Amy's Chamois Coupe
- Been thanked: 92 times
Re: Amy's Chamois Coupe
Top work going on here folks .
That inner rear arch shows just how crusty it was .
- Car Model: Bevan recreation/imp Super/Imp Van/Commer Van
- bdann0875
- Car Model: Sunbeam Stiletto
Great job. Wish I could do what you are doing. I can do some welding but not what you have done. Top job there!
1968 Sunbeam Stiletto
1998 Fiat Punto 60S
1998 Fiat Punto 60S
- Has thanked: 152 times
Thanks for the kind words but its not that difficult, the more you do it the easier it becomes, that and buying the right tools but still lots I'd like to get.
Rear quarter off
Inner rear quarter being readied to replace accident damaged one.
Little bit of rust in corner of window to deal with
Rear quarter off
Was it difficult to remove the rear quarter? Will the same panel be going back on, Scott?
Really excellent work. I love the fabricated repair section you have let into the bottom of the passenger side A-post. Really nice.
Paul
To remove the rear quarter simply drill out the many spot weld and chisel off, I have a NOS rear panel which will make the replacement easy using the spot welder.
Notching up the injuries on Amy's car - today when removing the last of the rear quarter twisting to break the last of the spot welds holding it when it suddenly released and hit me in the face giving me a nasty 3" cut on the cheek fortunately not too deep.
Line up of the potential culprits
It was the white one
Inner panel removed
Inner panel removed
Ouch! Still, I think you are winning this particular battle, Scott.
If it were my car, I'd leave the vents. It's up to you, of course.
Nice work!
Is Amy assisting you with the restoration of her car? I am just curious.
Nice work!
Yes, on Monday she repositioned the axle stands while I lifted the shell.
We did discuss colour schemes and interior options while walking the dog
- Dom
- Been thanked: 12 times
Great thread! looks like a lovely little challenge you have on your hands here! be sure to keep us updated with pics! looks great so far!
Dom Smith
69 Sunbeam Stiletto XPA175G
Bought a book on origami so thought I'd give it a try
Couple of folds later and I had this
Little mod - chassis leg boxed in
First trial fit of rear quarter
- Car Model: Imps
Superb Scott. Not an easy one, deciding on the vents eh? You could just blank them off inside and fill it with waxoyl.
The idea was to cut them out, plate over the hole and replace the vents, effectively closing off the vents but retaining the look thus preventing water getting in - well at least via that route.
However, not sure if it would look better smooth.
- Car Model: imp super 1975, imp super 1973, imp super 1971
Personally I'd be inclined to keep them for the looks, however most people would never think twice about them
Great work!
Great work!
- impmann
- Car Model: ...er, one or two
- Has thanked: 18 times
- Been thanked: 69 times
My 2p - personally, I think it will look odd without them. I also am not 100% convinced that water can creep up into them in any great quantity, tbh. I agree that the rear box section rots out on coupes, but this is more often caused by water collecting along the U section behind the engine lid and corroding through, in my experience or holes under the rear window surround or water leaks into the car by shonky rear screen seals.
Washing the car with a hose certainly can get a lot of water in, lots of work needing done so little improvements easily incorporated at this stage.impmann wrote:My 2p - personally, I think it will look odd without them. I also am not 100% convinced that water can creep up into them in any great quantity, tbh. I agree that the rear box section rots out on coupes, but this is more often caused by water collecting along the U section behind the engine lid and corroding through, in my experience or holes under the rear window surround or water leaks into the car by shonky rear screen seals.
- Car Model: stella sunbeam stiletto.libby 75 imp deluxe
excellent work scott
keep it up
keep it up
Good to see the scuttle panel solid
Small section of rust at bottom of A pillar - cut out and replaced
Bottom of inner wings constructed
- ChrisBenoy
- Car Model: Clan 'E' 998
- Been thanked: 1 time
^^ What Chris said. I like what you did with the A-post repair. I think my car might need some work to the nearside A-post. I like your whole approach to simply getting on with cutting out the rot and sticking in fresh metal. My hat is off to you.
No progress on Amy's car as I've been playing with my latest project 2003 1.8i MX5 accident damage to osf suspension and wing but otherwise very clean car.
Suspension now changed, panels replaced, timing belt replaced with 4 pce kit, brakes fully refurbished so time to tackle the chassis rails.
Far from rotten even hammering them failed to hole them but signs of internal corrosion going on from the swelling. It might be a couple of years
before it becomes critical but it will happen so might as well tackle it now when it already stripped.
Drilled out the spot welds for the inner section and then cut out the chassis rail.
Folded the inner section and outer panels and spot welded them together - trimmed to fit so the front fit into the front of the chassis leg and
then swings up at rear. Captive nuts and studs welded in.
In position prior to welding.
All welded in.
