Today I removed the trim piece over the glove box to recover it. It's been a bit baggy for months now, so today was the day.
- Has thanked: 130 times
Just for you little legs
All back together this morning.
- Has thanked: 150 times
Repairing bonnet and interesting to see the result of the factory adjustment to get the alignment right.
They have just given the rear corner a good whack to align it with the scuttle panel, it's not surprising then that replacements don't fit well. I'm sticking with the original
Bonnet repairs, rather than continuously weld the repair and then have to grind off decided to spot weld it with local seam welds.
PeterThe Nun wrote:I dont know if I would do that today, it does look rather a mess and its easy to get around and do the adjustment properly, but I suppose on the line they wouldnt have time to recut and weld at that stage, still a bodge though isnt it? Im all for keeping it as original but not in situations like that.
When I bought my Chamois, the previous owner said if you find anything that doesnt fit its how it was when it left the factory, which was rubbish as they had had taken the doors off in the past thus upsetting any factory setting, it was a excuse to cover their bad workmanship up more like.
Same as leaving the frayed door seals on, I didnt replace those as the new ones dont look right? but frayed does? and I didnt replace the carpets as new ones dont fit, but original ones with hole in the footwells look ok?
I always think to myself no if youre bothering to do a job, sort it out and put it how it supposed to be to the best of my ability, the cars werent designed to look bad Im sure?
Multiple uses still for a hammer and block of wood particularly getting the doors to fit properly, you can only do so much with the hinges and shims, sometimes the only recourse is the above tools as I can't stand the doors not being flush with both the wings and rear quarters - all the way down.
Last years restoration project
You'll be glad I'm off the same view - do your best, so you can sleep easy tonight as I cut out and replaced the rippled section.
Probably went a bit too far and stripped the bonnet apart to clean the inside of the panels
First time I've seen the factory dip coating on a door usually the doors have seen work and no longer visible.
Did some more sorting & unpacking in the garage, including turning the car around and putting it in the back corner in anticipation of perhaps collecting a car or two from storage on the weekend (6hr round trip...). Under the bench at right are the gearboxes plus some wheel rims and other parts, and in one of the tubs is another SOHC aluminium cylinder head - I should take a photo for contrast, 4.0L 6-cyl vs 875cc 4!
- mikeyhearne
- Car Model: B.S. Nymph
- Been thanked: 6 times
Done nowt to the Nymph.
Still sitting where it rolled off my truck after last year's national
On Saturday took my green Imp to Maffra, our car club is participating in a display of Bygone British Brands (isn't that nearly all of them?!?), we had 16 cars in total from 1930s on, with one other Imp. Then on Sunday while I had the van & trailer brought another Imp home and a heap of parts. All told 1,000km covered.
Here we are then, just for Peter. Stainless dome head screw with a washer under the head slid from the open end and positioned as necessary. JB Weld squeezed into the void to affix and locate, then filed off flat when dry. I will probably put a bit of rtv sealer around each as I push them through the front panel. Screws will be shortened a little so they don't protrude too far into the void.
Sum total of car fixorage this week so far.
Re-stuff some foam in the Singers passenger sunvisor as the bit i stuck in a few years back moved - ive done it different this time so it shouldnt happen again .
Having a factory fitted vanity mirror helps with this job , remove mirror , fit foam through the hole then refit mirror
Gordon delivered the side panel for his Van
I set about trial fitting it
More work still required but very happy with initial fit
Just need to find one for the other side now, if anyone has an offside one as its rotten at the roof and poor previous repairs to the rear corner. Van side panel would be great but could make a Husky one work.
Money waiting and not expecting it to be cheap.
Thanks to Martin Dingle for helping out with this one.
Washed 3 cars on Saturday - 2 of them Imps, first time they've had a tub in many years sitting in a shed & garage respectively. The blue car is example of why you can't trust photos (even slightly blurry ones) it is way less shiny than it looks! The stripes have cracked - not sure you could do this effect deliberately? It is also sitting a bit high - no engine. Another funny snippet - the mud flaps were made by cutting down some from a cement truck - the name of the company can be seen on them.
