libby the deluxe
basil imp
Car Model: imp super 1975, imp super 1973, imp super 1971
Re: LBW 514N hillman imp deluxe
Post by basil imp »
Those suction fed blasters take a while Dont they? Started doing a set of wheels once, think I ended up eating most of the grit :lol:
libby the deluxe
a bit of progress over the last 2 days
painter organised
industrial paint stripper found and bought,waiting to collect with the painter.(cant sell to general public).
bought a fibreglass stripping wheel and did the inside of the bonnet.(might as well start with the awkward bits).
treated with kurust because there is rust in the metal (common late imp problem).
ive left the back edge of the bonnet in paint because I tried to remove the bracing to get underneath but you cant get at the spot welds without going all
the way through so a bit of welding to sort the pilot holes.also the front edge has been welded inside so that is to sort.but no progress until next day of (Wednesday)
after ive serviced the jag for its mot.
pictures below,comments good or bad welcome
cheers chris d
Lovely work, Chris. :D :D
I've not heard of a glassfibre stripping wheel. Do they work well? I am guessing so, based on the evidence of your pictures.
hi paul
yes they work well
I got one for the angle grinder,you can also get them for the black and recker drill
have a look on the bay under stripping disks, should come up.
also do you know how to change the title of my thread,need to put libby on it
cheers chris d
Chris, let me know how you want the title to read (on here or via PM) and I'll change the title of the first post for you. I think that should do it. :wink:
Thanks for the information on the discs. I'll keep an eye out. :)
chris d wrote:h
cheers chris d
Go to the very first post in this thread , click edit , alter the subject to read what you want , click submit and the new heading will appear
basil imp
Post by basil imp »
ImpManiac wrote:Chris, let me know how you want the title to read (on here or via PM) and I'll change the title of the first post for you. I think that should do it. :wink:
I think they may be similar to polycarbide discs?
Re: libby the deluxe
yes its polycarbide wheel not fibreglass wheel (dementia getting the better of me)
thanks basil imp for the correction. sorry im for the confusion.
thanks dave for the tip on changing the thread title.
should be done now
cheers chris d
basil imp
Post by basil imp »
chris d wrote:yes its polycarbide wheel not fibreglass wheel (dementia getting the better of me)
should be done now
cheers chris d
It's cool :D there really good arnt they? I find though Dont go for the cheap ones, dearer ones last lots longer in my opinion :)
sammy the sturgeon
Post by sammy the sturgeon »
Don't press on with them!!! they wear away alot quicker- if you find a balance so they firmly hit the surface they work very well, and last!!
I bought these and were very impressed with them
http://www.ebay.co.uk/itm/120845663557? ... 1438.l2649
yes that's the stripper I used.
but got one for the angle grinder.
thanks paul for telling me about them in the first place.
they are very good at removing paint and rust
just got the rest of the car to do.
might need another wheel though :lol: :lol:
going to try industrial paint stripper as well
more to follow once ive collected it
a little bit more done
finished stripping the bonnet down and applied kurust.
got the industrial paint stripper
have to use it outside,but the sun came out so will have to try it later.
back to the sanding wheels.
started on the rear crossmember,half done
a couple of neighbours were unhappy about the noise,
so had to stop early
comments good and bad
cheers chris d
Solid progress, Chris. :D That bonnet looks to be in decent shape at the front, unless my eyes deceive me.
hi paul
the bonnet is not to bad
plenty of pin holes so going to fiberglass and fill it
I don't think it warrants cutting the panel apart
going to be use more than stella hopefully
so probably going to get scratched and stonechips anyway
cheers chris d
Imp025 Imp005
more progress
yesterday and today I managed to bare metal the front end and paint with kurust.
I used the polycarbide wheel and some industrial paint stripper.
the polycarbide wheel is brilliant but noisy on large panels. (vibration etc)
this upset the neighbours last week.hence why I am trying the paint stripper this week.
its a bit messy as well as hazardous,so must be used outside with gloves etc
sand the surface and apply,wait 20=25 mins for it to react then scrape away.sounds easy :!:
theres 4 layers and it does a couple at a time so time consuming etc.
it is recommended by the painter etc. not nitromors.
this morning I made a start on the heater box with the stripper,then after half an hour I had a visitor
Bradford council environment officer :shock: :shock:
wanted to know why I was running a business from a private house :!: :!: :?:
he had reports of excessive noise and complaints from neighbours that I was working all hours.
