Irish Clan Restoration
Oscarmax
Car Model: Clan
Post by Oscarmax » Fri Jul 05, 2013 3:53 pm
Leaky sunroof removed
Re: Irish Clan Restoration Q717 LKH
Post by impmann » Fri Jul 05, 2013 7:07 pm
You might change your mind about the sunroof when its on the road - Clans get very stuffy and airless in my experience without a sunroof.
Oscarmax
Car Model: Clan
Post by Oscarmax » Sat Jul 06, 2013 3:55 pm
x
Post by ChrisBenoy » Tue Jul 09, 2013 6:40 am
Generally speaking you will get some throughflow in an irish clan, it comes through the two small vents at the front and over the wheel arch into the cabin. Rarely do those sunroofs actually work and you can't get spare parts for them.
As for front rad pipes, with a little opening up of a couple of bits of bulkhead you can run 25mm rubber hoses through the sills and into the front, its the setup that i'm currently running and is working nicely.
Oscarmax
Car Model: Clan
Post by Oscarmax » Tue Jul 09, 2013 7:55 am
x
Oscarmax
Car Model: Clan
Post by Oscarmax » Tue Jul 09, 2013 4:38 pm
x
Post by Lotus-e-Clan » Tue Jul 09, 2013 5:57 pm
..and if it's anything like the glass one I took out (it looks similar) ...it''ll weigh a ton!
I haven't glassed my roof in yet mind. I'll I've done so far is fit a very thin carbon-effect black ABS sheet cut to the same shape as the sun roof and attached with about 30 or 40 tiny countersunk head allen bolts - doen't look too shabby unless you're really fussy ...and weighs NOTHING!. :lol:
Oscarmax
Car Model: Clan
Post by Oscarmax » Tue Jul 09, 2013 6:44 pm
x
Post by ImpManiac » Wed Jul 10, 2013 9:43 am
Where are you located, Oscarmax? :?:
Oscarmax
Car Model: Clan
Post by Oscarmax » Wed Jul 10, 2013 12:18 pm
Sunroof filled in still needs some work
Keith 'Supaimpy' Laming
Car Model: Imps and Clans
Post by Keith 'Supaimpy' Laming » Thu Jul 11, 2013 4:27 pm
viewtopic.php?f=33&t=9221
Quite a long job glassing up the roof and tricky to get the profile looking right, mines not perfect but a casual glance now and it doesn't appear too bad
Keith
Dorset ACO
Post by colin rooney » Thu Jul 11, 2013 6:03 pm
Am sure I posted on here last night but I cant have hit the submit button :lol: any way give chris a ring at fiberclass real nice bloke if you want the best advice tell him I put you intouch and he wont think your just a time waster 07747367067
Post by Lars Hagermark » Thu Jul 11, 2013 7:33 pm
You hit the send button Colin, but for the "How to" in the members section. Your helpful advice is all there to be seen. Hope Oscarmax will find it.
Post by colin rooney » Thu Jul 11, 2013 9:57 pm
Lars Hagermark(DJH705) wrote:You hit the send button Colin, but for the "How to" in the members section. Your helpful advice is all there to be seen. Hope Oscarmax will find it.
Ah im glad you found it I was starting to think I was cracking up even more than I am already
clanceltica
Car Model: clan crusader
Post by clanceltica » Sun Oct 06, 2013 7:50 pm
How is the clan comming, i live in near goginan nr aberystwyth, just finished mine after years of work it was my retirement project, if you are in the area call. 07989303614
Oscarmax
Car Model: Clan
Post by Oscarmax » Sun Oct 06, 2013 9:02 pm
Door hinges rebuilt
Oscarmax
Car Model: Clan
Post by Oscarmax » Fri Oct 18, 2013 6:16 pm
Seat belt plates
Oscarmax
Car Model: Clan
Post by Oscarmax » Tue Dec 10, 2013 4:35 pm
Engine mount
Oscarmax
Car Model: Clan
Post by Oscarmax » Tue Jan 07, 2014 4:45 pm
Roll cage suspension mounts
Oscarmax
Car Model: Clan
Post by Oscarmax » Tue Jan 07, 2014 4:47 pm
Modified and strengthened cross member
Post by ImpManiac » Tue Jan 07, 2014 5:13 pm
Those pieces of ironwork ought to spread the load of an impact quite nicely. :wink: And they shouldn't rust any time soon. Nice work!