Today I spent an idle 2 hours in the hot hot sun waiting for my eldest son to turn up to rescue me. I had taken the decision to nip down to Speedy Spares to purchase a recon starter motor as my original was playing around and was sure to give up the ghost quite soon. So this afternoon was exactly the right (wrong) time. So there I am parked up, new starter in my possession but inappropriate tooling to fit it at the roadside. Then.... and you can hardly believe it, after arranging my rescue, I waltz off to buy some water at a nearby petrol outlet. I've literally just crossed the road junction when "wham" there's an RTA right next to me ! Long story short - they close the road ! aaarrrrgh ! I'm now back home having eventually received a bump start
I mentioned recently the cylinder head size difference between an Imp and Ford Falcon 4.0 six. The cylinder spacing is the same as when the engine debuted in the first Falcon in 1959 as a 2.4L (144ci), however the cylinder head is longer to house the SOHC timing chain - it was originally OHV. The newer DOHC head is even bulkier at the front because it has the cam adjustment mechanisms for the variable valve timing. The SOHC layout is different to the Imp as the cam actuates the valves via rockers as per most 'what used to be modern' engines. Nice big port sizes anyway - with a big enough turbo I have heard of over 1000hp.
Here's the 1966 Mk2 Imp, a genuine little old lady car I bought after her grandson did not want it. Apart from the scrape on the side, she was prompted to retire from driving after running into her gatepost one day... Other than the damage there is no rust so I've always thought it's worth fixing; I originally bought it for the interior.
Today I finally got around to fitting an electric bonnet release. I'd had a half hearted attempt before, but it didn't work. This time I've used one with a motor, rather than solenoid and it's successful. Why have I bothered ? Well Stan was originally a basic : rubber mat, no door pockets, no glove box. Just a plain open cardboard shelf. This means that the bonnet pull is fixed to the bulkhead/firewall and as such is a right pain to reach if a glove box is fitted. Which has been the case for some years now. It invokes sideways looks if you ask your passenger to pull your knob as its difficult to reach ! So now there is a delicately small red button to press once the glove box is open, and hey presto - it's popped !
The motor is mounted on a chunky aluminium bracket bolted to the top of the front plenum. Stainless steel fixings all round. Actuator rod is affixed to the same place as the original cable.
To follow up here's the other car, a GT, and since the last installment I've put cardboard under them to catch oil drips and emptied out parts that were transported inside the car (seats, bumpers, boot cardboard panels/covers).
The GT has rust in most of the usual places but it's not that bad and seems to be pretty complete. It needs a full restoration, but I'll probably sell it before getting to it (don't really have space to keep all the cars). I don't believe we have the original engine for this one, but do have another GT engine. It has quite a small aftermarket steering wheel, but after measuring it (300mm dia.) and others, it just seems small because it is thinner - two other cars also have 300mm wheels but with thicker rims. Going on past experience that is plenty to give enough leverage on the steering. Also gives a good view of the aftermarket tacho I suppose!
- Been thanked: 100 times
Not quite done today but over the last 500 or so most days, 66 Sport and £4500 of new panels fitted will be off for a new coat of Ming Blue in the New Year, it was previously Minging Blue, quite a rare sport only colour back in 66/67 as most seemed to be metallic green, bronze.
- Car Model: Clan Crusader & Davrian Mk6
Same type of thing happened to me many years ago when I built a car up for circuit racing in the pre-66 CSCC series, where you had to run all steel panels and the single solex set up.moose wrote: ↑Sun Dec 22, 2019 4:51 pm I like Oxford blue. I did my rally car in an oxford blue and any one who has read my thread can see the work i put into the car so can you imagine how i managed to keep my cool at a show when having shown and talked someone round the car from one end to the other all i got (not even a compliment on the workmanship) was that is the wrong shade of oxford blue!
Had spent about 15 months stripping the car down, it had been off the road in a garage for about 15 years before I got the car. The car was really solid and only needed a small amount of welding in one wheel arch and it was re-built with a full re-spray inside and out.
Took the car and the re-build photo's on a build board to the national at Banham(?) and was told by someone quite senior in the club after they'd had a good look at the car and the photo's, "that's pity that you turned a really nice shell into a race car".