I asked him how this was possible seeing as I drive a truck 5 days a week and this was my hobby.
he basicly said that if there was any more complaints he would be back.
he went so out came the poly wheel and the black and recker,ear defenders and mask for me. plenty of noise for the neighbour
who incidently is 4 houses away and has double glazing.
watch this space to see if im locked up
dought it, I know the law about noise etc
pictures for your approval
basil imp
Post by basil imp »
Wow looks great! :)
Nice work, Chris. :D
It sounds as though you need to find some dirt on your neighbour and serve it up to them on a silver platter. :x Loud music for hours on end? Friends coming and going at all hours? There must be something. Report them for it, no matter how trivial. :idea:
Gaffer
Car Model: Sunbeam Stiletto and an Imp project
Post by Gaffer »
Hi Chris. Was your neighbour a Mini diver by any chance :?: :?: :o
Keep up the good work, but quietly :lol:
Pete
Trying to keep the faith.
Post by benwick3 »
A few tips about your problems with neighbours and noise. I know because I've had the same problem for years. Visits from the council, environmental health, planning etc, along with recently regular visits from the police. The last was because I had the audacity to start one of my Clans, fully road legal, at 7.20pm!!. That resulted in an afternoon visit by the local PCSO who wasn't too happy when I refused to limit working in my garage to daytime due to having to work for a living. Also didn't like me pointing out that noise nuisance was a civil matter and that I could see no reason why in my opinion she was wasting her time and the taxpayer's money. Her answer to this was that it could be come a police matter resulting in me being served with an ASBO!
The one thing I've learnt, however, is to keep the Council on your side. Point out politely that you are just pursuing a hobby. We found the council officers to be very open with us and in fact they could see no problem. What they did say, however, is that when they receive a number of complaints from the same person and they have investigated and found no problem then any further complaints, even if they may be justified, tend to be quietly put to one side and ignored.
Despite it being annoying I have restricted any noise to what I consider reasonable hours, i.e. 9.00pm, but I still tend to work in the garage to far later than that. Another thing I do is keep a record of the times when I'm making any noise, even when I start up one of my Clans and go for a drive. If the Council decide to proceed further with a complaint it is usual for them to require the complainant to keep a log of the times of any nuisance and your own records can be very helpful in providing a response. It's even worth letting neighbours know when you will be engaging in noisy work and roughly how long it will take. A visit to apologise when you have been noisy later than normal is always worthwhile as its shows that you are being considerate.
All a bit of nuisance but don't let them get you down and keep on with the good work.
Pete Richards.
p.s. When they come looking for help when their car won't start, as they usually do, just politely decline on the grounds that you don't want to cause a nuisance!
That sounds like excellent advice, Pete. Thank you! :) Mental notes made.
Neighbour disputes :roll: Glad I don't deal with them any more. :D Also glad that my neighbours are great (so far!).
Post by benwick3 »
The sad thing is that most of mine are. One of my nearest was a little disappointed when he moved in as at his previous house his neighbour was always working on hi V12 E Type.
long_gone_John
Car Model: 3 sal ('74/'64/'64)-all gone!!
Post by long_gone_John »
benwick3 wrote:The sad thing is that most of mine are. One of my nearest was a little disappointed when he moved in as at his previous house his neighbour was always working on hi V12 E Type.
....well, working on my modern [in the back lane, behind my terraced property].. Oil/Filter.. a neighbour, with whom I have been on 'nodding terms' with since moving in, ambled past and said "Ayye..busy?". I said it was just the usual bits & bobbs... he continued "Ayye..binn done it all, Ayye.. too old, got rid of mee car now"....
great old giffer, bet he's wrestled with a few recalcitrant Morris' and Pops!!
LGJ
TooMuch power.. is not quite enough ;<)
875- GGR 640N - Scrapped
930- 533 KNX - Stolen
BV998- 884 KOE (Ex Sidecar motor!!)
sammy the sturgeon
Neighbours! on one side I service their cars every year for them, joined to them I recovered a minibus for them so they are ok with me, across the road are the nebby neighbours who know everything thats happening on the street, which is ok as I know someone is always watching if I'm away!
