Parts remade last few years by Malcolm Anderson Imp Parts!
Postby imporium » Fri Jan 21, 2005 10:01 pm
Hi All,
Just to give you a very rough idea of most of the NEW parts we have had re-made / resourced over past few years! as they were generally unobtainable ??
Coupe. front, rear & side window rubber seals
Saloon. front screen seal, both rear opening rear window seals,
rear side w/seals, pairs
Bonnet front edge seal
Rack & Pinion Gaiters & special clips
Track rods l/h & r/h. with grease nipples
Speedo cables. both clip on & screw on heads
Throttle cables & Choke cables, both std & sport
Rad hoses, top & btm & water/pump to block & w/p seals
Water pumps
Petrol pumps
Fuel filler neck hose
Gear lever nylatron ballcup
Flexy gear change coupling
Top steering column bush. Mk1 & Stiletto.
Special top column bush for later models
front bib spoiler
fibreglass wider wheelarch's
Van / Husky GRP rear doors
Husky & Van rear door seal
Husky & Van rear door glass seal & insert
Husky & Van rear door lock catch block
Exhaust silencers std & sport m/steel
Race rear 800lbs lower springs
Monte front springs, extra special lower ones
Radiators uprated to higher spec
Engine mtg bush & std spec transaxle mtgs
Oil drain pipes for Sport & 930cc engines
Lock tabs for all of engine
front & rear hub bearing, locktabs
"H" brkt weld in part for top front suspension
Wishbone rubber bush's front & rear.
Wishbone bush,removal & fitting special tool
Kingpin bush removal & fitting tool
Handbrake lever gaiters
Oil cooler mounting brackets...both
Oil cooler pipes
Stromberg throttle cable support bracket
Husky & Chamois trim clips
Super & Sport trim clips
door glass outer scraper seals & clips
Malcolm Anderson
" Keeping the Imp Alive & Kicking "
imporium
Re: Parts remade last few years by Malcolm Anderson Imp Parts!
Postby matty14 » Fri Apr 15, 2011 5:38 pm
hi mate i am after a passengers rear panel fr a 1964 hillman imp
hi i am after a passengers rear panel for a 1964 hillman imp
matty14
Car Model: hillman imp 1964
Postby ibbo » Fri Apr 15, 2011 6:23 pm
its thanks to the likes of malcolm having these parts remade we are able to keep our cars on the road
mark ibbotson
ibbo
Postby Dave ' Linwood ' Lane » Fri Apr 15, 2011 6:28 pm
^^^^^^^^^^^^ Agreed , Big thanks to Uncle Malc and all the other suppliers who keep us on the road :D
Postby ImpManiac » Fri Apr 15, 2011 6:30 pm
^^ Yep. He's a jolly nice fellow to boot! :D
Postby bazzateer » Fri Apr 15, 2011 6:40 pm
ImpManiac wrote:^^ Yep. He's a jolly nice fellow to boot! :D
On the other hand, his brother ....................................................................................... :lol:
FOR THOSE WITHOUT A SENSE OF HUMOUR (YES YOU!) - THE ABOVE IS A JOKE
Barry Blackmore - Temporary Deputy Assistant Under-Manager Chiltern AC
Car Model: 68 Chamois/72 Imp Sports, 72 Deluxe, 67/69 Vogues
Postby HARTWELL MK1 » Fri Apr 15, 2011 6:58 pm
And I remade, all 4 wings, complete floors, and inner and outer sills, and door skins, without these many imps would have been scrapped!,
JEFF DAY
5948 RU Hartwell Imp
LLF 519 sept 63 imp Williams car age 7
HARTWELL MK1
Car Model: 02 07 63 Hartwell IMP
Postby ImpManiac » Fri Apr 15, 2011 7:04 pm
HARTWELL MK1 wrote:And I remade, all 4 wings, complete floors, and inner and outer sills, and door skins, without these many imps would have been scrapped!,
Also a top notch effort, Jeff! 8) My hat is off to you, sir! Without folk like you exploring the boundaries of what is "economically viable" or just plain Imp enthusiasm, many, many cars would have been given up on by now.
Postby ganderson888 » Fri Apr 15, 2011 7:21 pm
Well what can I say Paul, it must run in the family, not matter what Baz thinks... :lol: :lol: :lol:
Postby bazzateer » Fri Apr 15, 2011 9:03 pm
:wink: :D :lol:
Postby J4CK » Fri Apr 15, 2011 9:48 pm
wowa extra low :)
J4CK
Car Model: Imp Super, Imp Sport 998
Postby The Nun » Sat Apr 16, 2011 6:17 am
Isnt he a cider drinker too? :wink:
Peter Nunn...ey! Im member no.33
Singer Chamois? I know them, my wife's got one of their sewing machines.
Car Model: Singer 998 B1 Sport Chamois 1966
Postby GURNSIMPS » Sat Apr 16, 2011 7:06 am
Oh yes..and very good zider it is too!! :lol:
Loving Imps since 1963!!
GURNSIMPS
Car Model: IMP SUPER//TRANSIT
Postby bazzateer » Sat Apr 16, 2011 8:08 am
Wasn't that a hit for the Wurzles?
Postby ganderson888 » Sat Apr 16, 2011 11:04 am
Don't tell him I told you, but Wurzel was his nickname from his school days, way before he moved to zider country.... :wink: :lol: :lol:
Postby bazzateer » Sat Apr 16, 2011 11:26 am
Hence his eBay name!
Postby The Nun » Sun Apr 17, 2011 1:16 pm
bazzateer wrote:
The Nun wrote:
ImpManiac wrote:^^
Ooh Arr Ooh Arr, Ive got a brand new, Imp and I'll give you the key,
something like that anyway :lol:
Return to Imp Club Spares
Users browsing this forum: No registered users and 1 guest
