Rally Forum (Sticky like the HSA forum)
rally clan
clan
Post by rally clan »
Has thanked: 4 times
Been thanked: 205 times
----imp
more clips from the rallying the reason we all slow down at the bit with the big red truck in the background is there is a code board there on the cone it is usually a six digit number that the navigator has to write down. regards Moose
Hi pete yep slight oil burning going on, the rings came from my engine machinist (no idea of manufacture) when i ran a big end shell earlier on in the year when we dismantled the engine we decided a re-bore was required to make perfect but with the pressure on for the next event we gave it a quick hone and re-ringed it because we were in there. to be fair to the engine it has only come apart due to the big end problem since it was built by Hartwell in the 80's it did 6 thousand miles as a fast road car and has been rallied by me for 8 years so it is due a birthday. do you have a rcommendation for rings? i also suspect the use of 10,000 rpm on corners etc and probably slightly worn guides with no seals is adding to the problem, like a i say it has been a good engine and i owe it a refresh.
regards mike
Been thanked: 2 times
Post by benwick3 »
Hi,
Just asked about he rings as I've had a similar problem with a new engine. These were Deves rings which I had found previously to be superb even when fitted to worn bores. After perservering I stripped the engine to have another look at the rings. I had fitted them but at the time I was not sure they were correct but when checked against another set that I had they were the same so I left it as it was. It turned out that the problem was due to the second scraper ring being substituted by a second compression ring. I had a third set which had the scraper ring and the 1040 rings all had the scraper ring. I got Alan Petersen, who had supplied the two questionable sets and has had the same problem, to have a word with Deves. They admitted that for a short period that they had run out of oil scraper rings and replaced them with a second compression ring but they did not think this would cause a problem. We disagreed with this and they did eventually agree to replace the additional compression rings with scraper rings but wanted the compression rings back as they were running short! Last week I stripped the engine to find the original honing surface to be present. I replaced just the second rings and hey presto no oil smoke.
rally clan
If anyone thought the Avenger was uncompetitive check out the above clip, out of 151 starters the car finished in 21st place and that is against WRC's, Evo 9's and other top Group N cars and modified Escorts(Vauxhall Engines, Seq gearbox's).
Some Pilot and some result, and I believe his brother is just as quick in the Davrian Imp.
http://public.fotki.com/speedy/2007-eve ... g9175.html
Avenger is at 41 Secs, 53 secs, 1.02 and 2.03, but watch the whole thing.
rally clan
Lotus-e-Clan wrote:And those Avengers are very good looking and stylish cars...even more so than the popular Mk 1 & 2 Escorts IMHO... it's brilliant news that they are still competitive! 8)
They certainly are with the right Nut behind the wheel. There is a short piece of Niall in his Tiger in here. But the clip is mainly to show the Modifieds who rally Mk11's that look like a Mk11 but that is it, they are 280BHP Stg 50k+ monsters. The MK11, West Wales is a real MK11 as are the MK1'S. It is just short clip of Irish Historic rallying to wet the appetite to come over and give it a go in an Imp.
Re: Rally Forum (Sticky like the HSA forum)
from this years Knockhill speedfair (autotest demonstration) last year i was within one second of the midget on the rally stage but when we got to the circuit for this kind of stuff they thrashed me (after nine runs through the rally stage it was Noel in the midget and then me) These are two top irish clasic rally drivers and autotesters.
regards mike
Has thanked: 152 times
Been thanked: 243 times
Moose
You missed the best video from the Speedfair Autotest - The IMP :lol:
video imp rallying
imp on its way to setting fastest time on Johnston Trophy 2009
Ben (pobsport on here) with my old stilleto previously RFKDEMONS now ahs a proper engine and is being used.
regards mike
Imp and others Hangover 2009 - Hawick and Border Car Club.
Anyone up for a single Venue Classic rally June 14th 2009 - Competition preparation not required.
Good day out guaranteed
Contact me for details
pobsport in action on the Berwick classic the nearest i have got to competing this year was he had my brake shoes in his car! well done Ben looks to be going well, will be in touch about suspension set up.
regards mike
Pobsport
Post by Pobsport »
Couple of pics from Berwick Classic Rally thanks to Anthony Wakefield
Heres the Stiletto
And the triplets
Image[/quote]
and another bit of footage of the Stiletto around the quarry
Ben
Pobsport
Post by Pobsport »
Cheers Mike for the Shoes got me right out of a jam. They are good, think ill be investing in some. Ill send you that other rotor arm back. Will be getting some suspension hopefully soon for the Lake District as long as i have enough funds, you can here it bottom out in the quarry alot :D .
