1966 Sunbeam Imp MKII
whitebuffalo
Car Model: 1967 Sunbeam Stiletto
Post by whitebuffalo »
Here is my new project. It came from Connecticut and arrived in it's new home here in Lancaster Clifornia on 7 August. So now it can start to dry out. No rot found, but some crusty surface rust on the rear parcel shelf and rear left quarter behind the left rear wheel. A few dents and dings, but nothing I can't hammer out. Plans are to keep it mostly original and will do Monte springs and upgraded bushes and shocks. Wheels will be 12x5.5 Cosmics. Will keep it white with red interior and will add a dark red stripe to the sides.
1965 Sunbeam Imp
1967 Sunbeam Stiletto (Rootesy)
Re: 1966 Sunbeam Imp MKII
Remember to keep it looking standard looks virtually completely original at the moment, and the two IMPS next to it? is that a before or after or a bit in between?
Post by colin rooney »
nice looking car hope you enjoy restoring it
whitebuffalo
I do plan on keeping it looking original. The only divergent addition will be the Cosmic wheels and most likely will go bumperless. The other Imps in the background are another matter :o One belongs to Mark Costello (daysineuropa) and the red car is my '65 work in progress, that car will be modified and more aggressively powered with a 930 or a 998.
1965 Sunbeam Imp
Lovely project! As Colin said, I hope you enjoy the restoration. :wink:
whitebuffalo
Connected a battery to the car today. Lights, signals, horn works. Only think not working was the right rear light, but someone had cut the wire so should be able to fix it and the starter solenoid makes no clicking to try to start the starter.
1965 Sunbeam Imp
whitebuffalo
Did a little work on the Imp. Removed the fuel tank and surrounding covers .
Took to cleaning up the area and thankfully all the wiring is in good condition and paint is well preserved.
Next is to work on removing the front suspension and to restore the A-arms and brakes.
1965 Sunbeam Imp
Post by kilty »
Find any Diamondbacks lurking?
Looking good, whitebuffalo. :) The car does look to be well preserved.
whitebuffalo
kilty wrote:Find any Diamondbacks lurking?
Thankfully no Diamondbacks in this car. It came from New York state so very few snakes from that region. Thankfully I haven't found any evidence of spiders and no rodent activity.
I did find a few leftover snake skins in my Austin A50 when I first got it. :shock:
1965 Sunbeam Imp
whitebuffalo
So found these for my car. Thanks to a club member I was able to get the twin SU intake/exhaust manifold and thanks to a Mini club member I found a nice set of twin HS4s. Now I just need a Sport spec motor to fit them to :o
1965 Sunbeam Imp
whitebuffalo
Ok, after a long while, I am back working on my Imp. Was side lined by a car accident and had to focus on recuperating from an injured shoulder, but was without a classic to drive. Had to focus on the car closest to being on the road which was my '62 Mini Traveller. Now that is a drivable classic I can focus on the Imp so it can be a drivable classic. Took it in yesterday to get the title on it and since it was a car from out of state, I had to bring the car along for a VIN verification.
More to come ....
1965 Sunbeam Imp
Glad you're on the mend. :) You certainly cannot put a price on health.
whitebuffalo wrote:More to come ....
Be sure to keep us posted. :wink:
whitebuffalo
So, now that I have the car in my name, YAY! I have dug into the rear suspension. Took the old units out and wire brushed them down to bare metal and then painted in a good hard black paint. Rebuilt the axles and hubs , added the new brake shoes and brake cylinders. New pipes and braided hoses finish off the rear arms.
New shoes and internals
All done and ready to install
While I was at it, I decided to clean up the engine bay and give it a coat of paint in the color I am going to paint the car in as well as add the Spax shocks.
From ugly and unappealing
To a nicer shade of happy:)
And now with the suspension arms and Monte springs installed.
Took the motor out to get the transaxle ready to mate up with the rebuilt motor. Looks grubby, but only has 24,000 original miles
Finally put some time into the Imp after a year. Replaced the old red interior with a better, newer back interior. I also rebuilt the shifter mechanism and installed the radiator , water pump and all new hoses and heater hoses. The front cargo area covers were looking rather dingy so I painted them. Now I need to figure out a linkage set up for the carburetor and hook up some electronics and I should be ready to start her up and drive her for the first time since 1974.
Fresher looking cargo area.
The attachment DSCN3477.JPG is no longer available
Fresher black interior and seats with door capping too.
The attachment DSCN3483.JPG is no longer available
Radiator is in with new water pump and hoses.
Replacing the weather seals so took the windscreen out and will add a new seal.
I also painted the dash panel as it was white and reflected onto the screen when in the sun so now black will blend in.
I also put the new carb in and found a linkage that I bought ages ago and modified it to work on this application. I bought the 32/36 DGEV for a Fiat 850 I had back in 2003 and got a different carb to work for it so had the Weber sitting around all that time.
Now with a scrub and lots of high pressure water
Then it was outside to give the girl a wash for the giggles of it
Engine bay with Porsche Signal Orange in the sunlight
More to come during the week.
1965 Sunbeam Imp
I do like an orange Imp! :D
Firecracker.
Was the engine bay painted using rattle cans? :?: It certainly does give the car some sunshine!
