular strip for wing drip edge to spot to, welded it on 3sides straight down to sill then while still hot tapped it out to suit wing don't think I could have got shape before welding good thing is its now seam welded all round so no water can bleed through to inner wing .I will put door back on before welding lower wing back on
Camped wing on to check alignment
Did this a while ago when I first got welding again did it due to the thicker matl just to get used to it and get my hand back in so to speak when I cut it out and rewelded the recessed end bit for bolts to fit I tacked it up bolted to the car so there would be no shiming reqd although I am confident its good I don't intend to use it on the finished car if I can find I good one at a reasonable price .Plenty of time yet
Down garage today I really have to push this on now if I can't get it in paint this summer it will be too cold till next year and still a lot to do but getting there
Started on the inner wing had to cut part of the wing off to get access to the A post area it surprised me its in very good condition and very solid at the top of bulkhead
The inner arch contour was a mile out but just cut and shaped to suit .I'll tack it up and then weld it in when all is OK
Also did the front suspension mount mod asked for guidance on how to do it on the forum the help and information came as always
Now starting to put the jigsaw back together now that all behind it has been repaired and rust protected
- Been thanked: 91 times
The contour of the inner arch is absolutely perfect IMHO . Not exactly sure what car its perfect for as yet but one day il find it
The only panels that will fit spot on are the original factory supplied panels and even they have to be set and jiggled a little to line up correctly, any other repro panels wont go straight on, well they will but it wont look right, it would be "near enough" as many say.
Always try if you can to find original panels, they might cost more but you will make up for it in time saved getting it to look right.
Problems crop up when someone has removed an original panel in advance of getting the repro replacement only to find it would have been far better repairing what was there on the original rather than faff around making the new one look like it supposed to.
- impmann
- Has thanked: 18 times
- Been thanked: 69 times
Those inner panels (Radford) don't fit at all without serious chopping and welding. It has been mentioned once or twice and it's a highly emotive subject for some.
Tbh, I've seen cheaper and better results using the outer arch from a Fiesta (£14) - it took similar cutting and welding and looked similar once fitted. The labour costs were the same. But it was thicker steel.
I really look forward to seeing this car finished, it's going to be beautiful.
I got the panels about a year ago don't know who made them £120 for all 4 so expected a bit of work but if I had paid full price I would be very disappointed
Yes but didn't know like many others what we are capable of when we start
Hi does anyone know what the black plastic plug is for on the front panel headlight surround
I will see if i can find something on the Bresco.com site that looks like them.
Thanks peter when this car is finished I will have to list credits
Cant find anything thats exactly right, I would ask Malc, or Bob Imp Spares, but youre looking for something along these lines, you could have a look through the Bresco fixing site too, there maybe something you could adapt there??.tiker wrote:Thanks peter when this car is finished I will have to list credits
I doubt many twin headlight IMPs still have them as the owners dont realise there should be an abutment stop at each end of the headlight trim in the body to assist in its security along with the 2 central wing nut fixings.
Sorry the photos not too good but you should see what it needs to be like:
To give you some idea how it works heres a sketch looking from above through the headlight mounting (headlights not shown) so you can see the stops just rest against the bezel thats all to stop it rocking.
Vusky still has these plastic abutment stops fitted , I made sure of this , i had 4 NOS ones but cant remember where from as it was years ago
Hi all arches came from forum club member and corners from eBay .I was a bit green and eager when I got them I have learnt since then. It is a word of warning to all !I
I just thought if there for an imp they'd fit .
Hi got front corner back on today went back OK minimum filler reqd .One question the front seams have noticed on photos some have filled them in for a flush look were they visible as they left the factory like minis as I think I like them as they are
Doesnt look at all right if you fill the seams so they arent visible, a glaring mistake, and obvious its been done by someone who doesnt know what an IMP should look like.
Tidy work, as always, Gary.
I'd leave the seams visible too. As mentioned above, that is how Imps left the factory.
