Nods news , Sometimes its the little things .
Re: Nods news , Bit of a service
Post by African Imp » Sun Jul 21, 2019 9:06 am
Dave ' Linwood ' Lane wrote:
African Imp wrote:Dave, Thanks, I think I have the grasp of what your talking about? :)
Can you tell me why the Aerogen 4 wind generator stator that I have is 24 volt and not the 12 volt that I required at the time?
Windings or wire numbers? etc etc.
stator is the output , the rotor controls the voltage so winding that would do nothing to the volts , the rotor would need changing to get the 12V you want.
So stator = output
Rotor or armature = voltage
Rectifier converts the AC generated in to DC using diodes
Regulator controls the volts produced by the rotor / armature
Dave, in my case the rotor was not changed, the stator was which is why I have a spare one and which was giving a 24 volt output,
The rectifier was one of those small square ones with the 4 terminals on it.
Post by Dave ' Linwood ' Lane » Sun Jul 21, 2019 9:09 am
Normally changing the stator wont change the voltage at all
Post by Dave ' Linwood ' Lane » Sun Jul 21, 2019 3:24 pm
Having just fitted and adjusted a NOS set of rear shoes on the Singer ive had in the loft at least 10 years ive just noticed they are Asbestos free :roll:
Probably wouldnt stop a stationary bicycle however they are on so we will see - or die trying :(
Post by African Imp » Tue Jul 30, 2019 5:09 pm
Dave ' Linwood ' Lane wrote:Having just fitted and adjusted a NOS set of rear shoes on the Singer ive had in the loft at least 10 years ive just noticed they are Asbestos free :roll:
I still have some Ferodo VG95 linings here
Re: Nods news , two engine lid stays
Post by Dave ' Linwood ' Lane » Wed Jul 31, 2019 6:38 pm
Been planning this for months and today I finally sorted the double engine lid stays . they only ever had one on the left which isnt up to much really .I made the bottom part of the drivers side from scratch in the end as the factory L/H one was handed completely wrong , just like the mountings for the spring part which i also had to make .
Works perfectly and should now be a bit more wind proof :D
Re: Nods news , Two engine lid stays .
Post by johnh875 » Thu Aug 01, 2019 2:38 am
Nice work!
Post by Dave ' Linwood ' Lane » Wed Aug 07, 2019 5:16 pm
Rear shoes just arnt cutting it , think il hunt some NOS ones down with added nastiness :roll:
Post by 617sqn » Wed Aug 07, 2019 5:30 pm
Ask Moose....?
Post by bazzateer » Wed Aug 07, 2019 7:42 pm
Moose's shoes are superb BUT you abzolutely MUST following his bedding in instructions or they will disappoint.
Post by 617sqn » Wed Aug 07, 2019 9:13 pm
I'm sure Dave can follow the bedding in procedure. Had a great chat with Mike Dent at National. An interesting and clever geezer.
Post by The Nun » Thu Aug 08, 2019 8:03 am
Dave ' Linwood ' Lane wrote:Rear shoes just arnt cutting it , think il hunt some NOS ones down with added nastiness :roll:
You mean thats As.best.os you can do now? :shock:
Post by Dave ' Linwood ' Lane » Fri Aug 09, 2019 7:24 pm
:lol: :lol: . think il get hold of Moose :)
Post by Dave ' Linwood ' Lane » Tue Aug 20, 2019 5:54 pm
Picture posting test
Post by 617sqn » Tue Aug 20, 2019 6:30 pm
Yep. It's a picture you've posted !
Post by Bobbycham » Wed Aug 21, 2019 2:31 pm
Should have been , It's a lovely picture you've posted. :wink:
Post by 617sqn » Wed Aug 21, 2019 2:37 pm
OK, OK. It's a picture of a lovely Singer.
How's that ? :wink:
Post by The Nun » Wed Aug 21, 2019 3:52 pm
Who's is it? :lol:
Post by 617sqn » Wed Aug 21, 2019 5:23 pm
Katherine Jenkins ?
Post by Dave ' Linwood ' Lane » Mon Aug 26, 2019 7:26 pm
Today was inadvertently a cooling test day .
26˚c Ambient temp , 18 miles of constant driving , some around 40mph to 60mph and ten at a constant 70mph ( 74 on the speedo ) - heater off obviously .
Max temp achieved according to my infra red thing was 84˚C with the gauge showing a fraction past the middle.
Oil pressure at this speed and temp was 47 psi - on tickover it was 23 psi , coolant expansion in the bottle - just over an inch .
Temp after 5 minutes of being turned off 74˚C
Recon thats OK for a rear rad only set up with the heater off in this weather :)
Re: Nods news , Newness buffers
Post by Dave ' Linwood ' Lane » Sat Aug 31, 2019 2:40 pm
So for as long as I can remember the Singers engine lid has had a slight rattle . This seemed to be caused by the passenger side top buffer not even touching the engine lid added to which the mounting bits on both were knackered so the were loose anyway .
A year or so ago i got some rubber feet off a scrapped generator at work , exactly the same height but a larger diameter which therefor would mean a bigger hole in the car - meaning i put it off.
Anyway today i bit the bullet and fitted them plus i used the original ones but with the mounts cut off and bonded to the lid .
Pics tell the story .
No more rattle :D :D :D
old buffers plus one of the new ones
same height only bigger diameter
Original size of hole - you can see the skins dont even touch letting in water - a quick hammering sorted this out
drivers side original hole - must do that scratch !!!
Hole now bigger ready for new buffer
cut off mount off old buffer , cover base in glue and balance here
Close lid for 5 minutes then opening results in this
Tippex on the new one only then closing ---
---- proves they line up
And voila all done
Re: Nods news , Engine lid buffers .