Was not all plain sailing on the Berwick snapped the speedo cable after the first regularity on the saturday so had to guess by the rev counter as the trip also runs off the speedo, and then developed an oil leak from the cooler on the second to last test on the sunday but managed to hold out for the rest of the day luckily. All in all one of the best weekends rallying with such a sociable atmoshpere.
Be nice to see you out again Mike.
Ben
well done Ben another fantastic drive in the Lakes time to build a trophy cabinet! A very hot days motorsport with a good entry and some fantastic tests, to hear your car screaming through Lowther park has given me a boost to complete the imp and get it back out on these great events.
regards mike
http://www.youtube.com/user/alip944#pla ... Z9Z9vE0q5o
recent footage of the Durham dales rally sorry to the Vokes family no footage of the imp but i can confirm the imp was being driven well on the day, thanks Noddy the alt worked a treat on the lotus thanks again.
regards mike
Pushing on with the imp WILL be finished before end of the month so the NE25 could be its first event for 20 years :D :D
Did this event 2 years ago daytime regularities and tests and then a night navigational rally, excellent event.
typical rally test on NESCRO events
http://www.youtube.com/PaddonTeamGreen
i know it is not an imp but this is who i am looking after as a mechanic for Symtech racing he is the reason that yet again the imp rally car is on the back burner although i did do some work on it yesterday.
At the finish
Nigel Webster (anrw)
Car Model: None currently
Post by Nigel Webster (anrw) »
Henry and I had a very successful weekend at the Cambrian Rally on 8th October. Based in Llandudno, there were 6 stages through the Penmachno, Clogaenog and Alwen forests followed by two passes through the stunning 2.94 mile Great Orme tarmac coast road which follows the headland facing the Irish Sea. Being on a cliff face seemed less of an issue to me than the 3” high kerbs which meant the punishment for untidiness would have been severe (3 wheeled Chamois at the very least!).
Penmachno is said to have spectacular views but I can’t say I noticed!; Clocaenog (like the Great Orme a famous ‘Lombard RAC’ stage) was very fast with lots of technical bits and hairpins that had to be got right!
This is our third rally with the Chamois which was completed earlier this year, after an 8 month build. We were fortunate enough to have ‘Imp royalty’ as our service crew (Mike Dent - ‘Moose’ and Sam Thompson) who didn’t have to ‘put a spanner on’ the car all weekend. We did however end up the event with significant negative camber on the OSF wheel following a severe bump left by a combination of Escorts and WRC’s digging ruts. Mike noticed it early in the event but after checking it was nothing serious kept it from the crew so we wouldn’t back off!
Out of about 120 starters we came 80th beating many serious rally cars with 3 times our power. We came 7th in the historic class (pre 68) swapping times with the Austin Healey 3000 of Graham Goodall (who has won the HRCR Historic Stage Rally Challenge) but Graham used his superior power to good effect on the Great Orme and ended up 40 seconds up on us over the whole event. We also began to get close to, and on some stages, take time out of some of the Minis (all 1300’s) which will not please them much!
We’ve learned a lot about how to drive a competition Imp (I last drove a road going Imp in 1966!) but even more about what we have done right and wrong about building a stage rally car. There is a list of developments that we plan to do over the winter to improve the car. We hope to join Geoff Taylor in the British Historic Rally Championship next year and we might even coax ‘Moose’ to do the odd forest event too with his newly rebuilt rally Imp. I know of another two Imps that will do selected events also but we have a long way to go to have as many cars out as the circuit racers. However if anyone is interested please contact me on nigel@anrw.co.uk or on this forum and I’ll happily share what little I know. We do need more Imps out in the forests!
Junction 8 Clocaenog by Paul_Mitchell@madasafish.com
Penmachno Forest North by Paul (Pap!!! On Flickr)
Penmachno Forest South by Geraint Evans (On Flickr)
Due from the Sam Thompson editing suite any day is some incar footage which I will post here as soon as it is published on YouTube. In the meantime if you can’t wait to see some footage have a look at
But don’t blink or you’ll miss us ( 20 seconds in).
Thanks for the support of club members out on the stages this year.
