- Dion
- Car Model: 68 Chamois Mk2, 68 Husky
- Been thanked: 7 times
A topic frequently found on other car forums, was surprised there is none here so lets start one.
Today I fitted the new top steering bush. Robert Immers made one from PTFE and it fitted perfectly. No loose steering wheel anymore! Of course tested it with a long trip.
- Has thanked: 130 times
- Been thanked: 91 times
Cleaned the Singers boot out
- jetmech
- Has thanked: 1 time
Replacement piston rings arrived this morning so I set about reassembling the bottom end. Just need the head back now
A seat cover set also arrived today, so I was at last able to repair the drivers seat back, which had a couple of holes in the side panel at the shoulder. Forgot to take a before picture, but pleased with the finished seat.
Simon
Simon
- Grahame59
- Car Model: Hillman Imp Super
- Has thanked: 22 times
- Been thanked: 47 times
Had mine retrimmed in leather a few years ago — well, actually I used a scrap pair of recliners from a Californian or Chamois Coupé, my existing seats were mint so it would have been a crime to retrim those. A very worthwhile mod — backrests at a less upright angle and no longer sticky on a hot day.jetmech wrote:I have seen one car that was recently retrimmed in leather but in the original style.
Simon
- Has thanked: 68 times
- Been thanked: 100 times
Finished the dash at last.
Went to a fab show at Kingston Maurward College .
Mr Singer of Singer cars fame was born here so on their annual open day a few Singers are invited for a small display , superb weather and location
Today, whilst waiting for knifing putty and etch primer to dry, I drilled and tapped ( M4 x 7 ) the centre of a spare wiper wheel box spindle. The thought behind this is, considering Stan's wiper arms are a little "baggy" on their spindles, I might do the same on him and hold them a little tighter, in the interests of efficiency. As the outside of the appropriate part has a small domed effect to it, I had the idea of finding some stainless steel solid countersunk screw cups and use them upside down (countersink to wiper arm) and fix using dome head stainless socket machine screws.
- jetmech
Collected the overhauled cylinder head from Reg Patten yesterday.
Fitted it today. I am going to borrow a calibrated torque wrench from work tomorrow to double check the head bolts, before I close it up.
Hopefully it will be back in the car by the weekend.
Simon
Simon
- jetmech
MOT success
To celebrate I re-waxoyled the underneath. It's well over 10 years since it was last done.
Simon
Simon
Took my friends daughter to her prom night by request
Wayhey ! Managed to do it ! Now photobucket can go and boil its greedy head.
- Dion
Helped Stiletto owner Hans to fit a towbar to his car so he can pull his vintage Mostard Yvonne caravan. He always used his Minx convertible to tow the caravan but he wants to take the caravan to next weeks Going Dutch weekend - behind the Stiletto.
We got the towbar safely fixed to the car and tried it with a small run. The Stiletto has no problem towing this lightweight caravan - on Dutch flat country roads!
- Dion
For a long time I have wanted to mount a RPM gauge. Just to know what revs the engine makes. I already had a nice 2" sixties instrument, with the idea in mind to mount it next to the oil pressure gauge. I know the metal dash behind the wood already has a 2" hole for an accessory gauge. But on the other hand I did not want to make a hole into that beautiful wood. Also I did not want to remove the Chamois badge. So, I needed to find another space for it. Which is pretty difficult. I tried on the A post (looks stupid), under the left hand bin (in the way of getting in and out), above the radio in the corner (but I could not reach the remote bonnet release then), on the floor in front of the choke lever. Or on the column. Or under the dash, next to the column. That was the best place for it. Problem then it was further away so something larger would be better.
On Ebay I found a good TIM 80 mm gauge, in a black plastic pod. The most work was to get a wire from the - of the coil, under the floor, into the front compartment, and then behind the dash. Another wire was needed for 12V, another for ground and another for the light - all easy to find behind he dash. The instrument is mounted using an existing bolt from curved metal dash below the wood. No drilling was needed anywhere.
It works well, the location is a good one - easy to read while driving. It amazed me I usually never would go much over 4000 rpm.
- Car Model: 1969 Hillman Imp
Been working on getting my new gauge panel wired. Took the car for a little spin just to stay motivated, and pop went the windscreen. Two steps forward, one step back as usual. So I vacuumed up the glass and flogged it around anyways.
Jim Lecesse in Raynham, MA USA
1969 Imp Deluxe - IMPorted - two steps forward, one step back
1980 Caterham Seven - 1700XFlow flying low
- mikeyhearne
- Car Model: B.S. Nymph
- Been thanked: 6 times
Did nothing on the Nymph as I'm in IBIZA
But on seeing a yard full of the 2CV based buggy the Mèhari that are available to rent on the island
. I did wonder what became of the Nymphs that were sent for evaluation as rental cars to where ever it was they went ?
nothing is IMPossible with the right attitude and a BIG hammer
- gill
- Car Model: Hillman Imp Super, BS Nymph, Siva Llama
- Has thanked: 20 times
- Been thanked: 2 times
Well, not myself, but this is how far the painter has got with my Llama
Yes, a few bits missing, but it's coming along!