Post by 617sqn » Sat Aug 31, 2019 4:04 pm
Nice job, Dave. I like the tippex idea - must get some. Does it make shutting the lid much harder ?
Andy G. Image Stan
Post by Dave ' Linwood ' Lane » Sat Aug 31, 2019 4:16 pm
Andy G. Image Stan
No difference whatsoever , it just no longer rattles :D
Post by The Nun » Sat Aug 31, 2019 5:45 pm
It's the bottom edge buffer arrangement that poorly designed too, the buffers abutt onto the engine lid flange which has no reinforcement behind it in that area meaning over time or if the lid is dropped shut or close by a ham fisted person it bends the flange on the lid and cracks the paint, a doubling up of thickness there, or a small piece of angled steel flat on the inner edge would help no end?
Post by Dave ' Linwood ' Lane » Tue Oct 29, 2019 7:51 pm
Just in case your wondering why the updates just stopped .
A post to say i still have this although apart from fitting a full set of Mike Dents brake shoes ive done nothing to it .
I used it last Sunday and it ran fine , even put the heater back on - first time since April and thats working well ,
Im not sure it likes sitting for weeks on end doing nothing but as theres other stuff that needed doing around the house as well as doing work on my new toy :D as a result its been its been sadly neglected .
Still it did get washed on Sunday so at least something got done :lol:
Re: Nods news , Busy doing nothing ( working the whole day through )
Post by bazzateer » Wed Oct 30, 2019 11:35 am
New toy Dave?
Post by Dave ' Linwood ' Lane » Wed Oct 30, 2019 5:04 pm
New toy Dave?
Not an Imp , my new daily - an 06 C180K Merc
Post by bazzateer » Thu Oct 31, 2019 8:42 am
It's not the car that costs, it's paying for the chauffeur!
Post by colimp66 » Thu Oct 31, 2019 9:22 am
Nice 8)
Post by The Nun » Thu Oct 31, 2019 4:18 pm
Did you have the indicator option retrofitted? :lol:
Post by Dave ' Linwood ' Lane » Thu Oct 31, 2019 4:31 pm
Its a Merc not a BMW :roll:
Post by bazzateer » Fri Nov 01, 2019 11:53 am
That's the responsibility of the chauffeur :wink:
Post by Dave ' Linwood ' Lane » Sat Nov 02, 2019 5:10 pm
Sometimes its the little things :)
Picked up four meters of door pocket edging today , exactly as factory :) - now all fitted on both cars , mine were split - in bits or falling off .
Not anymore :D :D
Pic is of half of it as id already done the Vuskys :)
Re: Nods news , Sometimes its the little things .
Post by bazzateer » Sat Nov 02, 2019 11:42 pm
Pics of it fitted?
Post by Lotus-e-Clan » Mon Nov 18, 2019 6:46 pm
Bit late - but I just noticed your nice new C Class Merc! 8)
These are a bargain atm. My son recently bought an E Class Estate for little money. They are FAB cars - he loves it!
Some years ago I got hold of a "Star Machine" so I could properly diagnose and service the wife's SMART Roadster. The "STAR machine" has diagnostics for ALL Mercs (and Mitsubishi) including all SMART, Merc Buses and Merc trucks ..and of course the E Class is on there too. The fact I already had a Star Machine influenced his decision to buy a Merc.
We looked at a few E Class before buying the best of the bunch ...he bought the one with no serious faults pending (unfortunately nearly all have some). The sellers (none were Merc Specialists) agreed to let us plug the STAR into the diagnostics port prior to a test drive- which benefited them too because they had no idea about what faults might be on their cars. Usually a diagnostic-only session would cost £100 at a Main Dealer - so the sellers saved a bit of money by allowing us to 'plug-in' before buying. One E class estate we looked at in Leeds had a list of faults as long as your arm!
Fortunately, the E Class my son did buy had just had a new Sensotronic Brake Control (SBC) unit fitted. Apparently, according to a Merc Specialist near us, the SBC unit is designed to FAIL after a set number of brake pedal presses (outrageous! :shock: ). I think there has been a recall on this fault? We had no idea about the SBC "design fault" at the time we bought the car - we were just lucky it had just been replaced. I don't know if the C class has the SBC - but I could find out by looking it up on the Star / EPC.
Also to bleed the brakes properly with an SBC fitted (every 2 years) you should do it with the Star Machine connected. The Star remotely operates valves in the SBC in order to systematically build pressure for a proper flush and bleed. Having the Star Machine is a bonus for any DIY Merc owner...otherwise you have to use a Merc Specialist sooner of later. Not an issue if that's what you set out to do, of course :) .
Hope you have bought a good one Dave - they are very nice cars. But just like a lot of moderns they are both blessed and cursed by the presence of computerised electronic control systems
Post by Dave ' Linwood ' Lane » Mon Nov 18, 2019 9:20 pm
No SBC on this one , i changed the fluid tother week . star showed up two faults , alarm module and crank sensor , both now sorted , it runs fine but the clock gave up recently and although ive tried every trick i know it refuses to work , still if thats the only fault il live with it
Post by Lotus-e-Clan » Mon Nov 18, 2019 9:50 pm
That's good. 8)
After I posted I learned, tonight on Wiki, that the SBC was dropped in 2006 and they weren't fitted to most C class anyway so you will have never had this problem - it was a Merc /Bosch design -they got an award for the SBC design apparently (before it was properly rolled out!). :)
Post by Dave ' Linwood ' Lane » Wed Nov 20, 2019 10:10 pm
Time will tell if its a good buy or not , early W203s suffered badly from rust , mines a facelift ( 2004 on ) so fully galvanised , your right though its the computer problems that will kill these off way before anything , im hoping the clock isnt the start of bad things