Nigel Webster
Nigel Webster
Nigel and Henry's chamois is now my official test car :lol: will suggest lots of things to try to save me some money :lol:
It was a great weekend and after 4 rallies Nigel is now getting a feel for the car as you can see in the times some were nearly as quick as the front runners in much more powerful cars and some were a bit slower showing to me that the car and driver have the potential to run consistant top times, the car has proved itself bomb proof a credit to the prep. with the information gathered over the weekend some development off season can take place, mindfull of not changing too much too quick or else it will be like a completly different car but staged changes and a few tweaks will give a sound base from which to develop, further increasing Nigels confidance that the car will do what he wants consistantly so he can then start to push the car.
me working front corner and at 3 mins was the skill of Hayden as he holds onto the car in a big moment!
Cambrian Rally Alwen Forest Stage in the Chamois
At last some video of the Cambrian Rally this year. This is Shammy Moo doing the entire SS4 Alwen Forest (6 miles) stage (worts and all!)
Click the link at www.friesianracing.co.uk
Nigel Webster
Nigel Webster
Cambrian Rally In-car footage
We've had a few problems with our website so if you would like to see the in-car footage of
'Shammy Moo' on the Alwen Forest stage of the Cambrian Rally have a look at:
Nigel Webster
http://www.friesianracing.co.uk
Nigel Webster
leadfoot
Car Model: Hillman Imp Spring Special
Post by leadfoot »
Hi Mike
clad you had a good rally wish i could have been there, sorry to here about the demise of the other two imps :( looking forward to seeing the the imps on hrc events this year, if i can be of any help in servicing on events please let me know, now i have got the AFY on the road (your co-drivers old car ) i can start work on GTK, so plenty of work, would be greatful of surgestons and addvice, in all aspects of preperation.
How you doing with your car Mike as i read your thred with interest and like ideas would like to see your someday soon.
well done Nigel and Henry
all the best for all for the comming season.
Keith.
Hi Keith as with all levels of motorsport who knows what is happening next i am hoping that i will be able to finish my imp and get out on the rallies with Nigel and Henry, yet there is the full time shift job which to be fair does give me grouped days off to go and do the WRC stuff, no definate plans for 2012 myself so the best thing if you want info and ideas, is a pen and pad and pop over to my place for a brew and natter whilst i am working on the car or other cars look at what i have done and make notes and fire the odd question at me as to the why certain things have been done. this of course will incur a charge usually me shouting make me another brew! if you want to get involved in servicing i would talk to Nigel via PM he is the one that decides the amount of team members required and if i am asked to go on event i decide who does what, depending on rally service experiance. so call anytime to arrange a trip over if phone is off i am at work or in bed, i work 2 12 hour days and then 2 12 hour nights 7 till 7 so if you ring in a morning and the phone is off do not leave a message but try later in the day before 7 at night. if that fails try after 8 at night as i matbe on days! confused good !! mines a black coffee no sugar, oh yeah bring biscuits!! :lol:
http://bulldog-rally.co.uk/
Next event for the imps on the historic stage rallies anyone coming to watch!
Faro 1 April 2012
World Rally Championship, Rally Class 2012, Rally Portugal
Protasov wins Rally Class in Portugal
Under conditions so treacherous that the entire Friday afternoon loop of stages were cancelled, Ukraine driver Yuriy Protasov won the inaugural round of Rally Class on Rally Portugal. Protasov, a multiple rally champion in his homeland, also won the Group N category (class 3) on the all-gravel event in 20th overall.
Rally Class is designed as a feeder championship to the Production Car World Rally Championship, using identical Group N Subaru Imprezas, built by reigning PWRC champion team Symtech Racing, on control DMack tyres.
The winner receives five fully-paid rallies in a Subaru Impreza R4 car next year, while the second-placed finisher will get two rallies, all expenses paid, in a Group N Impreza. So far, four drivers have signed up for the inaugural series and they all encountered varying fortunes on the first event of the year.
Yuri Protasov had no problems during the opening night stages and enjoyed the muddy stages of Friday, despite the marginal conditions. The total traction and user-friendly handling of the newly-built Group N Symtech Subaru Impreza enabled him to pull out a significant advantage without taking unnecessary risks.
On Saturday's six stages, he was slowed by two punctures and he was also affected by a strange noise from the car on one stage that forced him to stop and investigate. However, the problem turned out to be nothing, and he was able to continue to service. On Sunday, he enjoyed a clean run to the finish over the remaining six stages.
"This was a great way for us to start the year," he said. "Rally Class has proved to be a lot of fun, and to come home with a win is always satisfying. This was a very difficult rally, and for a brand new car, it's great for us to get to the finish with no major problems. I'd like to thank all our mechanics and our competitors for a fantastic weekend. Now I'm already looking forward to the next round!"