Now got the cam timed up properly, water and antifreeze in, inlet manifold fitted etc. About to clean up the carbs, cam box and stainless Clan Club "silencer". All things turning up on time and it will be running by Thursday.
Kind of Imp related
Not normally one to get roped in by sales and price cuts I did succumb today as our local Homebase is closing down .
So I ended up buying 18 huge rubber mats 10mm thick made from recycled tyres . At less than half price I couldnt resist as they make great garage flooring .
No more lying on cold concrete for me
Serviced the carbs yesterday, discovering that the original cross head screws were fixed solid in a few cases, requiring a saw cut and flat screwdriver to remove. See other thread re stainless replacements. Replaced all of the O-rings and checked/adjusted float levels, reset to basic settings. Hoping to fit them today, weather permitting.
- pubcrawler
- Car Model: 1965 Imp, 1971 AH Sprite MkIV, 1965 Triumph Herald
Thursday, took part in a club's auto-solo….with a navigator
Completed this afternoon.
Found a slight problem
- Grahame59
I fitted LED bulbs to my front sidelights.
Very pleased with them. Beautifully bright and white. The photo doesn't really do them justice; the difference is massive.
Standard bulbs are a feeble 4W, these are 25W (4 x 5W LEDs around the sides and 1 x 5W LED at the front with a lens too) but being LEDs it doesn't of course draw 25W, I think the actual draw is something silly like only 2.4W. There's a wide choice of LED bulbs depending how bright you want them. 233 sidelight ones fit the Imp. Mine were £12 the pair but you can get some for just a couple of quid; all are a massive improvement on the standard bulbs. (Be aware that if fitting LEDs to later Imps you may need to gets shorter LED bulbs — there are plenty available — as later lenses are shallower; no problem on mine as it has the early deep lenses.)
I wanted bright ones as I intend to use them for daylight driving when conditions are gloomy or overcast but not dark enough to justify headlights. The standard bulbs are no good at all for this and to be honest are little more than parking lights.
- mikeyhearne
I fitted drl and led side lights to the Nymph a while back
- Has thanked: 150 times
Thanks Andy.
Bottom area made and tacked in, will fully weld when on the spit and upside down.
After work, I fitted the newly aquired RAC branded mesh blinds. They came with suckers, but that ain't the way, is it ? So I modified the four lower supports and used flange head screws to fix them. Lower in my case as it's much better, and simpler, to fix them to the lock transom and pull them up when in use. They will only provide a miniscule amount of sun/uv protection but, hey ho, they cost peanuts. I can easily modify them with a different material in the future.
More fabrication
More making stuff up
Floor edge replacement Would be happy with these welds but considering they were done upside down very pleased. Scott
A day spent repairing the inner wheel arch at the A post
- bazzateer
- Car Model: 68 Chamois Sport, 72 Imp Sport, 76 Datsun 260Z
- Been thanked: 88 times
Walked round it then, along with Impmaniac, took Rej the blue Vogue to meet Roger and his Stiletto for a Rootes convoy to Brooklands for British Marque Day. Some very nice cars on display plus some Minis.
Reason: Edited by Graham Anderson to correct orientation of the photo ;)
H bracket reinstated
Thanks Col
Time to stop and tidy up the Shed, look what I found hiding under a Car Cover
Looked better than I remembered, then I looked a bit closer
So moved it and Amy's Coupe to a new location and put the covers back on.
Soon Little Ones Soon
Made and fitter the missing bits between the roof gutters and the screen pillars
Steve
The Blue one would be good for that, there is a good covering of body filler spreading from the lower corner where its been repaired but no rust around the light area. £25
The good news is I'm coming over for the Irish Experience at end of May so can bring it with me. If your not going I'm sure one of the Irish members will take and keep it for you to collect and if not why not
Bad news, it would only be fair until to wait until I've heard from Lomond26 as he asked first however will give him until end of play tomorrow to reply so will let you know Tuesday morning if its still available but we will still have other options.
Inner sill fitted
- MattorMatty
- Car Model: Hillman Imp Super & Singer Chamois Sport
- Has thanked: 2 times
- Been thanked: 3 times
The Imp passed its MOT today, no advisories. That's what we like.
I've a number of new panels that unfortunately have some surface rust, I've used Bilt Hamber Deox rust remover with great success but it would be prohibitively expensive to buy the quantity needed for my new tank so after a bit of internet research decided to give citric acid a go which allegedly is the basis of the Deox solution anyway.
Used a 380 ltr wheelie bin, made up a bracket to hold an immersion heater element and added 25lts of citric acid powder.