Oscarmax
Car Model: Clan
Post by Oscarmax » Sun Jan 12, 2014 12:38 pm
x
Oscarmax
Car Model: Clan
Post by Oscarmax » Sun Jan 12, 2014 12:42 pm
x
Oscarmax
Car Model: Clan
Post by Oscarmax » Sun Jan 12, 2014 12:43 pm
x
Post by ImpManiac » Tue Jan 14, 2014 10:18 pm
Nice idea, tying the cage feet into the subframe. Should be good and strong. :D
Oscarmax
Car Model: Clan
Post by Oscarmax » Mon Mar 03, 2014 4:48 pm
x
Oscarmax
Car Model: Clan
Post by Oscarmax » Mon Mar 03, 2014 4:52 pm
x
Post by Lotus-e-Clan » Mon Mar 03, 2014 6:31 pm
Dramatic stuff! :D
If you are using it as a road car in all weathers (as well as comp work) you might want to consider fitting strategic plastic panels to protect the engine bay from road dirt off the rear wheels.... and /or reducing the wind/drag on the inside of the back panel?
Post by bks974c » Mon Mar 03, 2014 6:47 pm
Or just mudflaps ?
Oscarmax
Car Model: Clan
Post by Oscarmax » Mon Mar 03, 2014 6:51 pm
x
Post by The Nun » Mon Mar 03, 2014 7:10 pm
Is the electric shopping cart your normal everyday transport until the Clan is ready? :o
Post by Lotus-e-Clan » Mon Mar 03, 2014 7:26 pm
Ok. I Forgot about the turbo.
That said. If I went the turbo route I would still want to isolate the engine bay so it was relatively draught-free and therefore I'd try to position radiators and intercoolers specifically for cooling outside of the engine bay - OR isolated /ducted and air-flowed within it with no hot air leakage within the engine bay.
In an ideal world excess air circulation around the engine should be unnecessary ie all cooling should by via ducted /isolated rads/intercoolers. OK that might be a big ask in terms of space and location but If you keep the rads /turbo open/un-isolated within the engine bay then temperatures will tend to go up if hot air can't exit efficiently.
I have now isolated my rear rad air flow -but before I did that, the hot exit air within the engine bay (mine is a reverse flow rear rad) just added to the overall temperature load ...I'm aiming for complete isolation of the engine bay but it's a slow process 'cos the wife is stopping me from buying a set of high lifts ramps atm - ramps would make the job so much easier! :evil:
Oscarmax
Car Model: Clan
Post by Oscarmax » Mon Mar 03, 2014 8:05 pm
x
Oscarmax
Car Model: Clan
Post by Oscarmax » Mon Mar 03, 2014 8:06 pm
x
Post by Lotus-e-Clan » Mon Mar 03, 2014 8:23 pm
Mind you, the cooling need for a short-course sprint car is not equal to a long-run endurance car - the former may never get it's oil warmed despite 168 BHP from a turbo and the almost constant use of WOT (IIRC Eric never even ran an oil cooler at one point!). Whereas the latter will become systemically heat-soaked sooner or later - even on part-throttle runs - ie road car cooling is usually designed to deal with a wider range of operating conditions.
Oscarmax
Car Model: Clan
Post by Oscarmax » Mon May 19, 2014 6:09 pm
x
Oscarmax
Car Model: Clan
Post by Oscarmax » Mon May 19, 2014 6:13 pm
x
Post by ImpManiac » Tue May 20, 2014 1:14 pm
The car seems to have progressed well. :) Are you going to construct a removable rear panel?
Keep up the great work. :wink:
Oscarmax
Car Model: Clan
Post by Oscarmax » Tue May 20, 2014 1:38 pm
x
Post by ImpManiac » Tue May 20, 2014 2:58 pm
I just read your other posts under your other thread on the subject. :wink: Excellent stuff! :D
Do you have any idea when the car will be ready? Will it be at the Imp Club national at Huntingdon in late July and early August of this year, for example?
