I would think your correct.The Nun wrote: ↑Fri Mar 01, 2024 10:23 am Have you got any that line up spot on? They all seem to be slightly off centre but as long as the contacts are parallel with each other and mate up, being slightly off centre wouldn't make too much difference to their operation?
I use Cooper S contacts with the stronger spring and fibre heel from mini specialists which seem better made to me.
This set is marked 180 while another that looks the same is marked 070, that set looks ok.
The genuine Lucas has a small ridge on the underside where the screw fits, I guess that will grip the base plate better?
I used the Cooper S points on my race Imp back in 1971 but they are really Rocking Horse Poo to find out here!