And then the rain came on Rest assured next post will be back on topic
All welded in.
- lukesoanes
- Car Model: hillman imp
Hi
This thread is amazing last time I looked on it there was a rusty Coupe has someone swapped it for a new shell??
Out of interest the did you use a shrinker/stretcher to make the panel below? if not how did you make it? i've tried several times to produce a flanged curved panel but every time i end up slitting it and welding it back up! yours however looks perfect!
1976 imp super
1973 clan crusader
1985 fiat 900e amigo camper
1984 mini 25 turbo to be
1985 mini supercharged 1100
1994 audi 80
1973 clan crusader
1994 audi 80
Yes, shrinker/stretcher great little tool
http://www.ebay.co.uk/itm/20-METZ-Shrin ... 996wt_1170
Wow! Serious skills on display there, Scott!
Well where does the time go 2 months with no progess on Amy's car.
Today tidied the garage
and started to clean up the floor ready to weld in the floor edge, until Karen came home and I stopped to give her Imp the once over as taking it for its MOT tomorrow.
nice work scott
is the English wheel any good
that and a shrinker are on my wish list for xmas
unless your going into panel production
thanks for the comments on libby
keep up the great work
Chris
Not used it yet, still to get sandbag and mallets to have a go at inner arch.
However can highly recommend shrinker/stretcher as a tool to have.
Today started on welding in the Keith Lennox Floor edge - very good fitting panel and finished cleaning the rust from the inner panels and floor.
- bdann0875
This is serious work going into this resto. Well done. Keep us updated. Maybe you will treat yourself to Chrismas Day off from working on the car?
1998 Fiat Punto 60S
1998 Fiat Punto 60S
- Car Model: imp californian,imp estate
Thanks for the comments, had enough time away from the Coupe, time to get stuck in.
Today moved onto the front
Decided that the easiest way to tackle the repair was to remove the whole front panel
Leading edge in pretty good order
Inner arch sound
Cleared up
Leading edge removed
Started cutting out rusty bits
Made some space by sticking the door and rear quarter on, almost looks like a car again
Inner arch sound
Cleared up
- Lars Hagermark
- Car Model: .
Thanks for posting all this. I think you're doing a very good job with the car.
I've bookmarked this thread for when I get down to my 2 saloons, both probably in need of similar work.
Today made some repair panels and got them welded in, removed remains of wing. Somedays there seems to be little to show for the work done
great work scott
should be a cracking car when its done
keep it up
keep it up
Well it will be rust free - even where you can't normally see I don't plan on restoring this one again.chris d wrote:great work scott
keep it up
It would probably have been easier starting with a less rusty one but then it wouldn't be "Turner" just another Imp.
Amy has some interesting ideas for him
Really excellent work Scott.
Is it difficult removing panels like the front panel and wings? I ask because I would prefer to remove mine, as it would really help me to get the rot out of all the nooks and crannies. Do I just need a spot weld drill or three and a lot of patience?
Keep up the brilliant work. And please keep the pictures coming.
Paul
Removing the front panel and reusing not really a viable option unless you are replacing the wings anyway, the wings I would imagine nearly impossible to remove and reuse.
Ok, Scott. Thanks. I think that my wings are okay, so shall leave well alone.
- jetmech
- Has thanked: 1 time
I really hope that I wont have to go to these lengths when I eventually restore my wifes Imp, but threads like this help to convince me that what ever I find will be repairable.
Keep up the excellent work and thank you for sharing the progress with us.
Simon
Simon
This weeks progress
Inner arch is solid but rather than try to remove the surface rust decided to replace
First use of english wheel to produce
Scuttle panel although initially appears ok when wing remains removed bottom edge a bit thin so
Reconstruction
Modified so any water is directed away from the scuttle edge
Drain channel then added to let any water out
Weld cleaned up really nice
Floor edge replace again nice fitting panel from Keith Lennox
Reconstruction
Stunning work, Scott. The car's shaping up brilliantly!
A panel coming together
Wing support panel back in
Made up inner wing return and shaped it using shrinker/stretcher to match new wing.
Today cleaned up the welds
Still some welding and cleaning up to do but will be easier when its inverted.
Couldn't decide whether to have a go at rear inner arch or start on the other side
in the end did neither and started strengthening the crossmember and trailing arms for local members rally replica
Been putting of inner rear arch - finally decided to give it a go.
1st attempt seems a bit wide
Marked out metal for repair
Don't have sandbag or mallets so improvised
Metal bashing begins
English wheel was very effective at removing hammer marks but not right shape
In the end realised need more practice needed so resorted to cut and shut
Birthday and Christmas got in the way of play but not totally without Imps
they even included rust on the wheel arches which BKS does not have
Finished of the floor
Moved onto rear parcel shelf which has areas of pitting due to being in contact with damp underfelt.
