Wise words - and yes mine is fused --- everywhere on everythingThe Nun wrote:Yes looks like a Caledonian switch, no doubt yours is ok and done, but if you fit the switch to a non fused IMP, the switch can be very easily smashed when selecting reversing if you lever ball is worn meaning the lever can move more than intended, the switch breaks then the contacts can go to earth, result smoke and possible fire.
Fit a line fuse if your car doesnt have them in a fuse box, it has happened and a fire nearly occured so beware!
- Has thanked: 130 times
Re: Nods news - Vusky has a reversing light
All excellent work, Dave. But your shoes need cleaning !!
My take on the reversing light switch was to mount a reed switch and magnet internally. You can actually get reflective BLACK exterior grade self adhesive vinyl, you know ?
Andy G. Stan
Andy G. Stan
Initial Alternator stator rewind test results are in after i finally got the thing together .
Heres the initial test results .
Cut in speed was at 2000RPM -DIRECT DRIVE ie. one to one from the test bed motor Going on pulley side thats about 800RPM engine speed.
Putting a massive load on it at 2000RPM ( Tickover-ish ) produced the following
Direct drive on load 18.74A at 53.8˚C and 17.66A at 58.5˚C
Which means it will produce 18A on tick over alone
At 2500RPM DIRECT DRIVE it produced 32.00A at 53.8˚C and 30.00A at 63.00˚C.
Which means it will produce 32A at roughly 1100 RPM.
I never got any hotter than this 63˚C which is good .
It maxed out at 4000RPM ( DIRECT DRIVE ) producing 47A - Thereafter ragging the hell out of it produced no more .
So it would appear is produces a lot of Amps very early and peaks out much sooner .
This peaking out shouldnt make any real difference as I know the Vusky uses less than 40A with everything on , the high output very early on should be great for stop - start traffic with lights / heater fan / indicators on etc etc .
Wont be fitting it yet as i want to run more tests but it seems OK so far.
- Been thanked: 100 times
Re: Nods news - Stator rewind results
Are you thinking of making a few up to sell if its successful, or mod those owners already have if they would like it done or is it just a one off exercise on your part to see what can be done if you know how to do it?
Well I bit the bullet today and fitted it and what a difference it makes too .
I used to get strange things like the heater fan speed vary in sync with the indicators whilst sat stationary as the alternator struggled to cope at low revs - this evening i tried leaving it ticking over - main beam on - heater fan on and finally hazards .
When the hazards were operated the heater fan didnt vary at all and remained a constant speed , nothing dimmed and the Hazard flash rate was normal - engine revs dropped 200RPM but thats to be expected .
So all in all a resounding success
Re: Nods news - Stator rewind results = SUCCESS .
Did you have to beef up your wiring for it, or plenty in reserve still?
Good work, Dave!
Good idea, but servo motors controlling the throttle and choke were once the cause of cars being so unreliable, they would have a mind of their own and your car would suddenly accelerate away even though you werent touching the accelerator, i remember driving a Montego, remember them? And it took off at 3000 rpm wheels spinning, no engine control at all, that was due to mechanical servo motors up the creek so to speak, the more you fit the more there is to go wrong springs to mind.?
- Been thanked: 202 times
it was a joke comment to be honest Peter based on noddy liking to fiddle with his car.
Yer tis fitted - the extra earth lead is just a precaution - adjusting strap is damped with a rubber bush so no connection and the main mount gets covered in oil and other crap which may or may not effect it
MOT on both cars run out in 3 days - guess who forgot to do a thing about this
Re: Nods news - Brain fade !!!!!!!!!!!!!!!!
I should get to the doctors pretty quick for your MOT Dave (while you're on a roll)
Re: Nods news - Ten years ago this Friday
Ten years ago this Friday coming ( 15th April ) at 4.55PM I joined this forum for the very first time
Over 6000 posts and probably way too much time spent on here.
I hope youve got some enjoyment or info from this lot as ive nearly killed my typing finger posting it all up.
Re: Nods news - Ten years ago this Friday ( 15th )
I enjoy reading all what youre doing as it gives me ideas and inspiration and good to see what others do and different ways to solve a problem, and besides if you werent here typing 6000 posts you would be under the Singer, no good for a bad back, or decorating the house probably, no good for the legs and neck?
Best you change fingers for the next 6,000 Dave. If you include your thumbs that's another 54,000 posts before you return to the first one. Should be enough time to rest it.
You lose 200 rpm because of the extra effort on idle so i suppose you must lose a very small degree of performance,
Wasnt it Newton who said you cant get more out without putting more in? Or was that due to the apple hit him on the head?
Yeah. Keep the posts coming, Dave.
Great news on the MOTs! Not unexpected, though.
From an old metal cover for a capacitor on a mains motor , an imp door glass stop and the brush cover band from an old starter plus a bulb holder and a red lens Ive knocked up an experimental high level brake light that looks more period - strange idea seeing as they werent invented then but hay ho im weird like that
- Lars Hagermark
As always, attention to detail.Dave ' Linwood ' Lane wrote:... high level brake light that looks more period - strange idea seeing as they weren't invented then but hay ho I'm weird like that
Re: Nods news - Period style high level brake light experime
You can still see if the brake lights work
What style of rear window seal are you using? Is it one of Malcs lippy latest ones? Thats what im trying, seems a lot better than i had on my 75 Sport, looks as though it will have a better job of keeping the water out anyway.
