Nods news , Time for reflection plus year end report .
BKasl
Car Model: Imp Deluxe
Re: Nods news, Bonnets back from respray , pics of the proce
Post by BKasl » Fri Aug 12, 2016 7:19 pm
The 12 " wheel you are using for a spare, is that useable with 13" wheels on the car? Wont it make a rotation difference primarily on the rear for possible damage?
Post by Dave ' Linwood ' Lane » Sat Aug 13, 2016 6:55 pm
BKasl wrote:The 12 " wheel you are using for a spare, is that useable with 13" wheels on the car? Wont it make a rotation difference primarily on the rear for possible damage?
Should be fine - rolling radius for a 155 / 80 / 12 matches my 185 / 60 / 13s more or less exactly - diff should be able to deal with the -1% difference
155 / 80 / 12 rolling radius is 21.76mm
185 / 60 / 13 rolling radius is 21.74mm
Difference in Diameter: percentage = -0.18% actual = -1mm
Re: Nods news, Rear window seal - a new discovery
Post by Dave ' Linwood ' Lane » Tue Aug 16, 2016 2:22 pm
Well the factory window frame seal on the Singer has finally given up
Good news --- Ive got a NOS genuine one as a spare
Confusing news -- profile on the new one is different :?
Which must mean there were different versions of window frame seal - who knew :o :D
Anyway it had to be worth trying as the old one was leaking a tad .
New one fitted superbly and sits how i remember genuine ones fitting - ie. curled towards the frames outer face.
Window shuts fine - in fact better as ive had to adjust the catch so it closes tighter and the new seal is leak proof between it and the frame seal however the frame seal to car window aperture does leak a tiny bit under heavy hosing .
I think its Best to check this properly next time it rains as a hose is no substitute for actual rain.
Il let the pics do the talking
The old cracked seal - you can see how it sticks out which is different to the new one
New seal profile on the left which is way different to tother one
How the new seal fits
Initial leak test in progress
Shuts OK
Re: Nods news, Rear window frame seal- a new discovery to m
Post by Dave ' Linwood ' Lane » Tue Aug 16, 2016 2:31 pm
Close up of that new seal and how it sits
Malcolm Anderson has informed me this seal is a 63 - 65 early type :)
Post by Dave ' Linwood ' Lane » Sat Aug 20, 2016 6:28 pm
This will teach me to wash the Vusky :(
I found a hole :(
Henceforth a mini weldathon starts.
Paint match is so bad it might as well be feckin red as blue. LOL .
I will call this " The why the feck did I even bother starting " job .
A hole
A bigger hole
inner wing extended
kind of fits
Welded up - wing was made off cheese i think
Wob added
paint match was perfectamundo ( NOT )
Re: Nods news, Vusky sprouts a hole
Post by bazzateer » Sat Aug 20, 2016 9:35 pm
The paint will protect it until you give the Vusky the respray it deserves :wink:
Post by ImpManiac » Sat Aug 20, 2016 10:00 pm
Well spotted, Dave. :)
Post by Dave ' Linwood ' Lane » Sun Aug 21, 2016 6:04 pm
I have done a paint job on my welded in repair that Clark Dawson would ---------------------- cry over as being totally crap. :)
However needs must , paint match in my rattle can was totally wrong " but " its spot on in my old touch up tin ,
So
Brush paint a load on
Leave to dry off
Wet and dry the life out of it
T cut to get a sort of decent finish and
Voila - i give you my most bodged paint job EVA --LOL
The " Rattle can / wrong colour spray " job
The " brush paint / sand off / T-Cut paint job
Post by Lotus-e-Clan » Sun Aug 21, 2016 6:07 pm
Not too shabby, Dave ... 8) Clan004
Post by Lars Hagermark » Sun Aug 21, 2016 6:49 pm
Post by Lotus-e-Clan » Sun Aug 21, 2016 6:56 pm
I like your Avatar Lars!
Very noble and handsome...
Post by Lars Hagermark » Mon Aug 22, 2016 5:02 am
Thanks L-e-C.
Had the idea to change my avatar when I read:
617sqn wrote:Wouldn't it be nice if all of the ar$ebook images were seen on the Forum ? Dreaming I guess, but I live in hope.
Andy G. Image Stan
Same avatar as I have on FB. Don't think it was avatar pics Andy had in mind though. :)
Re: Nods news, Just a piccy
Post by Dave ' Linwood ' Lane » Thu Aug 25, 2016 5:11 pm
Not much to report but i did get a few sunset photo,s the other night im quite chuffed with :D
Sunset in Somerset
Re: Nods news, Actually no news - Just two piccys
Post by Lars Hagermark » Thu Aug 25, 2016 6:03 pm
Nice! Looks very much like Aruba sunset. Didn't see any Imps there though.
