68 stiletto Restoration
Re: 68 stiletto Restoration (SRC 527F )
Hi got the pedal plate out to referb.When looking at the photo the top cly is marked .7 and the bottom is .625 should they not be the other way round?
Just to confirm looking from underneath
The one at the top is .7 clutch why ??
Hi again could someone post a photo how this section should look like at the corner where the 2sections meet is it flush are poss inverted seam spot welded from underneath thanks as I had better sort it before the wing goes on as there is good access at the moment this car is a mass of small fiddly bits
I cant find a picture at the moment, but its a flat lap joint, the flange on the outer front wing tucks under the scuttle and is spot welded from underneath along the seam and then is just smear of seam sealer and then painted.
Looks generally as you have there, 45degree joint but needs to be a little neater of course and the overlap seam/join shows its not ground down flush so it disappears.
If you look on my thread for The Pest on page 7 you can see the original panel your looking for before I had to repair the tin worm myself in that area.
Doing a cracking job there.
Been a very good day today have started to strip down the quater lites and was I bit worried by the state of the rubbers drivers side is passable but not good but passanger very hard also the little handle that locks them was missing
I recalled seeing one in a box of parts that came with the car that I had only had a passing look at 2 years ago so you can imagine my joy at find this new one and a in as good a condiition as the day it was made passenger side too don't know what the 25 RCS means. well cuffed !!
Also got wing back on.
I also forget till I look back what it was like
The number is a Chrysler dealer parts bin number or shelf number where they kept the bit to help the staff locate the item when someone came in asking for one, instead of saying now where did we put that??
All looking supa dupa.
Havent commented much on this but im always looking at the updates , top workmanship I must say
I too love this thread. It's a joy to see the trouble that you are going to on your Imp, Gary. Keep up the great work. Then do mine for me!
My ashtray is now redundant since i stopped smoking 11 months ago , I rarely smoked in the Singer anyway and the ashtrays never been used ,
- pbergs
- Car Model: stilletto
Perhaps I embellished it a tad. They were loose when I collected it in Wiltshire and I had all those problems on my ride home to London, no appropriate spanner to hand. They now behave.
Thanks for all the support .This will be the 1st time I will be coming to the imp national s unfortunately can only make it on Sunday but look forward to meeting some of you and the great little imps of course
- pbergs
This may be of interest. There have been various threads about the low book prices printed for the imp range which did not reflect in any way either the money invested or the true prices restored cars realise. Many cars are sold by word of mouth for substantial amounts and these sales do not reach the price guides. ( see a thread by John Simister) I have just agreed a replacement value for my Stiletto of £10,000 with Peter Best Classic Car insurers . This of course does not mean I could expect to go out and sell my car for that price, but it does acknowledge that to replace a good example of a restored car could involve that kind of money. The car on this thread looks to be that kind of vehicle.It took my five years to find my car..quantify that!
Decided to work my way round the front panel. The lower edge was a bit crusty but with the air box in the way I could not tell the condition of the front crosember so removed the lower edge. Was expecting the worst but there was lots of wax and once cleaned off it was as new behind the suspension mount just a bit on the spotwelded edge that you can see cleaned everything ready for paint
There was a time around 15, 20 years ago or so to have a fibre glass bib spoiler on the front, apparently does no end for the handling especially in crosswinds, but just looks like an add on and most werent particularly bonded on properly, just pop rivet and filler sort of thing, and get scraped, youre probably better off without one now, for originality sake.
Just been wire brushing front panel in where the front grill fits .Its split into 2 one side I can see is for the heater blower but what is the other 3/4 for ?
Horn compartment.
You should have twin ones and there should be 4 fixing holes in the rear bottom of the box for them 2 for each horn.
Hi front drivers side inner arch and front corner cross member next just same as the other side ,inner not as bad this side but corner of wing and cross member are little worse. Bear in mind this is already been restored !!!
Got some bad news today have to be out of the garage by January, that could be a problem as have no where to go, don't want to sell it now not after spending 2 years collecting all the stiletto bits ??? Don't want to sell it for parts it was hard enough getting it all back together
No I'll concentrate on everything underneath so I can get suspension back on ready to move wherever??? The garage is separate but gets power supply from the flats they are sold so will lose power as soon as new owner takes charge I will just go in one day and I will be cut off
The new owner might be a kind old chap not a money grabber he might leave the power on for you, you never know your luck, youll have to take him for a pint.
Front panel lower edge all solid again horn and heater compartment all de rusted and hydrate 80 ready to paint
Front corner now cut off, more jigsaws
New sections made ready to weld in
New crosmember corner welded in
New outer fettled to fit couldn't save this one it was too bad
Did you fabricate that crossmember, Gary? I think mine will need work in that area.
I must say, you are doing a fabulously thorough job on your car. Keep up the great work.
Yes just same as the other side ,kept all the cardboard templates to save time
When fixing the other side had a problem welding the new seem by the front side lights as it was difficult to plug weld from the inside as I don't have a spot welder, so this side I will make up and weld to corner panel first and then butt weld to front panel
Seem remade once I am happy with fit I'll weld to corner and clean up before fitting to to the wing
Also been trial fitting bonnet it hangs over front in middle about 3/4" is this normal it's an early one 2 strengtheners
Early bonnets and later bonnets had the twin (cross) brace, only for a short period did they try them with just the one diagonal, I think around 1970/71 time? but they quickly reverted back to twin as the bonnets were too flexible without.
Not a great photo ,I have a support from the spit to front panel think it may be pushing front panel in a bit in the middle ??
I guess if you aim for a 1/2 over hang you wont be far out, but as I said you need to try the fit with the seal fitted, plus the flange on the bonnet to which the seal fits onto sometimes varies slightly in width too so that obviously moves the seal a little too.
Once you get the spit bracing out of the way you can always jack the front panel out slightly if you need they arent that stiff even with the vertical brace between the airbox and top flange.
Got front corner welded on today bit of a compromise round light as it didn't fit that well but managed to get it there may need a bit more filler but I'm not going to worry about it we work with what we've got don't we ? Its on and that's the main thing
You can always finish it properly and lead load it if need be
Always fancied a go at lead loading ,they say its very difficult to master. A lost skill so to speak
Had a small break been on holls plus got bit down on the car with all the problems with the garage nothings changed but in better state of mind now just think I needed to walk away for a bit
Started re shaping inner arch and welded some temp strip to hold in place before cutting the outer arch off
Then cut outer to give access to repair inner
Removed lower to check underneath well it just pulled off
Some more hidden horror's that need attention under scuttle
Plus old repairs to sort out same as the other side
Could be that many blobs maybe he was trying to write something are sign his work !!! Certainly wasn't conservative on the wire
Its all fixable.
Its all fixable.
I am thinking I will have to cut the bottom of the post off to repair this correctly any advice would be welcome
I think you will, it looks what you might call a bit naff?
Same blind man ??
Unless it was done by a Holey man
Same blind man ??
Welded in front section of inner wing
Also put some top coat on the other side to seal it .I won't touch it again until the whole car needs final flatting
