water pipes
Duk
Car Model: 70' stupidlow super, 74' not so low super
Re: water pipes
Post by Duk »
They don't have to be metal, anything will do aslong as it's resistant to the antifreeze/coolant and a bit of heat. I use a combination of silicon bends and oversize rubber heater hose
MRG 734G - Deceased!
JKO 15N - Sharkmouth
Been thanked: 88 times
Re: water pipes
For a road car you can use anything really. For competition you'll need to consult the Blue book.
Richard Claydon
Car Model: 65 Ex Works Rally Car
Been thanked: 3 times
Re: water pipes
Post by Richard Claydon »
bazzateer wrote:For a road car you can use anything really. For competition you'll need to consult the Blue book.
Blue book says on page 145, Section J 5.10.1 - "Have any fluid lines or tubes carrying coolants through the driver/passenger compartment painted red, and if non-metallic to be internally or externally metal braided hydraulic pressure hose."
Rich
Richard Claydon
67 Chamois Sport
66 Imp Deluxe
65 Works Rally Car
Duk
Re: water pipes
Post by Duk »
Sorry didn't realise it was in the motorsport section :oops:
Been thanked: 8 times
Re: water pipes
Post by colin rooney »
pipe in the car should be 1 piece most people seem to use copper pipe i can make them in alloy not cheap but very lite
Turboimp
Car Model: Sunbeam Imp Sport Turbocharged in 1983 + Clan
Re: water pipes
Post by Turboimp »
metal best as it gets rid of some heat from the coolant on it's way through , Every little helps ! Imp009
must be some kind of record !
