imp heated windscreens
This is the section for passing on details of suppliers that have offered you good service and would like to recommend to others. Please give brief details including price(s) and always include their full contact details and a website link.
No traders, self advertising or complaints please,
Post by moose »
http://www.heatedwindscreen.com/acatalo ... reens.html
i highly reccomend Ricky and his company for quality of product and service.
skamanfrank
Car Model: 1972 Imp Super
Re: imp heated windscreens
Post by skamanfrank »
What's the difference between the Monte Carlo and the normal heated screen?
I'd really like a Ford style one.
Frank
Car Model: Imp
Monte Carlo has the visible horizontal silver line at the top and bottom of the screen, the old fashioned way of doing it, a Ford type screen has elements that are almost invisible, these types are slightly more easily damaged when installing if someones a bit rough handed with them, but they usually have the elements split into 2 separate circuits left hand and right hand but they still work together.
The Ford style would be my preference too, the silver lined old style would get on my nerves.
Post by moose »
Normal is as per Ford, as you can see in pics no silver stripes, the Monte is as per the monte works cars (or similiar before an anorak jumps on my back) with silver stripes across.
skamanfrank
moose wrote:Normal is as per Ford, as you can see in pics no silver stripes, the Monte is as per the monte works cars (or similiar before an anorak jumps on my back) with silver stripes across.
Looks like it has the silver strips in the pic for the "standard" one though:
Image?
vs
Am I missing something or have they just used the wrong photo?
Frank
Post by moose »
yes pic is wrong but the description of a clear screen is correct if you want to see what a clear screen looks like look at the coupe.
Post by Grahame59 »
Just curious, on the Monte Carlo screens with the rather garish silver lines, are they the only heated elements or do they have Ford-like elements running vertically between the silver lines? If the silver lines are the ONLY elements I'd be interested to know how effective it is as there is quite a distance between the two lines. Anyone actually fitted one? If I was lucky enough to own a works Imp then obviously the Monte Carlo style is pretty much compulsory but for a road Imp the Ford type has to be better, if only to avoid everyone asking what those silver lines are every time I park the car!
Very slightly off-topic… I'm thinking of getting one of their laminated screens with a top tint (most likely not heated as the car is rarely used in winter), does anyone know if this requires a different windscreen seal as I think laminated screens are slightly thinner than toughened?
Imp011
John Simister
Post by John Simister »
I believe there are indeed thin vertical elements between the visible silver strips, but not as many as in in the Ford-type heated screen. The Monte Carlo-type heated glass was an option for the rear window of some cars in the 1960s, including the Rover P6 (not fitted to mine, sadly).
Post by Turboimp »
I was lucky enough to have the Monte Carlo type in My 1967 Imp Sport when I bought it in 1972 ( ex hartwell demonstrator ) Still going strong by the way, The advantage of this type is lower current consumption as the elements are shorter , the silver strips never bother me . I cant say I even remember seeing them until it was mentioned above .
There is a Myth going around that FORD have some sort of patent on these , Ford are not the only company using them , volvo do as well on later models ..But It was TRIPLEX who brought these to us as said above ... first seen as a rear screen in an Early 1960's Rover . Imp009
must be some kind of record !
skamanfrank
Thanks for clearing that up Mike. Perfect for what I want then.
Turboimp wrote: There is a Myth going around that FORD have some sort of patent on these , Ford are not the only company using them , volvo do as well on later models ..
Could it not still be a Ford thing then but used by other PAG members e.g . volvo and JLR (who also use them)?
Frank
Post by Grahame59 »
John Simister wrote:I believe there are indeed thin vertical elements between the visible silver strips, but not as many as in in the Ford-type heated screen. The Monte Carlo-type heated glass was an option for the rear window of some cars in the 1960s, including the Rover P6 (not fitted to mine, sadly).
A friend had a Rover P5B in the early 90s which also had this type of HRW. I remember being very impressed with the near invisibility of the elements. It was the first of that type I'd seen.
As a kid I used to collect all the brochures at the Motor Show and noticed that you could order a heated rear window as an option on your new car. I remember thinking that surely a heated FRONT screen would be even more useful! Later, I can't recall the details but there was some patent around in the 90s which allowed Ford to use this type of element for heated front screens, which is why they are referred to as 'Ford type'. I recall thinking at the time that it was rather immoral to put a patent on what was clearly a safety item for commercial gain. Obviously lots of brands have them nowadays so maybe the patent was only granted for a limited time only? Our 2007 Mini Cooper S Clubman has a heated front screen and I must say it works extremely well. Our Kia Sedona also should have had one – it has the switch but unfortunately the previous owner must have suffered a broken screen as it was replaced by a standard screen. Anyway, it looks like any patent no longer exists and they are far from exclusive to Ford.
Imp011
imporium
Post by imporium »
Grahame59 wrote:Just curious, on the Monte Carlo screens with the rather garish silver lines, are they the only heated elements or do they have Ford-like elements running vertically between the silver lines? If the silver lines are the ONLY elements I'd be interested to know how effective it is as there is quite a distance between the two lines. Anyone actually fitted one? If I was lucky enough to own a works Imp then obviously the Monte Carlo style is pretty much compulsory but for a road Imp the Ford type has to be better, if only to avoid everyone asking what those silver lines are every time I park the car!
Imp011
Hi Grahame, Laminated screens are a bit thicker, ie 1/4" & used a different wider grooved rubber & you will be lucky to find one... Part No 7209761.......Malcolm Husky003 Van001 Imp003 Imp009 .
Post by Grahame59 »
Imp011
Thanks, Malcolm. That's not good news. If you are saying the screen seal that you supply for toughened screens won't work with a laminated screen that sort of puts a lid on me – and others – getting a lam screen! I'd better stick with my toughened one unless Ricky can supply the correct seal. (I've emailed him to see.)
EDIT: Just had a reply from Dan at Ricky's: ''Funnily enough we have an Imp ourself and have just fitted a heated screen to it. The standard seal is actually ok with a lam screen if it is in good condition as we are talking about maybe half a mm difference''
imp.sport
Car Model: Sunbeam Imp Sport (Marv)
Post by imp.sport »
Just curious of how much these variants are as last time I saw a price for these screen's it was out of range for me.
I'm just one reasonable lottery win away.
Post by Grahame59 »
imp.sport wrote:Just curious of how much these variants are as last time I saw a price for these screen's it was out of range for me.
Have a look at the link at the top of this thread and tap 'Imp' into their search box. They do various laminated Imp screen combos: saloon or coupé, clear or top tinted (green), hot or cold. Be aware though that postage is hefty at around £44 as it comes attached to a pallet. Also factor in new seal (recommended if you don't want leaks) and relays, switches, wiring etc for a hot screen. There's also the risk of it cracking when fitting (laminated screens are a lot more fragile during fitting compared with a toughened screen). Two lottery wins should just about cover it.
Imp011
imp.sport
Post by imp.sport »
Sorry :oops: I should have looked.
I'm so used to finding websites where you have to ask for a quote to find out.
Actually cheaper than last time I heard even with the extra pallet.
Just a generous birthday gift away now. :)
