DT1 - club spares list
Club Spares Info - parts lists and contacts in this forum
Moderator: spares
Postby pure~hillman~imp » Mon Jun 12, 2017 7:21 pm
Hi all, to save hassling the spares team I was wondering if anyone could confirm for me whether DT1 (hinge plate door stainless with screws) is the plate that sits inside the inner arch that the lower hinge mounts to? If it is I can put my order in and save everyone a bit of time.
Change of location: Avoiding teh forumz Police...
pure~hillman~imp
Car Model: 1976 Saloon, MX5 Turbo
Re: DT1 - club spares list
Postby Dave ' Linwood ' Lane » Mon Jun 12, 2017 8:38 pm
I believe it is , for some unknown reason though the bolts are metric :roll:
Postby The Nun » Mon Jun 12, 2017 9:07 pm
Dave ' Linwood ' Lane wrote:I believe it is , for some unknown reason though the bolts are metric :roll:
Another repro not quite right again I suppose?
Peter Nunn...ey! Im member no.33
Singer Chamois? I know them, my wife's got one of their sewing machines.
Car Model: Singer 998 B1 Sport Chamois 1966
Postby John Ross » Mon Jun 12, 2017 9:44 pm
It is indeed metric
Fits well, but its a real PITA when you have a hand full of screws taking doors on/off to set position and try and put the wrong one in while holding a damn heavy object at arms length .....
I have not orderd any yet but I also plan on doing the same as Dave has done and use socket head countersunk screws instead of those damn cross head devils which end up being rounded to hell after many years of having impact drivers fired at them then badly fitting screwdrivers.......
John Ross
Car Model: too many at moment.....
Postby pure~hillman~imp » Tue Jun 13, 2017 3:17 pm
I'll probably be looking into the same, we have a really good local nut and bolt supplier who have sorted me out with no end of stuff in the past, unless there's an easy online supplier?
Thanks for clearing that up!
pure~hillman~imp
Postby tiker » Wed Jun 14, 2017 5:27 am
Do they supply the top hinge fixing plate if there metric m8 I guess are do you have to make your own?
Postby SimonBenoy » Wed Jun 14, 2017 11:46 am
The top plate doesn't tend to be affected by corrosion as it isn't exposed like the lower one. Regrettably you would end up with imperial bolts in the top plate and metric in the lower. But once refitted, it should be good for many years.
SimonBenoy
Return to Imp Club Spares
Users browsing this forum: No registered users and 1 guest
