Singer Chamois CNA 476C
- Car Model: Singer chamois
Hi
I am very new to this forum, this is the very first posting of my attempt of restoring an old 1965 Singer Chamois.
My original intentions were to clean the underneath and paint it, but over the several months of undertaking this project, it has led to a little more than this.
hopefully i may get some expert advice from your good selves to point me in the right direction.
Car purchased June 2014
Re: Singer Chamois CNA 476C
Tucks neatly away in the corner of the garage.
!st job for me was to see how clean it was underneath,
having it on a 4 post lift we notice a lot of surface rust,
Engine out because it was blowing blue smoke, always wanted a 998 anyway so took it to Maynards.. hopefully back in January
Front and rear suspension off
More Rust !
Powder coat
Decided to buy a spit ! makes the job a lot easier
Powder coat
Anybody want to buy a Clip, Got Loads !!!
Its nice to know that there is some of you out there that recognise the car, hopefully putting it back into a trouble free motor.
After the POR15 Treatment
The final POR15 treatment is a black finish
The spit has got to be the best bit of kit i purchased for this car, I may rent it out to a club member for next to nothing if anybody is interested, when I've finished with it P.M me
Finally the colour
Time for some brake pipes
nuts and bolts have arrived
Bolting the front end together
Update, for all those that love restoration of cars.
Wheels back from the powder coaters
- Been thanked: 100 times
They are original MinIlites wheels, they look like 5 1/2" ones?
I have a set but mine are 13"dia x 6" so have a wider outer flange and even then could go to 6 1/2" at the rear with the same offset and clear the body, but they dont do them so you would need to go to 7" which would probably mean some arch flange dressing would be needed and its not a thing you want to be doing once it all painted.
I will have the 6" front and rear but the rears having a 1/2" solid spacer with extended solid escort studs to bring the wheels out to fill the arches properly, this gives a better look in my opinion.
How did they make these Oil coolers, Before and after picture of the pain staking straightening of the copper fins
- Grahame59
- Been thanked: 47 times
Took about 2 hours to do mine, I also used a small screwdriver. It is quite a therapeutic job!
These are my MINILITE wheel nuts but my wheels have the taper steel seat insert in them to match the nut.
Dash Going back in, anybody wants a set of veneers for there dash i have enough for two more cars spare, anybody interested inbox me for a price.
Thanks for those kind words
Am i Missing something,
seems to me that there should be something for the chrome trim to connect to, maybe other singer chamois owners will know.
Found it, item 362
my version of the missing trim
Re: Singer Chamois CNA 476C hot water screen wash
stole this idea from Nods imp, tried hard to try a buy one,but no such luck so made my own,
Tonights project putting the wood back on the door and rear cappings
Re: Singer Chamois CNA 476C Awaiting the engine
Awaiting the engine,
getting close for some movement !!
Re: Singer Chamois CNA 476C 40s filters
I would like to hear peoples opinion on filters for twin 40s, are k&n still the best or would you go for ITG.
Re: Singer Chamois CNA 476C nut and bolt check
Decided to take a the car to have its nut and bolt check and engine start
I made the ambulance glass rear window using 1/4" laminated double shadowlite ambulance glass, its very heavy though, too much for the IMP stays really.
The only thing missing from yours is the rubber surround holding the glass into the back lift up window frame otherwise it looks similar, youre probably better off as youve got it now, looks good still.
Really I suppose if youre going down the Greetham look you need the Astra Mk1 roof spoiler to complete the look, and the front mounted cibies, the spoiler which is now extremely hard to find especially now theres only about 5 of the original cars left on the road.
I wont be at national this year unfortunately my car wont be ready until next year and im not going in anything else wouldnt be right.
All the hard work does pay off
1st at the nationals