Latvian Andis Neiksans finished second in the Rally Class standings after a fraught start to the rally on Thursday. When he went to start the night stages that opened the event, he found that the lamp pod was not working. His attempt to fix the electrical problem actually made things worse, as the car then refused to fire up out of regroup and he lost 16 minutes.
On Friday his run through the stages was straightforward, but he lost time on Saturday as the result of a timing issue and some problems with the brakes. At midday service, the gearbox was also changed. Nonetheless, he finished second overall in the Group N standings on Sunday after a challenging event.
Mexico's Ricardo Trivino is third in Rally Class but he encountered problems on Friday's SS6 when he hit a rock and opened up the front-right wheel. Unfortunately, the car then slid off the road at around 10kph on the inside of a right hand corner. The Symtech team was able to repair the damage and the Mexican re-started on Saturday. However, the accident had affected the suspension and this slowed Trivino over the first loop of stages. The problem was fixed at midday service and he had no further problems all the way to the finish on Sunday afternoon.
Multiple Indonesian drifting champion Rifat Sungkar took his time to adapt to the unique conditions in Portugal. Sungkar battled an intermittent gear selection on Friday, which was fixed during the final service halt, but he too picked up two punctures on Saturday. On the day's final stage he was losing time with a braking problem, so he chose to stop and take a five-minute super rally penalty rather than lose more time by battling to the end.
He was set for a strong finish on his World Championship debut, but on Sunday's penultimate stage he slid off the road. After losing several minutes he was able to get back on and complete the final power stage. He ended the rally classified fourth in the Rally Class standings, ensuring that all the Symtech cars that started also finished.
Symtech Racing's Dirk Van der Sluys commented: "We faced very difficult conditions for our debut, which wasn't made any easier by the fact that our tight deadlines for championship registration meant that the cars weren't finished until just before the rally. Nonetheless, we're here with everything we need and we've certainly had a spectacular start! I think everybody has understood that this is our first event and so there's plenty of work to do, but we're delighted that Yuri has had a trouble free run over the tough stages to claim this win. I'd like to especially thank the Portuguese organisers for the warm welcome they have given us and all their help. Now we look forward to the next round on the Acropolis Rally, where we may also be joined by some new competitors."
After Portugal, Rally Class continues with five more rounds in Greece, Germany, France, Italy and Spain making three gravel rallies, two on asphalt and one mixed-surface event.
For more information and copyright-free images please visit www.rallyclass.com
Loutraki, 22 May 2012
World Rally Championship 2012 - Acropolis Rally
Rally Class prepares for arduous adventure in Greece
The new-for-2012 Rally Class competitors will face their biggest challenge of the year later this week as the crews prepare for what is arguably the hardest round of the championship: the Acropolis Rally.
Rally Class is designed as a feeder championship to the Production Car World Rally Championship, using identical Group N Subaru Imprezas, built by reigning PWRC champion team Symtech Racing, on control DMACK tyres. The Rally Class series consists of six rounds and provides a level playing field for the participants, with all cars prepared and managed by the Belgian team. A unique prize structure rewards the overall winner with five fully-paid rallies in a Subaru Impreza R4 car next year, while the second-placed finisher will get two rallies, all expenses paid, in a Group N Impreza.
The Acropolis Rally is the second round of this year's Rally Class and is one of the longest running events in world rallying. The stages on the Loutraki-based event feature a mix of rough, dusty and very twisty mountain passes, while blisteringly hot weather usually means temperatures in the car exceed 50 degrees centigrade. Cars must be robust to cope with the demands of the rock-strewn stages and crews have to be at peak physical fitness to cope with the arduous terrain and stifling temperatures.
The opening round of the Rally Class took place in Portugal in March with Ukraine driver Yuri Protasov claiming full points to establish an early lead at the top of the championship table. Latvia's Andis Neiksans is second with Mexico's Ricardo Trivino in third. Multiple Indonesian drifting champion Rifat Sungkar is classified fourth in the Rally Class standings.
Championship leader Yuri Protasov said: "Portugal showed just what a fantastic and above all good value innovation Rally Class is to the World Rally Championship. Not only did we win the Rally Class standings, but we also won Group N overall, which goes to show that these cars can fight at the very top of the category as well. Portugal was an incredibly tough rally, but I think the Acropolis will be even harder. It's a legendary event that is well-known for the roughness of the roads and it will be a real test for our Subaru Impreza. More than ever, I think the key will be to pace yourself and stay consistent over all three days of the rally. That's going to be my aim, so I will drive my own rally and not worry too much about what everybody else does."
