Rubén’s on the Road, after 25 years
- Car Model: 02 07 63 Hartwell IMP
Back in 1983 I aquired a limelight green stiletto shell UHK 74K for a school project. It got built back into a car, resprayed red and brother Jon ran it for a while and then I bought My maroon Chamois CNA476C. This I restored with new panels and a full repaint and then learnt to drive in it.
I set up the heathrow area centre and handed it over to the cashmores when I moved away to university. On my first trip back, a couple turned up in a MK1 imp in skye blue which they were trying to sell the number plate off it for £550. I paid them this for the car.
The car was registed new on July 3rd 1963 by Hartwells of Bournmouth, as 5948RU and is the oldest surviving hartwell imp. It came with, but not fited a fabricated manifold for a twin choke weber 24 32 ddc off a citreon ds 19 The car otherwise was basicaly standard apart from extra instruments and a wood rim steering wheel.
Bodily the car was poor but i decided to restore it.
So far its had new inner / outer sills (no drain holes on mk1's)
It needed new floors, so I made the floor pan tool
All 4 wings and front panel still need to be fitted along with rear window inner / outer frames and rear engine bulkhead.
And of cause all new bolt on panels, correctly back dated to mk1.
Edit April 2016 Daughter is now 9, and my son is 6, and the car is still not finished
Kind regards and Happy Christmas
After a 8 hour respray prior to national in 1996
new sills
rear end cut away
new rear window frame
CNA476C in its current state
new sills
rear end cut away
Re: Jeff's Hartwell Imp *
Well 18 months has gone by, some of you may be wondering whats happened to this car. Well I now have 2 kids, and even less time, but the family are of on holiday without me in november so I will be able to start the assembly of the shell big time.
To sumerise, the list of parts I have for the shell are:-
Low sidelight Front Panel
Low sidelight LH Front chassis leg
Low sidelight RH Front chassis leg
Front floor
Boot lid
Front Scuttle
LH low sidelight front wing
RH low sidelight front wing
LH Inner outer and heater sills*
RH Inner outer and heater sills*
LH floor*
RH floor*
LH Door (Perfect used )
RH Door
LH Rear Wing
RH Rear wing
RH C post*
Inner rear window surround
Outer rear window surround
Rear shelf
Rear roof trim
RH Engine bay inner wing
LH Engine bay inner wing
Rear body crossmember
Engine lid
* indicates Fenn Lane panel
All in this is 19 nos rootes panels, + 9 of my repair panel + numerous repair pieces for the inner arches. I have a new set, but the car is not bad enough to need these.
Loads of photos will be added soon as the assembly commeces
Front floor
Boot lid
Front Scuttle
LH floor*
RH floor*
RH Door
LH Rear Wing
RH Rear wing
RH C post*
Rear shelf
Rear roof trim
Engine lid
- tim sears
Do you mean Naomi isn't staying at home to help ?
Good luck
Tim
Good luck
Tim
1963 deluxe
1965 deluxe Nessa's
1967 cali Demelza's
1967 cali Rosie's
1967 cali
1968 Husky
1973 Clan
1967 Sport
1970 Super
1968 Stiletto
1965 deluxe Nessa's
1967 cali Demelza's
1967 cali Rosie's
1967 cali
1968 Husky
1973 Clan
1967 Sport
1970 Super
1968 Stiletto
Some more pics from the strip down, I forgot it looked so awful, why did i bother!
As removed from the lockup in 2002
Found this shim in the rear suspension
Shell was lightly sandblasted
Supplied by Hartwells sticker, anyone make me a new one!
Hartwell's pug dealer has been bought out, so no issue of copywright, as I am replacing an existing sticker, for my car, and to anyone else that has a genuine hartwell car,
IOW graphics cannot help, any other ideas?
- Car Model: Imps
Pop round your local art school, there will be many talented `utes` that can sort you out with the artwork for the price of a kebab!!
Re: Jeff's Hartwell Imp * Does the JIG and gets a new rear end
Well after 7 years of moving it around, I have cleaned the surface rust of the back of the car, ground out the rear shelf and inner wings and cleaned up the new panels and started the reassembly of the shell
All GONE !!!
cleaned up second hand shelf backdated to 63 mk1
NOS 1963 LH inner wing being spotwelded in. This is a very early panel, When i cleaned the primer off, is had been heated up to form it, and had some hand working on it. Prototype part maybe?
NOS 1963 RH inner wing being fitted, note the light cutouts, to suit self tapping screws. another drawing office cockup!
Trial fitting of new old stock rear wings and inner window frame
How I left it this evening, The back end all clamped in place with NOS rear window frame, and new C post, engine lid and crossmember. Looking like it all fits
All GONE !!!
- colin rooney
- Been thanked: 8 times
Re: Jeff's Hartwell Imp does the jig and gets a new rear end
Top work as always
Hit the prototype inner wing with a big hamer!!!
Everthing now fits, and have the new rear wings on.