The other side of me complained about the dogs barking when I used to have them, and complained to the environmental health about it - in between the letter and the visit i set up a video camera and recorded him, with a stick over the back fence, banging it on the window of the back door and getting the dogs to bark, environmental helth had a lovly police man come and watch the video and have a word with him next door and I haven't heard a peep out of them in the 10 years since!
I do worry that he makes his own firework and blank bullets for his country and western weekends in his shed though, but his use of the bench grinder till ten at night just gives me 'ammunition' (a pun :D |) it I ever do make any noise.
Annnnny way - Libby
shes looking good and solid, you should be thankful that the paint is so tough, it looks like it has protected her well, the bonnet and front valence look good without too much crud underneath it all.
keep at it mate - you know what it feels like at the different stages!
Paul
stilettohusky
Car Model: 1967 Stiletto NUT325F, 1968 Husky YRA461G.
Post by stilettohusky »
Hi Chris, all looking good,is the 4headlight panel still in the frame? If you need any front floor repair sections I have left and right front floor sections cut from well under sealed car are in great cond, they are left over from my Husky rebuild if you can use then I will bring them back from Hartlepool. Keep up the good work, I understand they have a good panel repair shop in Armley Prison.
hi everybody
thanks for the replies,
I know what you mean im, but I cant lower my standards to theres.
will see what happens on Wednesday when I continue with libby.
I might bite the bullet and shut the garage doors but well see
cheers chris d
Imp025 Imp005
a little progress
after running around with stella yesterday only managed a few hours today.
front slam panel and off side wing cleaned to bare metal and kurust applied.
no noise police so will carry on next week.
pictures for your comments
cheers chris d
Imp025 Imp005
sammy the sturgeon
stilettohusky wrote: I understand they have a good panel repair shop in Armley Prison.
:lol: :lol: :lol: - not far from you either Chris- and i'm sure Sue would cope!!!
i stick with what I said earlier - under that paint it looks very solid.
good going mate
Looking good, Chris. 8) Kurust seems to work well, doesn't it. :wink:
a little bit more done today
bonett gutter and near side front wing cleaned to bare metal and kurusted.
of down sarf tomorrow
grandson is having a birthday party so having 4 days playing tourist in London
so back to it next week
cheers chris d
Imp025 Imp005
The nearside wing looks good, Chris. It's a pity about the pinholes in the scuttle panel but I guess they're fairly straightforward to repair. :)
imp 50 goes to the palace
had a good time in London
now back to the graft.
if the neighbours complain about the noise,picture 2 will come in handy :lol: :lol: :lol:
cheers chris d
Imp025 Imp005
Post by colin rooney »
When were u down chris we could have got together for a coffee
hi col
me and sue were staying at Walton on thames Thursday-sunday
gransons birthday on the sunday
so played tourist Friday Saturday
walked around imperial war museum. the mall.the palace.trafalgar square,the usual tourist bits.
then sat went to brooklands.what an brilliant experience.
if I known you were around col I would gladly have met up for coffee,
might have to come down early next year so will give you a shout
cheers chris d
Imp025 Imp005
had a good day in the garage today
windscreen frame, scuttle panel and half the roof cleaned to bare metal
them polycarbide wheels are realy good
still on the first one
cheers chris d
Imp025 Imp005
Yeh let me know if your down again ,you want to get some wash etch primer, some times called acid etch primer on them bare panels before the cold weather comes
keep up the good work
hi col
yes will be in touch next time I come down
the panels will be painted in kurust to day
should stop the rust coming back
then etch primer etc
cheers chris d
Imp025 Imp005
few more hours on libby today
managed to finish cleaning the roof to bare metal
then applied kurust to all the fresh bare panels
more tomorrow
cheers chris d
Imp025 Imp005
You've been busy, Chris. :D Are you still on the first carbide wheel? I may have to get some of those. :wink:
last update until next week
back to work tomorrow for a rest.2am start :lol:
windscreen and roof in kurust
osr wing cleaned to bare metal
bottom section of wing needs repairing also a few pin holes in rear of roof.
a bit of damage to the wheel arch edge also needs a repair,found loads of filler in wing section.
paul yes im still on the first polycarbide wheel.they are realy good if you don't press on them to hard,mine are for a drill not an angle grinder.
cheers for now
Imp025 Imp005