Dirk Van der Sluys, of reigning Production Car World Rally Champions Symtech Racing added: "We received a fantastically warm welcome in Portugal, after a race against time to get all our cars ready! We're privileged to have four fantastic competitors in our first year of Rally Class this season, who showed in Portugal that they are ready to face anything and will drive flat-out all the way. The legendary Acropolis Rally will be a really big test for them, but having had the opportunity to learn their cars in Portugal, I'm sure that our drivers will be able to get the most out of them in Greece. It's going to be a rally that tests their strategy as well as speed, not to mention their physical fitness. Motorsport is always going to be an expensive business, but our aim at Rally Class is always to provide our competitors with the best possible value. This enables them to participate at the top level in a reliable car, receiving plenty of exposure in the media and the service park, while keeping costs down. They also all have a fantastic chance of winning some great prizes. In the current economic climate, this return on investment is more important than ever."
A ceremonial start in Athens will kick off this year's Acropolis Rally on Thursday evening (24 May) with the first full day of action commencing on Friday. Drivers will face 410 competitive kilometres over 22 special stages before the finish podium in the rally base of Loutraki on Sunday afternoon.
info : dirk@symtechracing.com
www.rallyclass.com
anybody going to be out there ? i have bumped into people i know at most events, small world! fly tomorrow, listen to rally radio on wrc.com
Loved the stage and the driving was pretty good too.
Correct link
Free rallying for novices
Wigton Motor Club
Lake District Classic
and
Lake District Targa
Sponsored by
Sunday, 7th July 2013
A counter towards the
Gates Tyres
Historic Rally Awards
Wigton Motor Club Ltd
Lake District Classic Rally
and
Lake District Targa
Sponsored by
Lake District Hotels Ltd.
We have pleasure in inviting you to take part in the Lake District Classic Rally and the Lake District Targa on 7th July 2013. The events will start and finish at the Penrith Truck Stop close to Junction 40 on the M6. This year there will be no timing or regularities on public roads, however the parts of the route on private land will be interesting and involving so you will not be bored. The route will visit a total of 20 tests, all of which should be enjoyable for both competitors and marshals alike.
There will be some simple preplotting of the route by map references and directions only and there will be ample time allowed for this before the start. Cars must comply with MSA Blue Book vehicle regulations Sections R 18 and 19 for the event entered. The Classic is a counter towards the Gates Tyres Historic Rally Awards.
We are grateful for the continuing enthusiastic sponsorship of Charles and Kit Graves of Lake District Hotels Ltd whose help enables us to maintain the entry fee at previous levels.
Lake District Hotels have made special rates available at the George Hotel in Penrith for those seeking accommodation.
In celebration of National Motorsport Week we are offering a Free Entry to the first three absolute novice crews to enter. Neither crew member must have competed in any rally previously. The £95 entry fee will be waived for the first three such entries received by post by the entries secretary. The entries can be for either event.
We look forward to seeing you and promise a choice of two enjoyable events with limited road mileage without any trickery, sufficient time to preplot the entire route and an early finish.
The Organising Team.
Lake District Classic Rally 2013
Supplementary Regulations
1.Announcement
Wigton M.C. will promote two clubman status road rallies on Sunday 7th July 2013:-
The Lake District Classic Rally running under MSA Permit Number Applied for.
The Lake District Targa Rally running under MSA Permit Number Applied for
Both with start and finish at the Penrith Truck Stop near Junction 40 M6.
2. Jurisdiction
The events will be held under the General Rules of the RAC MSA Ltd incorporating the provisions of the International Sporting Code of the FIA & these Supplementary Regulations. Both events will run as Clubmans Status events.
3. Eligibility:
Both events are open to members of Wigton Motor Club and. competition licences are not required. All drivers and crew must produce Wigton Motor Club membership cards at signing on.
Historic Permit - Cars registered prior to 31.12.81 which comply with the MSA regulations may be entered in the historic event and period modifications only are permitted. Cars constructed 1/1/68 – 31/12/81 with more than 4 cylinders, two carb chokes or more than 1 camshaft will be submitted to the MSA for consideration.
Targa Permit – Only 2 chokes, 4 cylinders and non turbo 2 wheel drive cars are permitted. Fuel injection permitted if fitted as standard to the model entered.