Decided not to put complete inner arches on, but made small repair pieces for the arch edge, mainly so the spot welder would work.
Rear wings are now on both sides.
Just need to fit the mk1 engine lid hinges to the window frame and fit this.
Next job Front End!
Next job Front End!
- tim sears
Re: Jeff's Hartwell Imp gets 2 wings
1963 deluxe
1965 deluxe Nessa's
1967 cali Demelza's
1967 cali Rosie's
1967 cali
1968 Husky
1973 Clan
1967 Sport
1970 Super
1968 Stiletto
1965 deluxe Nessa's
1967 cali Demelza's
1967 cali Rosie's
1967 cali
1968 Husky
1973 Clan
1967 Sport
1970 Super
1968 Stiletto
With this panel in the back end is done, bar little things like a battery tray and engine lid hinges. Need to repair and strengthen the original mk1 ones, One of which is in two pieces, having rusted away!
Re: Jeff's Hartwell Imp Front end rebuild, as bad as the back!
Rust and accident damaged panels removed!
Time to raid my panel store again
Re: Jeff's Hartwell Imp gets a nos scuttle
copying the arch edge of the nos original panel
inner arch repair , the rest will be done when the floor pans repaired
nos scuttle clamped in place, dont thimk I will ever see one of these again!!!, should really of been used to make new ones, but................
Front end parts all clamped in place, nearly there!!!!
So far the panel count is over 30 new panels, numerous repair pieces with just the floor to fit. I must be at a point where there is more new metal than old!! Does this still make it a 1963 car!?
Phew, and it only took a week, a very long week, with not much sleep! Lou naomi and william fly back in this evening, so ............ watch this space!
Re: Jeff's Hartwell Imp front floor and chassis rails changed
You seem to be using up the worlds final supply of NOS genuine panels ( except for mine ) , great work and a worthy car to use them on , worthy person doin the job too
- ChrisBenoy
- Car Model: Clan 'E' 998
- Been thanked: 1 time
Surely that is the closest to a brand new imp we are going to see anytime soon? Looks like more or less an entire new rear and front end? Impressive restoration either way.
- long_gone_John
- Car Model: 3 sal ('74/'64/'64)-all gone!!
Agree with Chris
No new shells (built any year down the line?)... so that's out.
This is a heavily refurbished shell, originally at the '63 Build date.
If someone was to get pikkie... then a skip (next to it) full of the bits cut out (AND... all the rust flakes) STILL qualifies as a '63 car
I also agree that a steel/3D photo set of the panels, as listed in the WSM, is priceless... and WON'T be done again..
Ace...
LGJ
Ace...
LGJ
TooMuch power.. is not quite enough ;<)
875- GGR 640N - Scrapped
930- 533 KNX - Stolen
BV998- 884 KOE (Ex Sidecar motor!!)
Re: Jeff's Hartwell Imp need's some new floors
Car moved on a little this week, bare metalled the new front end panels and acid cleaned them, back to shinny steel. Welded the scuttle in, so that tied the front end back together.
Next task is to use the car as a Jig for the front wings I am currently making, any one else want any?, and then weld on my new front end. Car then can leave the safety of the jig, and have the internal bolt in braces fitted, so it can be inverted and have the floor repaired.
Estimated completion date, imp 50 2013!
Project Status
30 panels fitted, 5 left to fit!
LH floor*
RH floor*
Parts fitted
Front floor
Boot lid
Front Scuttle
lh scuttle finisher
rh scuttle finisher
LH Door
RH Door
LH Rear Wing
RH Rear wing
RH C post*
Rear shelf
Rear roof trim
battery tray
Engine lid
LHF outer wheel arch edge
RHF outer wheel arch edge
LHR outer wheel arch edge
RHR outer wheel arch edge
Rear seat belt ancher plates *2
closing panel between a post top and inner wing
front grill
LH floor*
RH floor*
Parts fitted
Front floor
Boot lid
Front Scuttle
lh scuttle finisher
rh scuttle finisher
LH Door
RH Door
LH Rear Wing
RH Rear wing
RH C post*
Rear shelf
Rear roof trim
battery tray
Engine lid
front grill
- Car Model: 64 Grp N race car, 66 Mk2, 68 Super
- Has thanked: 8 times
- Been thanked: 12 times
Re: Jeff's Hartwell Imp Try's a 4 Lamp Front panel and Wings
Why did you change to the 4 lamp front end Jeff?
'cos it looks better!
Re: Jeff's Chamois has a play in the snow
I too have old petrol in my Chamois.
Your short run in your Imp sounds like it was fun, Jeff!
Re: Goodbye CNA 476C
New owner pointed to the forum and the club I hope Jeff?
Re: Hartwell Imp Garage at home, planning approved today
What are your time scales, Jeff?
Re: Hartwell Imp's garage has walls
Nice! I'm definitely suffering garage envy. Can't wait to make a start on mine.
Insulate as much as you can Jeff, walls ceilings and doors. A bit late for the floor though!
