ANDY DAWSON TRIPLE CCC IMP
bonzaimotorsport
Car Model: Hillman Imp - Andy Dawson CCC Car
Post by bonzaimotorsport » Mon Nov 12, 2012 11:01 pm
Just to keep you updated Andy Dawson's car that did the 1976 RAC Rally BMH 572H is now under going a full restoration, the body shell is down with Mike Hanna who is rebuilding the shell from scratch, hopefully it will be ready for the National in Perth next year keep you updated once i have some more news
pubcrawler
Re: ANDY DAWSON TRIPLE CCC IMP
Post by pubcrawler » Tue Nov 13, 2012 7:04 am
Great news, be sure to post some photo's when available :D
Martin Parkes.
Post by Lotus-e-Clan » Tue Nov 13, 2012 8:18 am
Any contemporary photos available to post?
Post by ImpManiac » Tue Nov 13, 2012 11:20 am
One word springs to mind: AWESOME! :o 8)
Mike Hanna
Car Model: 2 ZIMPS, 2 SINGER CHAMOIS, 6 HILLMAN IMPS
Post by Mike Hanna » Wed Nov 14, 2012 7:04 pm
Hi All. The "Triple C" project Imp is indeed in my workshop needing a bit of a rebuild. It is looking a little sad for itself. The front has taken a battering,the front suspension mount is back and up about 3/4" and the front panel and spare wheel well are rippled. Luckily I have a very good used front panel complete with SP well and legs. Not too much rust in the shell but it had a cover sill on the drivers side. When removed it revealed a big dent running from 1/2 way along the door aperture to the rear wheel and the floor edge is pushed in about 1/2" and the o/s/r wing has been replaced before becoming a rally car and 1/2 of it has been popriveted on. Another problem I have discovered is that because the cage wasn't pointed round the shell the 'B' posts at waist level are an inch further apart than they should be and the driver's side rear pocket bin has cracked and lifted from the rear seat pan. Nothing that can't be put right. The sand blast man was in yesterday and is going to pop round when the weather allows and test blast an area to see if the paint will come off easily, other wise its Nitromors. Will post some pics when I get round to taking some. Cheers. Mike