4. Programme:
Entry list opens now
Entry list closes June 28th
Final instructions e-mailed July 1st
Pre event scrutiny & documentation July 7th 07.30
Event starts July 7th 09.30
Awards presented approx. July 7th 17.30
Any crew not signed on by 30 minutes before their start time will be excluded.
5. Route:
The event will consist of a 70-mile route in the northern Lake District and Eden Valley based on 1:50,000 Landranger O.S. Maps 90 and 91 - any recent edition. There will be two regularity sections on private land timed to the second. There are no time penalties on any public road sections except for exceeding 30 minutes maximum lateness at MTC 1, MTC 3- Lunch Out and MTC 4 Finish. Your due time at any point is that shown on the Time card plus your start number in minutes x 2 (as cars are running at two minute intervals). There may be passage checks and code boards on the tests, which have to be visited and recorded subject to penalty. The competitive part of the event will consist of the tests and regularity sections on private land.
Every competitor will be provided with full route instructions defined by map references and direction of approach and departure. Test book and time cards plus a time schedule will give full details of the event. All will be available after scrutiny and at least 1 hour before individual start times. Cars should start each test in numerical order where possible, at two minute intervals. Walking the tests is not permitted.
6. Classes:
Lake District Classic there are eight classes in four catagories:
Pre- Historic (pre 1960)
H1 Up to 1500cc, H2 Over 1500.
Historic (1960 - 1967),
H3 Up to 1500cc, H4 Over 1500.
Post Historic (1968 -1974),
H4 Up to 1500cc, H5 Over 1500
Classics: (1975- 1981) to road rally specification. Not eligible for overall awards.
C1 Up to 1400cc C2 Over 1400cc
Lake District Targa
There will be three awards Ist o/all, 2nd o/all and 3rd o/all
All vehicles must comply with the appropriate MSA Rallying Technical Regulations (R) Section 18 and 19.
If there are less than 4 cars in a class the organisers reserve the right to almalgamate cars with another class in the same category. For cars entered in the LDC application will be made to the MSA to accept entries from cars registered between 1.1.1968 and 31.12.1981 with more than four cylinders, more than one camshaft and/or more than two carburettor chokes. Competitors must mark their entry forms accordingly.
7. Awards:
Awards will be presented to those competitors who comply with the above and are then classified on their total time and code board penalties on the special tests plus regularity time and code board penalties.
Unique perpetual awards will be presented to the first two in each class subject to the number of entries. The
number of awards may be increased or decreased as appropriate.
The outright winner and second overall will receive the unique perpetual awards but are not eligible for class
awards.
8. Entries:
The entry fee for either event is £95 which includes coffee at the start, a light snack at lunchtime and dinner
at the finish.
Club membership for Wigton Motor Club is available for the balance of the year at £8 per person.All entries
must be made on a correctly and fully completed entry form accompanied by the correct fee. Cheques
should be crossed and made payable to Wigton M.C. Ltd. All cheques will be banked on receipt. The closing
date for entries is June 28th. Late entries may be accepted after that date with an additional fee of £25. The
responsibility for entering the correct event and class lies with the entrant.
Entries Secretary:-
Ron Palmer, Manor Croft, Moorhouse, Carlisle, CA5 6EL
Phone 01228 575153 ronpalmer777@hotmail.com
The maximum number of starters for the Lake District Classic is 60 plus five reserves and for the Lake District Targa is 30 plus 5 reserves. Entries will be accepted in order of receipt and the entry may be reclassified for the start order. Entry fees will only be refunded (minus a £20 administration charge) if the entry is withdrawn in writing prior to June 28th.
Withdrawals after that date will not receive a refund.
9. Officials:
Club Steward John Taylor
Clerks of the Course David Agnew and Ian Whittaker
Chief Marshal David Agnew 01946 841455
Entries Secretary and
Secretary of the Meeting Ron Palmer 01228 575153
Assistant Secretary Ian Whittaker
Time Keepers David Agnew & Graeme Mactavish
Scrutineers John and Andrew Graham
Results Graeme Forrester and Chris Leece.
PR and Safety Officer Graeme Forrester
Start and Finish Coordinators. David and Debbie Rushton
10. Results:
Provisional results will be published as soon as possible after the finish as per H35. Any protest must be lodged in accordance with C5.1
11. Route Instructions:
Crews will be provided at signing on with all instructions necessary to plot the route, plus test diagrams and time cards. OS Maps 90 and 91 any recent edition will be required. The route will include transport sections with no time penalties and regularity sections timed to the second.
