Nods news , Styling exercise part 3
Re: Nods news , " In tank fuel filter " from bobbycham fitte
Hey I like that! 8)
When / where are they for sale?
Lotus-e-Clan wrote:Hey I like that! 8)
I believe thats the plan bobbychamp has in mind , im just testing its OK - as I did with Mike Dents ignition system - im Mr Guinea Pig :lol:
Re: Nods news ," In tank fuel filter " from bobbycham fitted
Ah! I see.
S'pose the fuel will run out a tad early given the shoulder on the magnet ..need to test for that obviously! :)
Lotus-e-Clan wrote:Ah! I see.
I think it will run out before it runs out but not by much , without chopping a tank up or measuring it its tricky to tell
Simply put: - What I would do is to see if the car stops with the fuel gauge still showing fuel. If that happens then a tech note should be included with each filter device to explain that fuel will run out and the car will stop before the gauge shows empty. Clan004
John Ross has one fitted and the tanks coming out tomorrow , hes going to try and measure the difference - TBH if the fuel got that low youd probably stop going up a hill :lol:
Dave ' Linwood ' Lane wrote:John Ross has one fitted and the tanks coming out tomorrow , hes going to try and measure the difference - TBH if the fuel got that low youd probably stop going up a hill :lol:
Good point. But proper testing uphill and down Dale will put minds at rest! :) Clan004
Re: Nods news , Back to the gauge pipe
Having changed the oil pressure gauge pipe block fitting and re-routed the gauge pipe is was pointed out the clips " could " wear through the pipe in time so this morning ive sorted this out ,
The original bottom clip was too small ( still no idea what it was for ) so ive replaced it with a slightly larger one then sleeved the pipe where the clips hold it .
Also did the three tabs that hold the wiring in place .
In case you wish to do the same I used the rubber sleeves removed from single bullet connectors slit length wise for the oil pipe and the double ones ( i just slid the rubber sleeve off ) for the tabs :)
Re: Nods news , Back to the oil gauge pipe .
Thing is they didnt seem to bother about it might wear away on the original installation, as that was just held using the loom securing tabs to hold it in place, and it never seemed to wear away, just went brittle with time and then broke off at the engine connection.
The Nun wrote:Thing is they didnt seem to bother about it might wear away on the original installation, as that was just held using the loom securing tabs to hold it in place, and it never seemed to wear away, just went brittle with time and then broke off at the engine connection.
All that flexing with engine movement i suspect , hence me doing this latest mod
In other news the Singers running perfectly and having done 40 odd miles the new angled gauge fitting appears to be leak free . :D
Thats about it Singer wise for this year although i will of course carry on using it as often as possible .
If anything does get changed / altered / modded / broken il post it on here as usual .
And of course il report on anything re. the new tank filter and Mikes ignition system .
Have a pic from Yesterdays trip out to the Bristol classic car show, :)
Dave, I just caught up on your wonderful thread. Keep up the brilliant work! Your cars are an inspiration! :mrgreen:
Dave I fitted a new pipe and took the feed from that large center fitting in the side of the block. I used a number of sections of shrink tube around the exit union to support the plastic pipe, then took it towards the coil and then up and into the wire loom that crosses the top of the engine bay, then into the side panel and on to the dash, its worked out fine :D
I think the reason it broke eventually, OK it was brittleness but the pipe coming straight out rather than at 90 degrees it can get in the way sometimes when plug changing, clutch bleeding etc its easy to catch it or snag it as you work which can't help matters
The Clan's oil pressure pipe seems to be bomb proof.
Same material as the fuel pipe - a very tough thin-walled black plastic tube.
Mine are well-over 40 years old and showing no signs of degradation....but don't tell David Attenborough! :shock:
Lotus-e-Clan wrote: The Clan's oil pressure pipe seems to be bomb proof.
Mines been changed although that was 20 odd years ago , fractured on the joint where the bend is / was , i guess the added expense of a 90˚ bend was just too much for Rootes ,
Dave, my 1967 Singer Chamois had the oil pipe take off on the opposite side to the picture just posted, so below the oil filler neck, but on the block, not the cylinder head. I assume that was as the factory fitted them? it never gave any bothers and it was still there when I sold the car in January 2015.
If you mean the oil pressure gauge is taken off the PUMP oil gallery (above picture) which is located PRE-filter, then the readings will be up to 7psi higher when hot (and 14 psi higher when cold) compared to a take off from a gallery which is located post-filter (like the centre main bearing or head gallery take off).
In other words there is typically a (hot) pressure drop of 7 psi across a modern cartridge filter using 20w/50 oil (probably less with the larger pore original filters in above picture).
The preset oil pressure relief value needs to be accounted for when assessing max pressure - but not idle pressure obviously.
If you wanted to fool a purchaser that the hot idle oil pressure is healthier than it really is, then you might use a pre-filter take-off point ...
Lotus-e-Clan wrote:Image
Obviously the preset oil pressure relief value needs to be accounted for when assessing max pressure - but not idle pressure obviously.
Yes, that is where the take of was and I assume may still be, as I sold the car three plus years back.
Where di Rootes take the supply from on a Singer Chamois normally?
The 1967 Imp Californian has the take off for the oil pressure gauge on the center of the block, it goes from there up and around the coil and then along the wire loom on the top of the engine panel.
I have removed the vacuum pipe from the distributor to improve the picture.
