ALJ117K
Re: ALJ117K
Post by ImpManiac » Sun May 22, 2016 12:13 am
Yep! Looks good! :) When will it be roadworthy again?
imp-aus-ter
Car Model: 6x Hillman imp '63 '64 '66 '67 GT(Aus), '67 '67
Re: ALJ117K
Post by imp-aus-ter » Thu May 26, 2016 4:50 pm
I have been researching dynamat and looking for alternatives. One thing I read, is that completely covering every square inch of the car promotes mildew and doesn't help the sound deadening effect any more than having patches in the middle of panels roof or whatever? It is the centre of panels that causes the noise amplification, so I reckon, where you see rootes has put the deadening, like in behind the elbow bins next to the back seat.... put it there a bit bigger than they used... where the black gunk is in the footwells etc.... but prolly a good idea to use the 10mm stuff behind the back seat (the whole back seat area and back shelf) and yes, painted black should look better.
The dynamat ceiling lining is like 10mm thick, they have 6mm and 2mm for other areas... I will prolly get the black chinese stuff because I am a cheap rrr's :lol: If it doesn't work, I will double up... there is a bulk pack with heapsof metres of the chinese one :)
There are cars better than an imp, but when rated in 'smiles to the gallon' not many beat an imp
Re: ALJ117K
Post by The Nun » Thu May 26, 2016 8:32 pm
will jack wrote:. A repro Sunbeam badge has been fitted. Its got four holes on the crown. I think I read somewhere that it should only have three. :o ..
No one will notice the badge, but they might see the front strips are upside down? :wink:
will jack
Car Model: Californian, Sunbeam Sport
Re: ALJ117K
Post by will jack » Fri Nov 11, 2016 1:41 pm
Stripped the steering rack for inspection and fitting new rubber boots. It all looked perfect. Filled it with Land Rover hub grease. Fitted adjustable track rods on both sides, and Fiesta track rod ends.
I've looked on the dvla site for the car a couple of times, and never found it listed. I had assumed it was because the car has been off the road for so long(last taxed 1983). I only noticed that it was listed as a Hillman when I scanned the old tax discs. I'm not sure how much grief that's going to cause, to get sorted out.
will jack
Re: ALJ117K
Post by will jack » Tue Jan 31, 2017 2:29 am
The rack is refitted now, along with the front brakes and brake pipes. A new servo is fitted.
I think the tank was modified by Hartwell so that the wider rims would still fit in the spare wheel well.
will jack
Re: ALJ117K
Post by will jack » Wed May 15, 2019 12:30 pm
Finally finished - or at least, finished enough to pass an MOT test and be reasonably usable.
philgsmith
Car Model: Imp - deluxe, BMW320d Touring, MGF, MGTF
Re: ALJ117K
Post by philgsmith » Wed May 15, 2019 12:51 pm
Looks lovely Will - well done.
Phil
When you're in a hole - stop digging/too much to do, too little time
Re: ALJ117K
Post by bazzateer » Wed May 15, 2019 1:11 pm
Nice!
Re: ALJ117K
Post by colimp66 » Wed May 15, 2019 3:58 pm
Very nice , well done.
Thanks for sharing.
Col .