12. Identification:
Cars will be identified by classic style adhesive rally plates window numbers and numbered time cards.
13. Penalties:
Target Timing will be used for the road sections but there are no road time penalties.
Each competitor must visit all the tests and regularities and reach the finish within 30 minutes of their due
time to be classified as a finisher. There will be no other road timing penalties except for exceeding maximum
lateness of 30 minutes at MTC1, MTC3 and MTC4. The special tests will be run to
RAC MSA regulations and full penalty details will be contained in the final instructions.
14. Times:
The onus in obtaining the correct times lies entirely with the competitor. In the event of a query, the
time on the time card and marshals’ check sheets will be used.
15. Final instructions;
Will contain details of scrutiny, noise checks and start venue arrangements plus details of test and
regularity penalties.
16.Insurance
The entrant is required to supply details and the name and address of his insurers on the entry form. Chaucer
Insurance will be issued for the event.The basic rate for cover on this policy for the event is
£25 per competitor.
All new applicants wishing to use the scheme must comply fully with the points on the entry form.
In the event of a competitor causing damage for which the club must claim, the first £350 will be
payable by the competitor. .
17. Accommodation is available at specially reduced rates at The George Hotel, Devonshire Street,
Penrith. For details call 01768 862696 and mention the Lake District Classic Rally.
Acknowledgements
The club wishes to thank the following for their support in this event.
Charles and Kit Graves, Lake District Hotels Ltd
Gates Tyres.
The landowners on the route:
Mr Alan Jenkinson and Penrith Truckstop,
Mr Edward Wood,
Mr Alastair Dunn.
Mr Richard Morris, PFK Auctions.
Mr Paul Bird,
Carrs Billington,
Lowther Estates
Plus:
The Lake District National Park
Cumbria Police
The MSA
Mr Fred Bent (RLO)
Mr John Taylor
The clubs and individuals who marshal so willingly.
Rec. Ack. Class No.
Wigton Motor Club
Lake District Classic / Lake District Targa
(Delete as appropriate)
ENTRY FORM
Driver: Wigton MC M/ship no.
Address:
Post Code: Telephone:
Navigator: Wigton MC M/ship no.
Address:
Driver E-Mail,
Nav. E-mail.
Car make: Model:
Year: Capacity:
Registration: Class:
ENTRY FEES:
Entry fee £95 £
Club membership for the balance of 2013 £8 per crew member. Application form must be completed. £
Extra meal package £12.00 (2 included with entry fee) £
Chaucer RTA Insurance fee £25 £
Total enclosed £
All fees include coffees at the start and two dinners at the finish.
Please make cheques payable to Wigton M.C. Ltd.
Declaration
I declare that I have been given the opportunity to read the General Regulations of the Motor Sports Association and the supplementary regulations to this event and agree to be bound by them. I declare that I am physically and mentally fit to take part in this event and I am competent to do so. I acknowledge that I understand the nature and type of the competition and the potential risk inherent with motor sport and agree to accept the risk. I understand that all persons having any connection with the promotion and /or organisation of the event are insured against loss or injury caused through their negligence.
I confirm that the use of the vehicle hereby entered will be covered by insurance as required by law which is valid for such part of this event as shall take place on roads as defined by law
I confirm I have read and agree to the terms of the declaration :-
Driver’s Signature...................................................................... Date Age. (if under 18).
Navigator’s Signature....................................................................... Date Age. (if under 18)
Consent of Parent or Guardian if the driver and/or passenger is under 18 years of age.
Parent or Guardian of Driver Parent or Guardian of Navigator
Name................................................... Name........................................................
Relationship............................................ Relationship..............................................
Address...................................................... Address......................................................
Signature..................................................... Signature.....................................................
Insurance Declaration
Competitors must have Insurance in place which provides Third Party Liability cover that complies with the Road Traffic Act. This can be an extension to the existing motor policy for the car or purchased via the event organisers.
If a competitor uses an extension to an existing policy, they will be required to sign a declaration that the cover complies with the requirements of the Road Traffic Act. Any responsibility for a fraudulent or misleading declaration about existing cover lies with the competitor.
If a competitor wishes to purchase cover via the organisers then they can do so prior to the event providing they comply with the following.
All drivers must be aged 19 or over.
Have held a full licence for a minimum of 6 months.
Have no more than 6 points on their licence.