Re: Nods news, Rust fixorage on the Singer
Post by Dave ' Linwood ' Lane » Sun Aug 28, 2016 4:13 pm
So this poxy bit of rust on the singer proved to be an arse - mainly as the things full of waxoil which = Fire .
Welding was knervwracking and slow because of this even after id shoved some damp flannels down where i was welding there was smoke and the potential for a disaster .
Consequently the welding aint pretty but it will have to do
flange has kind of rotted away
chop chop
inners very solid
New flange welded in
Trial fit of outer panel
start to weld in
Finish welding - add Wob
seam sealed and trimmed up
bit more done
As it stands now - more work needed though the heartstopping stuff is done
Last edited by Dave ' Linwood ' Lane on Sun Aug 28, 2016 4:45 pm, edited 1 time in total.
Re: Nods news, Yet more welding - this time the Singer
Post by The Nun » Sun Aug 28, 2016 4:38 pm
Looks quite professional, Ive seen so called garage repair specialists work not come out as good as that and youve retained the correct look and profiles too, a job well done I think.
Had the waxoyl actually gotten behind that bit, I know the inner wing and outer can touch at that point which is why it corrodes as the anti rust cannot penetrate behind?
Post by Dave ' Linwood ' Lane » Sun Aug 28, 2016 4:48 pm
The Nun wrote:Looks quite professional, Ive seen so called garage repair specialists work not come out as good as that and youve retained the correct look and profiles too, a job well done I think.
That feels good coming from you - waxoil was everywhere except between the inner and outer arches between that flange - so thats where it went - still inner was solid - no rot on the outer bit either except for that flange
Post by The Nun » Sun Aug 28, 2016 5:13 pm
Thats one problem when youve got an original car and its looks ok but whats behind around the seams you dont know and you think youve anti rusted it but of course it doesnt get right into where its most needed half the time, I found that out when I re paneled my Sport, that had been Ziebarted from new and everywhere that stuff had got too was like brand new perfect, but it never got into where the inner and outer arches touch simply because it couldnt get into there, Rootes/Chrysler seemed to put some sort of caulking between in that area which doesnt help one bit of course.
Ive rust proofed my Chamois best I can with hot waxoyl poured and sprayed in, but you always wonder if its got in all those spots, which I doubt?
Post by oli » Sun Aug 28, 2016 10:28 pm
Peter - if you want to try to get something between the arch lips where they are spot welded together - try pouring in (or very liberally spraying) lots of WD40 onto the inside of the outer wing panel so that it runs down and penetrates between the two skins.
Post by 617sqn » Mon Aug 29, 2016 1:29 pm
Well, a reasonable suggestion, except long term WD40 is merely a film, and wont prevent the sort of corrosion we are talking about here. But taking the method on board, perhaps the biker/aircraftsmans friend would be a good option ? ACF50.
http://www.acf-50.co.uk/acf-50.htm
Andy G. Image Stan
Post by Dave ' Linwood ' Lane » Mon Aug 29, 2016 5:05 pm
A quick one coat spray of top coat on the Singers repair just to see what it looks like.
At least its all solid metal and not rust / chicken wire / bondo .
Needs more work but the basic shapes good i think - Inner part still to do but the primers just been put on so not till later in the week .
A few more days on axle stands before its done :(
Post by The Nun » Mon Aug 29, 2016 5:37 pm
Dave ' Linwood ' Lane wrote:A quick one coat spray of top coat on the Singers repair just to see what it looks like.
Looks a good match 8)
My friends 76 Caledonian sill was mostly found to be a Cherry Red/Leicester Mercury combo, still I suppose it could have been worse they could have used The Sun. :lol:
Post by Dave ' Linwood ' Lane » Tue Aug 30, 2016 7:14 pm
The best i can do on this repair .
Ive run out of time , will , enthusiasm , paint and money .
Needs cutting back at some point .
At least its solid and not built using chicken wire , wob , epoxy resin , newspaper , papier mache and metal filings LOL :)
Post by The Nun » Tue Aug 30, 2016 8:47 pm
I don't think the uniformed would know anything has been touched so that's the main thing, it looks right.
Post by 617sqn » Tue Aug 30, 2016 8:55 pm
Uniformed ? Do you mean our Baz ? :lol:
Post by The Nun » Tue Aug 30, 2016 9:02 pm
Oh heck it's those annoying predictives again changing all my worms :lol:
Post by 617sqn » Tue Aug 30, 2016 9:24 pm
:D
Post by The Nun » Wed Aug 31, 2016 9:29 am
oli wrote:Peter - if you want to try to get something between the arch lips where they are spot welded together - try pouring in (or very liberally spraying) lots of WD40 onto the inside of the outer wing panel so that it runs down and penetrates between the two skins.