Think the other thing that miffed him was the repainted Imp badges on the dummy grill and "C" pillar with a Mopar green backround instead of blue, this really wound up him and others that weekend. I'd done that to go with the green painted ashtrays that I left in the dash and on the tunnel behind the seat, with most of the brackets also being green along with the wing mirrors. As both of my previous hillclimb cars always had something green on them and I like green, even had a green race suit. Wasn't that bothered about the comments, as when we took the car to Donington to race in the support race for the German Touring Cars(pic above), Pat Longhurst (the multiple Davrian driving champion) had a really good look round the car and congratulated me on the preparation
- Has thanked: 59 times
Cleaned, polished up and painted the windscreen motor.
Also stripped the headlamp bowls and cut a hole in the back so I can access the bulbs easily when I refit them with H4 halogen lamps. Cheers
Sorry to hear that, Mike. Best keep them outside of the car from now on, eh? It's the same jealousy that inspires the giits to run a key down the side of a nice car....
Copycat , Works well though , as long as you keep the spring tab in place you can chop quite a lot out . Passengers sides a bit more complicated but not difficult
- mikeyhearne
still done nowt to the Nymph.
Still sitting where it rolled off my truck after the 2018 national
just has more leaves on it
Friday is now a ,if l feel like cutting metal day, l will , only working generally four mornings .
So Imp wise l converted a batch of washer jets to take the larger style jets, ones l originally made them for were single jet plastic and they were all failing my testing so decided to scrap the idea of offering that style , coloured ones shown will more than likely be available , awaiting more test results.
So that was my Imp related work today
Had a partial sort out in garage , and decided to partially fit steering rack together
Give it another wash out , fit a valve (NODS MODS) to end gaiter, load grease\oil , l'm going to use Land Rover swivel grease , copper slip track rods (nice stainless ones), and that's first job in front end reassembly
All seemed ok with operation by hand , no tight or loose spots,so good to fit, already one on the car at the moment , as l got vertually two of everything when l bought it.Give it another wash out , fit a valve (NODS MODS) to end gaiter, load grease\oil , l'm going to use Land Rover swivel grease , copper slip track rods (nice stainless ones), and that's first job in front end reassembly
- yoeddynz
- Has thanked: 13 times
I tried to take a photo of the imp with the sun coloured all red, thanks to those pesky aussies sending their smoke over our way. It's been a weird day.. Pretty hot at 31 degrees but smoke haze making the sunshine on the ground red. Luckily the sea is just cold enough to take away the heat. Local Motueka River is lush right now too.
Crap phone photo...
Refreshing river...
Crap phone photo...
Refreshing river...
- mikeyhearne
It's blue and plastic so not far off the original .
Carried out Daves steering gaiter mod, punch hole in gaiter then glue in tyre valve stem for refilling if needed Thanks again Dave.
Also stripped stub axles
And lift & tilt car lift arrived Bob
Also filled steering rack with Landrover swivel grease .
Nice one, Bob.
As for me, I undid a Jiffy bag which contained these two, courtesy of our resident all things rally spec manufacturer, Mike Dent.
- jetmech
Finished and tested the alternator conversion. It's only taken me 31 years to get around to it! I used an original spec alternator as I don't have any heavy load accessories and the car wiring is original. Fitted a Lucas fuse box in place of the old control box.
From a week and a half ago now, brought the last Imp parts home - a bodyshell is a part right?
As always I'm glad Imps are small and light - it was easy to lift the shell to get it on dollies to roll it to the trailer, easy to winch it on and even easy to winch it off (with a separate hand winch) using timber boards to slide on.
Been moving cars and racking around at the workshop and decided that what was needed was mobile benches so have made 4, two at 58" and two at 75".
These were done on the cheap using materials that were around, the racking is the old staging from the mushroom farm which are just over 4m long and bl***y heavy. these were cut in half, one part can be used as is but the other needs new legs welded on but as it's heavily galvanised needs to be well cleaned before welding. Bits of wood and OSB sheets as well as the tops from the old benches were used, the only parts that needed to be bought were the castors.
Much still to do to get it where I want but going to commit next week to the task.
Losing interest in all this tidying but seeing some results, many trips to the tip sorry recycling centre . Need to stop keeping all the bits that might come in handy but seldom get used.
Moved many £1000's of Imp panels. Sounds a lot but not really, just expensive
Floor area between the racking cleared and it all looks so much better.
Slapped together an engine box/trolley from some ply offcuts I had, which wasn't 100% ideal as the sides could have been 20mm longer but it still works. The base was only 5-ply but again I think it will do. You can see the screws holding the castors on, as I thought it was better space them wider for stability rather than put the screw protrusions 'inside' the box - if it becomes an issue I'll cut the ends off. Or perhaps I should do that before scratching my fingers on them...