Have had no more than 1 fault claim in the last 3 years.
Any competitor, who falls outside these perameters, may be offered cover at the standard price (or a higher price) depending on circumstances. These competitors must ask the event organisers to obtain agreement from Chaucer Insurance prior to the event.
The Event Organiser’s RTA scheme is underwritten by Chaucer Insurance.
I am able to comply with all the points of the Chaucer Insurance Declaration
Signature Print Name Date
Competitors using their own insurance are required to provide the details below:-
MSA Regulation K22.2 (Cars registered between 1.1.68 and 31.12.81) Please indicate if your car has:
More than two carburettor chokes………………….
More than one camshaft…………………………….
More than four cylinders……………………………
Send all completed forms to the Entries Secretary :-
Wigton Motor Club
Membership Application Form 2013
Lake District Classic / Targa Entrants
Name(s)
2012 memb. no.
Email
Address 1
Address 2
Address 3
County
Post Code
Phone number
The events that I would hope to take part in are: Speed Historic Rallies Autotests
Classic Tours Show Autosolos
I hope to marshal on some events
Fees
Single until 31st December 2013 (Magazine by email) £8.00
Cheques payable to Wigton M.C.
1972 Welsh Rally with several imp
springcourt
Car Model: singer chamois/imp californian
Post by springcourt »
hi alan here from springcourt auto and motorcycle centre Rochdale goin to get back into rallying after a 25 year rest ! rear wheel drive only for me so fancied a mk 2 modern didn't quite have the 100k needed !so were goin to build a imp modern have a caly shell for the build would like some advice in the future thank you
a quick over view we are an auto and motor cycle centre with back grounds in aerospace engineering we build racing motor cycles .We designed and built a 650 twin that my business partner Phil Mcgurk won the 2010 ultralightweight manx grand prix breaking the lap record in the process(pic posted) using the same thought process for the imp we are goin to build an imp with as much modern technology as possible. having purchased a road goin singer cham fantastic little car but definatly room for improvement will try to keep post goin
cheers alan
Has thanked: 15 times
Been thanked: 28 times
Just to reply to a question earlier in this thread - one place to mount a scissor jack is inside the spare wheel. I have mine mounted that way, and the wheel is bolted horizontally onto the top of the fueltank. (To a specifically designed frame). Strong cable tie type fixings through the wheels slots hold the jack in place. A pair of pliers or sidecutters in the toolkit suffice for extracting it should it be needed, just carry a few ties for resecuring it afterwards.
Has thanked: 60 times
Been thanked: 53 times
Post by colimp66 »
I hopefully will be going up with my son to see you all in action.
Gutted we missed you on the Berwick Rally Mike considering you were on my doorstep in Dunbar when you were razzing around Howdens.
Hoping for better weather for the weekend.
Good luck.
Wish you good luck and holding thumbs! :D
we won the blue streak targa rally on sunday despite making a few mistakes, more video footage will follow, Brian hodgson was also out in his 930 powered imp and finished 6th overall as soon as i have a proper copy ofthe full test time results i will post on here.
Car Model: 68 Chamois Sport, 72 Imp Sport, 76 Datsun 260Z
Has thanked: 68 times
Been thanked: 88 times
Nice!
Next event is the Durham dales rally at the Nissan test track, http://www.durhamautoclub.org.uk/
http://www.nescro.co.uk/index.php
worth a look many good events
Couple of untidy moments but the drawings are not to scale and we had never seen the test sites before so driving blind.
Well the engine is done thanks to Andy at Shrigley now to rebuild the car !
http://www.heroevents.eu/Events/ScottishMalts/
i will be in Scotland but not at the imp event and not in an imp, i am media driver for the event.
Has thanked: 184 times
Been thanked: 13 times
Cheers, Mike. It may take me a while to make sense of that lot! :?
Thank you very much, Mike. I found Geoff and Steve in the results. :) They were doing well against some tough opposition! 8)
Any idea what went wrong with the transmission? It sounds like oil loss leading to a mechanical failure of some kind.
engine and box coming up to me soon for a valve clearance check on engine. I will report back on the box findings but to me i suspect a broken crownwheel tooth or sun and planet wheel failure, this is based on, i can select all gears the, car drove off the main road making a clunking sound, no oil loss on the sump guard.
Steve and Geoff's times were good there were quite a few moderns struggling to match the pace.
http://www.devilsownrally.co.uk/
Anybody entering ?
Marshalls required for the event no experience required you will be well looked after.