I have put a thin rust inhibitor down in that area, but if it gets to the area only time will tell, its a bit of a guess as to whether it will or not? I suppose if the metal is still like new it stands more chance of penetrating than if the rust has already started, and on something 50 years old thats anyones guess when you cant actually see it, and I expect?? Noddy was surprised when he found his was rusting even though he too had poured in loads of rust proofer?
I know its to be best avoided at all cost wherever possible as original is best, but the fitting of new panels does come with the advantage you know whats behind and can treat and protect whats there properly whilst youre about it knowing its future proofed for many years to come?
Post by ImpManiac » Tue Sep 06, 2016 2:07 pm
617sqn wrote:Uniformed ? Do you mean our Baz ? :lol:
He's retired from that malarky. :wink:
Great work, Dave! :D To be honest, if you did not know there had been a repair to that area, it would be very difficult to spot it. It'll be more so when you've cut the paint back a bit too because it has that 'from the gun' shine at the moment. Well done!
Pog
Car Model: 1969 Super 'Betty'
Post by Pog » Wed Sep 07, 2016 2:59 pm
Well it's taken me a good 2 weeks of here and there reading, but I have finally finished all 115 of your wonderful thread, Dave!
You're a true inspiration to anyone wishing to look after any car, not just an Imp. I've never come across anyone with such a broad spectrum of technical skills under their hat - electrician, welder, seamster, painter, fabricator - simply incredible.
Your cars are a credit to you. I hope that one day I can park next to you in the masterclass line!
Pog
Post by Dave ' Linwood ' Lane » Wed Sep 07, 2016 4:48 pm
Pog wrote:Well it's taken me a good 2 weeks of here and there reading, but I have finally finished all 115 of your wonderful thread, Dave!
Pog
Why thanks Pog :D , apart from the welding its all self taught - if i can do it anyone can.
Glad you enjoyed it - ive not read a lot of it for years but its great someone else has got some inspiration from it all .
I just muck about fixing whats broken and altering things as and when - its just a hobby of mine .
This year was my last year in the masterclass but your welcome to park next to me in with the others anytime you want. :)
Re: Nods news, Just a photo
Post by Dave ' Linwood ' Lane » Sun Sep 11, 2016 4:50 pm
Arty shot from today - cars running rather well - touch wood etc etc etc . :)
Post by tiker » Sun Sep 11, 2016 8:04 pm
Hi Dave looking at the paint repair I would think your using cellulose I was wondering because I'm still in two minds to go cellulose are 2k as cellulose is so easy to repair later?
Post by Dave ' Linwood ' Lane » Sun Sep 11, 2016 9:23 pm
tiker wrote:Hi Dave looking at the paint repair I would think your using cellulose I was wondering because I'm still in two minds to go cellulose are 2k as cellulose is so easy to repair later?
I still prefer cely as its easier to rectify any boo boos , bonnets now 2 pack and mega shiny - too shiny for the age of the car IMHO
Post by The Nun » Mon Sep 12, 2016 3:36 am
Mine "was" done in celly and the boo boos were still there, hence the reason for me getting it all redone in modern without the boo boos. :lol: I can see if you want the original patina look then celly gives the flatter more lived in finish. :wink:
Post by Dave ' Linwood ' Lane » Sun Sep 18, 2016 3:44 pm
Couldnt resist this photo opportunity at Thornfalcon car show today .
Got there mega early just to park under a massive Oak tree
Bonkers mad or what :)
Re: Nods news, Just a photo ( with added tree )
Post by Bobbycham » Sun Sep 18, 2016 5:40 pm
Not to be done on a windy day!
Looks good Dave.
Imp005
Post by Dave ' Linwood ' Lane » Sun Sep 18, 2016 6:07 pm
Bobbycham wrote:Not to be done on a windy day!
Looks good Dave.
Imp005
Not a puff of wind today - had to go for it :) Singer looks super imposed in the last pic for some reason - rest assured its not :?
Post by Lars Hagermark » Sun Sep 18, 2016 6:29 pm
Dave ' Linwood ' Lane wrote:Singer looks super imposed in the last pic for some reason - rest assured its not :?
At first glance I thought so too. Nice pictures all four with the first being my favourite. :)
Post by Dave ' Linwood ' Lane » Sun Sep 18, 2016 7:08 pm
Thanks - last pic does look strange i must say - must be the sunrise and strange lighting