- Car Model: Super
is if 4m at the eaves then or are you going to have the first pent-roof imp after the first attempt
- impmann
- Has thanked: 18 times
- Been thanked: 69 times
Re: Complete restoration of a Hartwell Imp
Go for it... it would be good to finally see that car back in one piece!
Those porsche wings are £700 EACH
If they will sell you that size for £865 then take it, they look ok from the photos, mine cost £1800ish for the same size in 1998! Obviously like flat screen tele's theyre getting cheaper all the time and have come down in price, as long as the door comes down, oh and goes up when you want it to you cant go wrong.bazzateer wrote:When the time comes I'm thinking of getting mine from these guys:HARTWELL MK1 wrote: just needs some doors and insulation!
http://www.ebay.co.uk/itm/AUTOROLL-ELEC ... 0705979036
Re: Hartwell Imp Engine Time
Sounds good, Jeff. I must say, your (almost) chosen colour scheme of white over blue sounds most excellent!
Re: Hartwell Imp Balmoral grey / Skye Blue
And whilst I'm thinking about making it go, it will also need to stop. However micras were not too common in the 60's, so I broke a brabam viva for the front brakes. The rest went in the crusher but it was a bit rusty.
Time will tell whether I like this set up or not, But I've got a fair waay to go till I find out
Paint wise I will try Skye Blue Lower Half and Balmoral Grey top at the guide coat primer stage, and if I like it It will stay. I suppose I could also spray a bonnet grey, and borrow vicky morgans car
Re: Hartwell Imp Balmoral Grey / Skye Blue paint
Also not going to use the mk1 wing badge in favour of a stick on number plate ?
Seems a shame. Its one of my favourite things about the Mk1
"I think it would be a good idea."
- Mahatma Gandhi (1869-1948), when asked what he thought of Western civilization
And how it looks at the moment!
Although not much looks to have been done, several hours of work has been done on tweaking panels, and making minor adjustments, to make this imp fit together how Lord Rootes wanted them to look! And Yes that is a new sport engine lid in the background!
- tim sears
No spot lights.
Keep it clean and pure.
Just my opinion ,but living with 3 females it doesn't usually count for much.
Keep up the good work
Tim
Tim
1963 deluxe
1965 deluxe Nessa's
1967 cali Demelza's
1967 cali Rosie's
1967 cali
1968 Husky
1973 Clan
1967 Sport
1970 Super
1968 Stiletto
1965 deluxe Nessa's
1967 cali Demelza's
1967 cali Rosie's
1967 cali
1968 Husky
1973 Clan
1967 Sport
1970 Super
1968 Stiletto
^^ Speaking personally, I agree with Tim. Keep it pure and leave the spotlights off. Obviously that is just my opinion and I am certain that the car will come out looking spectacular, whatever you decide to fit or omit.
- impmann
Hmmm, nice, but I think if the top was Skye blue and the bottom was slate grey it was look even yummier....
Re: Hartwell Imp Balmoral Grey /Porsche Slate Grey paint
The next weld a thon begins tomorrow
Re: Hartwell Imp gets some more welding done!
Well not much left to do now,
Heres my TO DO list
Fit the enlarged front airbox
Reinforce and fit the Mk1 engine lid hinges
Repair the floor (Its heavily pitted but not holed, so a good coat of paint will have to do!)
Drill loads of trim holes
Paint strip, phosperic derust treatment and paint
Reassemble
Take to wicked Welsh!
Heres my TO DO list
Reassemble
Just spent 4 hours derusting the floor!
Heavily pitted but mostly intact, so this will be repaired rather than replaced
Spent a hour or so with the mig on low power welding up pin holes! to save the floor
The square that is cut out on the lh side, was already patched in the 90's when I got the car along with a cover sill that side. In fact that was the only rot on the car
Should have repaired it and waxoyled it then!
Time for bed
Time for bed
Re: Jeff's Imps! 5948RU and _________
Sounds good, Jeff. But we need PHOTOS, please!
(Well, I do anyway. )
- Car Model: stiletto - chamois - californian - super
Re: Jeff's Imps! 5948RU & a sleeping friend
This sleeping friend wouldnt be painted a certain shade of Vauxhall Beaudeax Red maroon pearl by any chance?...................................?
- Car Model: IMP SUPER//TRANSIT
with an 'imp'related number plate...
Loving Imps since 1963!!
Fabulous! The long-awaited return is imminent, eh, Jeff? Daft as it is really, I'd be losing sleep anticipating that first drive! Just like when I got mine back from being worked on almost five years ago...
TAGORAMAN wrote:This sleeping friend wouldnt be painted a certain shade of Vauxhall Beaudeax Red maroon pearl by any chance?...................................?
Maybe !GURNSIMPS wrote:with an 'imp'related number plate...
- Car Model: Imps
Re: 5948RU & 4181MP (The sleepy sport)
Octo-lamped Maroon-ness.
Very cool Imp!