Just wondered if yours was his latest? If so hows it working?
Be interesting to see if this works then, the frames original and excellent, no twist and hasnt been sprained at the hinges, the seal has fitted that and the body really good so far, i mean it looks as if it will work well..
Just waiting for the stainless screws to come then on it can go and give Andys stays a test too
I have had to extend the screen latch, only a fraction, in the past to get the window to shut before without slamming and that was with the late factory seals, they werent ideal either.
Ten years ago today at this very time and date I signed on here for the very first time . Although it was a Saturday then.
Where did the time go
Re: Nods news - Ten years are up ( exactly )
And it must have been 36 years ago about this time I joined the IMP CLUB too, now thats a triple wheres the time gone.
And my old Sport was 41 a couple of weeks ago and my Chamois 50, all figures that are far too high for comfort, in fact its best not to think about it really??
As the foam grey is finally dry it was time to finish off that third brake light properly with added black and stainless to match the rest of the car
- Lars Hagermark
Will be 13 years for me this coming December the 5th.
Clip on aerial has moved from the front passenger window to the rear passenger window so Annie can wind the window down
Your Chamois looks really good in those photos, Dave!
- pbergs
- Car Model: stilletto
Since you are all old lags and I'm a relatively new boy I think it's worth a mention that I have had nothing but good experiences in this club. I think we are all happy to see imps running and I have been helped out of trouble a few times by members giving time,advice and spare parts just for the love of the cars. Thank you.
From the archives .
Anyone who fits a 3 inch Bilge blower to replace the wheezy Smiths effort might like to copy the way i sealed the inlet end.
Just get another Imp fan case and cut off the outlet just as it bends to its full diameter - this way it wont fall in - the inner edge of it where it touches the bilge fan is a tiny bit too small so dressing it back with a flap wheel sorts that out .
The four small bent in parts are to help get it out should you need to.
Once the fan is fitted it wont go anywhere.
PS I sprayed it in red to use up an old can of paint
- Lars Hagermark
Re: Nods news - Im a small fan.
This came very well timed as I've just ordered a Bilge blower.
How many mods have I copied from you now, I wonder?
- Lars Hagermark
Well the aerial move has been a great success .
Not only can Annie now use the passenger window but the reception is much better as well .
I did shorten the aerial where it screws into its window mount so its closer to the gutter by 20mm , thread was 2BA
- Car Model: to be purchased
Re: Nods news - Aerial move a success
Hi Dave Glad aerial move was a success - enjoyed your pictorial memories .Thanks for your support
- Lars Hagermark
Re: Nods news - heater fan grill
So the Singers plastic heater fan grill gave up yonks ago , i had a bit of large mesh in its place but tother day a soggy leaf got in - i thought the fan had borked itself such was the noise LOL .
So not having another one I had to think laterally .
Rummaging at work an old 60s fan guard for an electric motor was found that looked like it might work,
A bit of cutting / grinding / flattening and painting later its done.
i used the edge of the old plastic grill as a seal
- Lars Hagermark
Re: Nods news - Heater fan grill bodgimication
To try and get the Singer Mojo back ive sorted the one thing thats annoyed me on it - the OSF arch was repaired before i got it and was never correct IMHO - No idea who did it though .
Rust was starting to come through But considering it was pre 87 its done well ---
so it was time to grind grind - chop chop etc etc
Unlike African Imp who is allowed to bondo / epoxy his car back together over here its a welding job.
weldings not very neat as i was scared of doing a proper run due to the amount of waxoil in it - didnt fancy another fire if im honest , every short run resulted in a drip of waxoil - scary stuff .
Ran out of time to finish the job properly paint wise but this will do for a few weeks til ive some time off
Re: Nods news - Shock news 24 , Singer has rust - now gone
Theres even more risk if youre trying to gas weld it though, you need a fire watcher with extinguisher at the ready ideally, still the job doesnt look half bad, not easy when you cant get the car right up to working height.
- Lars Hagermark
Well done! Hope Singer Mojo was repaired too.
cheers all , Heres a side view of the repair
- Lars Hagermark
Repair? Can hardly be seen even though I zoomed in. Nice job.
Re: Nods news - Oil leak solved.
Cheers Lars - its quite good a repair considering i made the bits myself - took three hours to make and weld on plus the filling / painting bit .
One thing ive finally solved was an oil leak - its been quite oily around the filter housing although it proved difficult to trace .
Finally yesterday after getting back i found the little bleeder .
It was in fact the long oil cooler pipe , not where it screws on but where the fitting is crimped onto the pipe - oil was getting past the crimped area and running down the pipe to the oil filter housing where it spread everywhere.
So today i blew a wadge of dosh and had two pipes made locally by a company ive used before and have been trading 40 odd years .
Made whilst I waited - it took 1/4 hour.
Fittings are O ring sealed as well which must be better that just a taper seal - They will take way more pressure than can ever be crated by the engine.but were not cheap
Re: Nods news - Singer oil leak finally solved
Proper job, Dave!
- Lars Hagermark
Reminds me about the oil cooler hoses on the Cali. They've been stored for 40 years so should be changed asap. Stored with oil in them so perhaps fine inside but despite there aren't any visible external signs of drying or splitting it would be stupid to trust them now.
Engine cleaned of oily goo so i can see what leaks in the future
Very tidy. Jif and a toothbrush ?
- Lars Hagermark
^^^Add a spoonful of patience and the recipe is complete I assume?