Excellent work! :mrgreen:
whitebuffalo
Yes, three rattle cans of the orange, my trigger finger is tired :lol:
1965 Sunbeam Imp
whitebuffalo wrote:...my trigger finger is tired :lol:
I sympathise, having painted an Imp engine bay using aerosols in the past myself. :|
whitebuffalo
A box from club spares arrived, now I can get to Imping!
1965 Sunbeam Imp
Christmas came early! :D What's next for your Imp then? :?:
whitebuffalo
A mad dash to get the motor and trans in and get it running by the 19th of July :o for a car show. Not at all unrealistic is it ? Darn, can't find the sarcasm button on this keyboard. Well, I do plan on getting the motor and trans in and see how far I can get. If I don't get it running by the 19th I will trailer it to the car show.
1965 Sunbeam Imp
whitebuffalo
Gave up on the idea of trying to rush to get the car to the car show this weekend, rather do it right and enjoy the build than to try to enjoy the car show with the Imp. Will take my '62 Mini Traveller to the show instead.
So, work on the Imp continues, started to build up the motor. Added a new clutch and am in the process of getting the water pump assembly built up. I also added a new release bearing to the 'box and fitted new mounts. Will paint the output shafts to make them look better and keep rust away.
To take a break from the motor I then was able to remove the rear window without any problem. I was ready to break off screw heads and curse a lot, but every one just unscrewed as they should. I then added the new seals on the rear window aperture and hatch itself.
1965 Sunbeam Imp
whitebuffalo
Finally got to work on my Imp. Added disc brakes to the front, switched out the 12 inch wheels for 13 inch and they fill the arches really nicely. It will get lower as the coils settle and the weight of the motor and other ancillaries sit on the suspension.
Today was a productive day, was able to fit engine and transmission as well as the light weight engine mount. The transom panel fits up nicely and I will have to figure out how to mount it to the car.
13 inch wheels with lowering springs.
Engine and transmission finally in place! :thumbs: Note to self, always make sure locating dowel pins are removed from one side or the other, two pins opposite each other makes it difficult to fit trans to motor!
Transom panel fits well, needs holes or brackets to affix it to the car somehow.
1965 Sunbeam Imp
whitebuffalo wrote:The transom panel fits up nicely and I will have to figure out how to mount it to the car.
If its only a skin fix it on using the tapped hole fixing in the end of the rear chassis rails, that the rear bumper would normally use?
whitebuffalo
Yes, it is only a skin and I now see the holes for the bumper so will use them to hold the panel in place, thanks!
1965 Sunbeam Imp
It's coming along nicely. 8)
whitebuffalo
1965 Sunbeam Imp
Looks like youve got an indicator stalk missing? It would help you to fit that before you fit the screen so you can see what youre doing behind the binnacle better, loads of wires.?
The Nun wrote:Looks like youve got an indicator stalk missing? It would help you to fit that before you fit the screen so you can see what youre doing behind the binnacle better, loads of wires.?
Probably has a Floor dip switch fitted as its American spec :)
whitebuffalo
Thanks Nun for looking out for me, but as Dave said, it is a US model so dip switch on the floor.
1965 Sunbeam Imp
Post by 617sqn »
You could replace the missing stalk and use it for an electric screenwash pump. Or front facing machine guns hidden behind the indicator lenses. Rear smoke screen ? Oil spray ? No. Hold on. Being an Imp it with all have that fitted as standard. :D :lol:
Keep the updates coming.
whitebuffalo
Installed the new rear window seals and painted the door window frames and B pillars to have them blend it with the seals.
1965 Sunbeam Imp
whitebuffalo
For those not on Face Book, here is a short video of the car running! Hope to have it's first drive today after 43 years of being off the road.
https://youtu.be/HuzvaoP6hTo
1965 Sunbeam Imp
whitebuffalo
80 miles of driving and loving every minute of it. Got to get use to the reverse being to the left and back as opposed to right and back on the Minis. I have stalled it a few times trying to get the clutch catch just right. Got to remember to take it out of gear and let go of the clutch as if you try to push the clutch in and start it, it turns very slowly, if clutch is released then it turns properly.
1965 Sunbeam Imp
Post by 617sqn »
That will be down to the release "bearing" being made if a graphite material which isn't as slippery as a proper ball race bearing. When you have the conversion done, the revs rise when the clutch pedal is pressed down. The opposite of the original type. :D
whitebuffalo
Thank you, good to know. I was worried that I had the RPM too low as I have it idling at around 1000 right now and seems fine, just dips down when I push the clutch in.
1965 Sunbeam Imp
John Simister
Post by John Simister »
That tendency for the revs to drop when you press the clutch pedal is greater with a Quinton Hazell clutch like yours. It has a stronger spring than the original Laycock type, which gives a heavier pedal and slows the engine more. My car is the same, but I've managed to find a NOS Laycock clutch which will make the car nicer to drive.
Post by 617sqn »
But the modern bearing is even better and eliminates the tendency to stall at junctions completely, plus you can reduce the tick over rate anyway, as a bonus !
Dion
Car Model: Chamois Mk2
Post by Dion »
617sqn wrote:But the modern bearing is even better and eliminates the tendency to stall at junctions completely, plus you can reduce the tick over rate anyway, as a bonus !
Is there a supplier yet for a modern ball racing bearing as replacement for the old graphite bearing? Or is this still a DIY thing?