A loose sump makes a perfect template for drilling holes to locate the sump studs. You might be able to see that the lip of the sump hangs over the right-hand end because the timber was a little bit short. I haven't added rope handles yet, also I'll do a couple more to store engines upright so will refine things for the next one.
Further to my post about Lift & Tilt car lift , today l modified some of the extension pieces so that unit can be stored underneath the car in garage, the lift comes with three different widths available , it arrived with it set for its narrow setting , l modified the middle range by removing 70mm from the spacers , just need to make some more bits for it tomorrow .
It's a heavy piece of kit so didn't want it stood up against wall (garage is small enough without making it narrower)
The winding mechanism is wider than track of wheels but that's going at back of car .
tuk841 wrote: ↑Fri May 08, 2020 10:10 am Fixed the washer plunger that had done nada for some while!
I had lashed up a temporary elec pump some MoTs ago, but recently got a new, Mk3 washer pump/plunger from Bob at Imp spares. After fitting that, whilst the dash was out, it made no difference. Lots of air-sucking noises, but no water. Ho-hum
Popped a one-way valve in the output tube from the pump (towards the nozzles) last night and hey presto, working as if it had never stopped - marvellous.
There must be one as standard under the dash that had failed? not that I have ever noticed (there isn't one built in the pump) - as thinking about it, it was never going to work without one, as the pump will take the easiest option and suck air from the jets rather than pull water up from the depths...
New Jet replacement kits still available here .
These plus single jet chrome.
This :
Good day
Hope to get wishbones back on tomorrow and even better back on the deck
Destroyed one rear trailing arm to save another
Running short of gas so will leave the welding until later but that's the hard work done.
- Car Model: singer chamois
Found time to spend all yesterday afternoon on the cars. ( some of us are still working)
On Imp I put passenger door card and pocket back on. The chrome trim on door was loose at front so replaced plastic clips with new ones
Checked tyre pressures and had to blow three up before firing up car for first time since the autumn.
Even with BMW power took a few turns of the key.
Car wouldn't go into gear as clutch plate stuck on. Re-starting car in gear with foot on clutch freed it off (any better way to do it?)
Moved car out on to drive so could work on Clan. I have single garage and Clan lives above Imp on a car hoist installed Clan engine needs changing and head already off. With hoist job is so much easier and soon had everything needed to get engine and box out except large bolt to rear mount sorted before calling it a day.
Went to put Imp back and found rear brakes seizing on so that's my next job sorted!
Need to get at least one car ready for when lock down lifted
Teddie2003 wrote: ↑Sun May 10, 2020 5:24 pmWhat make/size of car hoist is that or did you make the hoist yourself?Peter Hurst wrote: ↑Sun May 10, 2020 1:18 pm Moved car out on to drive so could work on Clan. I have single garage and Clan lives above Imp on a car hoist installed
I copied him and bought the same hoist 6 years ago only in red and yellow. It's from china - the smallest/narrowest version specifically for classic cars. It will still take my Lotus Excel (just).
Mine cost about £1100 including delivery (6 years ago) - delivery is quite expensive IIRC. Would be lost without it now!
Pulled out the suspension to see what I actually had and came across a combined manifold - Score
Had a go at retrimming a Stiletto steering wheel myself and considering I dont do sewing and leather and the original was in tatters it does look sort of presentable again.
Carrying on the theme of sorting through years of hoarding and turning the tat into ready to use parts, today was the turn of hubs/brakes.
Stripped them into their individual components ready to be cleaned and derusted before going through them and refurbishing them.
Surprising how many I could identify which car they came from - sad I know.
Today I sewed up the brushed nylon material and recovered the drivers seat in Stan. It's the first serious sewing I've done since the age of 16 or so, and I used the Toyota machine passed onto me when me Julie bought a new one last year. I have 4 of the 7 pieces needed to redo the passenger side one, so as I'm now confident in my technique, I shall order the rest of the material next week.
- jetmech
Finally got around to fitting a hazard lights unit. Very easy to install, no changes to the original wiring, just a couple piggyback connectors at the indicator switch and a permanent live, taken from the interior light circuit.
Simon You do not have the required permissions to view the files attached to this post.