Put 4 Imp front wings in and it has proved very effective despite having them in for only a couple of hours at 40 degrees, after rinsing them off much of the rust had been removed .
I decided not to leave them in overnight just in case they dissolved completely, I once bought a wheel arch section with light surface rust, by the time it was rust free it was paper thin . I did however leave a couple of centre sill sections in to see how they turn out, as less worried about them.
- Car Model: 64 Grp N race car, 66 Mk2, 68 Super
- Has thanked: 8 times
- Been thanked: 12 times
Here it is. There is some blue sky reflected in the window, I was very lucky with the weather, we had rain all day Wednesday and on Thursday night but the day was dry and 16°. Yes it needs a wash!yoeddynz wrote:Photos of new place, sunshine included please. If only to cheer up those in blighty who aint yet having much of a flash summer.johnh875 wrote:Moved my Imp Super to my new place, plus 2 engines. One tyre had gone a bit flat (<10 psi) but other than that, smooth sailing. Having said that, a lot more work than last time I moved nearly 12 years ago and I've still got a lot to do before I'm finished.
I did also wonder about the weight of an Imp engine. Does the 'standard' figure of 170lb/77kg include manifolds, carbs, flywheel? One of the engines was complete from full exhaust & carbs to clutch, less water pump, generator & starter. I'd carried it into the garage years ago but decided it was better to have help this time.
Well its official new formula paint strippers suck, great for the environment I'm sure but does nothing for its effectiveness.
Stripped a number of panels ready for further repairs including a bonnet, removed the inner panel and it's easy to see the reason for them rusting out - absolutely no protection on the inside just bare steel.
Inner panel 30 mins at 50 degrees in the citric acid bath - only get 3/4 of it in.
Took the passenger door off the 66 Sport for re skinning, never been touched before so factory fit, had to get the screws glowing red to shift them. Interesting to note out of the 8 hinge screws 2 were short ones being 3/4" long and not 1" as they supposed to be and as all those on the drivers side.
The factory must have had a stock shortage at the time so had to use whatever they had to hand?
Today I removed the trim piece over the glove box to recover it. It's been a bit baggy for months now, so today was the day.
Just for you little legs
All back together this morning.
Repairing bonnet and interesting to see the result of the factory adjustment to get the alignment right.
They have just given the rear corner a good whack to align it with the scuttle panel, it's not surprising then that replacements don't fit well. I'm sticking with the original
Bonnet repairs, rather than continuously weld the repair and then have to grind off decided to spot weld it with local seam welds.
PeterThe Nun wrote:I dont know if I would do that today, it does look rather a mess and its easy to get around and do the adjustment properly, but I suppose on the line they wouldnt have time to recut and weld at that stage, still a bodge though isnt it? Im all for keeping it as original but not in situations like that.
When I bought my Chamois, the previous owner said if you find anything that doesnt fit its how it was when it left the factory, which was rubbish as they had had taken the doors off in the past thus upsetting any factory setting, it was a excuse to cover their bad workmanship up more like.
Same as leaving the frayed door seals on, I didnt replace those as the new ones dont look right? but frayed does? and I didnt replace the carpets as new ones dont fit, but original ones with hole in the footwells look ok?
I always think to myself no if youre bothering to do a job, sort it out and put it how it supposed to be to the best of my ability, the cars werent designed to look bad Im sure?
Multiple uses still for a hammer and block of wood particularly getting the doors to fit properly, you can only do so much with the hinges and shims, sometimes the only recourse is the above tools as I can't stand the doors not being flush with both the wings and rear quarters - all the way down.
Last years restoration project
You'll be glad I'm off the same view - do your best, so you can sleep easy tonight as I cut out and replaced the rippled section.
Probably went a bit too far and stripped the bonnet apart to clean the inside of the panels
First time I've seen the factory dip coating on a door usually the doors have seen work and no longer visible.
Did some more sorting & unpacking in the garage, including turning the car around and putting it in the back corner in anticipation of perhaps collecting a car or two from storage on the weekend (6hr round trip...). Under the bench at right are the gearboxes plus some wheel rims and other parts, and in one of the tubs is another SOHC aluminium cylinder head - I should take a photo for contrast, 4.0L 6-cyl vs 875cc 4!
- mikeyhearne
Done nowt to the Nymph.
Still sitting where it rolled off my truck after last year's national
On Saturday took my green Imp to Maffra, our car club is participating in a display of Bygone British Brands (isn't that nearly all of them?!?), we had 16 cars in total from 1930s on, with one other Imp. Then on Sunday while I had the van & trailer brought another Imp home and a heap of parts. All told 1,000km covered.
Here we are then, just for Peter. Stainless dome head screw with a washer under the head slid from the open end and positioned as necessary. JB Weld squeezed into the void to affix and locate, then filed off flat when dry. I will probably put a bit of rtv sealer around each as I push them through the front panel. Screws will be shortened a little so they don't protrude too far into the void.
