TMF104F Stiletto 2nd place at IMP50 Perth!
- bdann0875
- Car Model: Sunbeam Stiletto
I have owned this Stiletto since 2001. In 2002 I had the car restored and the plan was to use the car occasionally throughout the year as I was using my trusty but rusty Californian as my daily hack...In 2005 the Californian's tin worm got too bad so had to reluctantly scrap her.
This meant the Stiletto had to be used as the daily hack, all year round in snow , rain, whatever mother nature threw at her! The consequence of this was the return of the tin worm, so late last year I decided to restore her for a second time, but as I now have my wife's old 1998 Punto to use, I can hopefully keep her in good order for longer!
Here are some photos just before stripdown in October 2012.
Not looking too bad.
Some rot in the arch and bottom of windscreen.
More rot getting into the engine cover.
More photos soon.
More photos soon.
1968 Sunbeam Stiletto
1998 Fiat Punto 60S
1998 Fiat Punto 60S
- bdann0875
Re: TMF104F Stiletto restoration
The stripdown begins!
This is my luxury garage/workshop!!
1998 Fiat Punto 60S
1998 Fiat Punto 60S
- bdann0875
Some pitting under the vynil roof.
Some grot in the A pillar.
1998 Fiat Punto 60S
1998 Fiat Punto 60S
Eeeeeeek !
Good grief : Now I see why you wanted to give it a make over. Not a great advert for a vinyl roof IMHO
- bdann0875
Yeah, some of the rot was by not having that wonderful thing called "hindsight"... Basically, when I had the car sprayed last time, the guy said it wouldn't need lacquer on the roof, only the base coat, as it would be covered with vynil. I didnt think about the lacquer would also protect the roof from moisture/sweating under the vynil!
Oh well, we learn by our mistakes.
1998 Fiat Punto 60S
1998 Fiat Punto 60S
- bdann0875
The tape was only to stop the water getting in!
One area welded up.
Rot in the same place on the oposite side!
1998 Fiat Punto 60S
1998 Fiat Punto 60S
- bdann0875
Cant believe the rot had got that bad after only 10 years!
1998 Fiat Punto 60S
1998 Fiat Punto 60S
- bdann0875
Progress update:
Slowly but surely the car is taking shape.
Can't wait to start putting the trim etc back on in a week or so!
1998 Fiat Punto 60S
1998 Fiat Punto 60S
- Gaffer
- Car Model: Sunbeam Stiletto and an Imp project
moving along so quickly. Well done. It will be back on the road in no time at the rate you are going.
Nice job.
Peter
Nice job.
Peter
Trying to keep the faith.
- bdann0875
Shell in primer, top coat to follow.
The car wouldn't be progressing this quick if I was doing the welding!
1998 Fiat Punto 60S
1998 Fiat Punto 60S
- bdann0875
Thanks for the comments.
Time for an update!
Welding and spraying finally finished!
Now it's back to my outdoor garage!!
Looking to start the refit.
Time for an update!
1998 Fiat Punto 60S
1998 Fiat Punto 60S
It must be really gratifying to reach this stage with a restoration. It looks like a lovely paint job!
- bdann0875
I don't know if I was expecting too much from the workshop that did the welding and respray, but IMHO they should have atleast covered the suspension with paper or cloth to stop the shultz underseal going over the shocks and springs!
I was going to be removing the suspension components anyway, but I still think a bit more thought could have gone into covering certain components prior to spraying.
I have put new brake cylinders all round and new brake hoses. I wasn't intending changing the brake pipes, but sod's law, once I tried to undo the pipe unions, they twisted the pipe each end. Not a major problem as I have a brake flaring kit to make new pipes up,but it was something else I wasn't expecting to do!
The spring around the front brake hose aparently is to stop chaffing.It's took 50 years of the Imp's life for brake hose manufacturers to think this is an issue.
If only there were some let up in this bl***y rain, I would have had the car finished by now!
1998 Fiat Punto 60S
1998 Fiat Punto 60S
What? You mean between out wet season and our even wetter season?bdann0875 wrote:If only there were some let up in this bl***y rain, I would have had the car finished by now!
Sadly, not many folk put the kind of care and attention into things like paint jobs as we would do if we did the job ourselves. It seems as though you have fallen victim to this. The only thing you could have done would have been to mask those parts up yourself. Still, as long as you are pleased with the job in most respects, all they've done is given you some more work to do - and a few more parts to find.
- bdann0875
Now we have had a few dry days, I have been able to get some more hours in on the refit.
New fuel line and heater pipes in.
How NOT to fit a laminated screen!
I know laminated screens are to be treated with care, but I tried one push too many.
Luckily I had a spare toughened screen complete with rubber and stainless trim in my loft as a temporary measure because nowhere has any coupe laminated screens at the mo. Aparently Triplex and Pilkington get all their glass made in China now so I have an 8-12 week wait for a new one.
I had new stair carpet fitted a few months ago and the fitters left some underlay behind so thought I would put it to good use in the Stiletto!
Waste not want not eh?
1998 Fiat Punto 60S
1998 Fiat Punto 60S
- bdann0875
Re: TMF104F Stiletto restoration FINALLY FINISHED!
Here are the final photos of my Stiletto rebuild.
There have been problems along the way,and at times I've felt like giving up, as I'm sure many of you have too?
I covered over the original blown vinyl. Results were quite good and certainly look better than the cracked/missing sections underneath.
It's soo good to be able to drive the car again,and to fill up with petrol and have interesting conversations with people that would otherwise not say anything when in a eurobox modern.
Looking forward to taking the car to Perth in a few weeks for IMP50 yay!!
1998 Fiat Punto 60S
1998 Fiat Punto 60S
Glad to see you put the chrome strips back on the sill top edge, a lot of folk dont bother, or dont know they were supposed to be any on the 301 series Stiletto
- pubcrawler
- Car Model: 1965 Imp, 1971 AH Sprite MkIV, 1965 Triumph Herald
- Been thanked: 7 times
Excellent resto work, a credit to you. Well done .
Martin Parkes.
Martin Parkes.