Bought some new check strap stuff from ebay , 1 1/4 X 4mm Balata strap .
Really strong stuff - well happy :D
Last edited by Dave ' Linwood ' Lane on Fri Nov 16, 2018 6:14 pm, edited 1 time in total.
Re: Nods news , New check straps fitted+tank filter update
And now back to the in tank filter I fitted from Bobbycham .
There has been a few comments and worries on wether the extra height of the magnet and filter means you run out before you actually run out if that makes sense .
Some testing has been done and the difference in useable fuel is less than 1/2 a litre , in other words you will run out less than 1/2 litre sooner than normal and maybe loose a few miles total range .
Lets face it if your running that low you fully deserve to grind to an uncompromising stop anyway :lol:
Checking filter in and tank out the filter is covered with just a litre of fuel , mainly because the centre base of the tank is lower anyway .
Most gauges show empty with a few litres still in . It has too otherwise the float would hit the bottom of the tank and jam up and lets be honest they are hardly accurate down to a few millilitres :roll: .
Ive noticed no difference in fuel supply , my leccy pumps not working any harder or sounding stressed by the extra filter .
Its also been reported to me that another car that did have fuel issues whereby crap being held over tank exit pipe until vac released caused it to stop . Apparently none so far since fitting and a complete success in curing these fuel issues without having to pull a tank and blast/clean/coat it !
So is this worth it
Id say most certainly it is , it also keeps the main pipe clear which has caused numerous issues in the past on many Imps .
Basically its passed my and others testing and is recommended :D
Re: Nods news , New check straps fitted+ tank filter update
THANKS for testing the internal fuel tank filter Dave , all looks good , and has cured long standing fuel starvation problems on another Imp in testing .
I have a batch made now , l just need to tweak the instructions paperwork.
This is an item that is basically "fit and forget" and as far as l know hasn't been available for Imps before .
I will put ad in "for sale " section on forum and also in Impressions when l'm ready.
Should anyone need more information before l do that , feel free to contact me via PM or
mail me on bobpicton@outlook.com.
There are still a few windscreen washer replacement kits available ,should anyone be interested.
Thanks again Dave & others involved in testing .
Dave ' Linwood ' Lane wrote:Bought some new check strap stuff from ebay , 1 1/4 X 4mm Balata strap .
Dave, looks good.
I did a similar fit back in 1971/2 when I raced a Mk1 998cc race Imp here in Cape Town. The road springs were heated and compressed by 2'" all round, Van Zyls Spring Works did the work.
The check straps we never a source of worry and the car was fast and competitive in its class.
75 F at speed,Killarney.jpg (17.54 KiB) Viewed 129853 times
Bobbycham wrote:I will put ad in "for sale " section on forum and also in Impressions when l'm ready.
Excellent. Just send m an ad for the mag when you're ready.
I'll have one for sure, looks a no-brainer.
I'll have one too. ~1/2~ litre less fuel tank capacity within 27 litres total is no big deal. That last 1/2 litre will contain concentrated 'fines' that you don't want through your fuel pipe anyway!
After fitting the anti slosh valve in the filler neck for when I'm competing, I think I would have one of those filters too. (Any small fines / rust would stick to the magnet and be easy to remove too).
Let me know when you have a price for the kit.
Oli
Boring tiny Singer update number 27 .
As the washers and wipers are now interlinked a new switch label was needed
Instead of just screen washers ive gone for a symbol saying both :)
End of boring update :lol:
New tag with wash / wipe as a symbol
Old tag
Old tag
Re: Nods news , Tiny Boring update , new bit fitted.
The stainless strip on the parcel shelf is also an addition isnt it?
The Nun wrote:The stainless strip on the parcel shelf is also an addition isnt it?
Yep , someone had drilled a 4mm hole in it before i got the car , strip hides this well but did mean more holes - only smaller - looks OK I think :)
Never boring Dave. :D
Seeing those pic's (lovely) , isn't or shouldn't there be a particular side that number plates are fitted when not central to vehicle.
Not being finicky am l?
I like and may copy your stainless steel strip on my Californian and on the same side. Imp027
Well the Singer is 19,721 days old - or 54 years if you want to make it easier and is now the same as me for a short time
Im sure the shell was built and painted weeks or maybe months before as the body number is well over 1000 higher than the chassis number so its really just an assembly day and the day it actually came a whole car .
The odds of any car surviving this long is slim let alone still having its original sills and arches and a fair bit of original paint .
:o
Re: Nods news , Singers getting older.
Don't remember that scene in Ice Cold in Alex, or Carry On Cleopatra. :lol:
Bobbycham wrote:Don't remember that scene in Ice Cold in Alex, or Carry On Cleopatra. :lol:
Wrong continent! Going by the angle and direction of the sun it's clearly the Atacama desert. :wink:
Don't forget Weston Super Mares just a stones throw away, but can't see any mud ,so doubt it's there!
The first picture shows you could have jet washed your drive Dave , not just the car. :lol:
Post by tiker »
Hi Dave cars still looking great better with age , I was wondering about the body number should all cars have one or was it just early ones mines a 68 and couldn't find a number where is it supposed to be?
My fave shot at the same location
tiker wrote:Hi Dave cars still looking great better with age , I was wondering about the body number should all cars have one or was it just early ones mines a 68 and couldn't find a number where is it supposed to be?
Its on the front panel , R/H side on the upright where the wing meets the front , il get a pic later for you.
