So i'm finally posting on the forum about my restoration project. I bought the car on eBay (from Jim Cox) for a princely sum of £350 and to our surprise there was /very/ little rust , the vinyl roof is in very good condition also, the few areas needing attention were the driver's side rear arch and spring mount, also the front suspension shock mounts were slightly rusty, the rear cill extensions had gone and the whole cill on the near side needed to be replaced. The bonnet wasn't from that car and was very rusty, the boot-lid and crossmember were also from a donor car... One door has been brazed up on the handle holes (Why would somebody do this?), and the door corners had gone in the usual places.
So we started by putting the car up on a chassis tilter, this is a fantastic way to get to the underside of the car, and easily work on the suspension etc, we then set apart stripping the underside, and removing all the underseal.
Next (once all the suspension, gear selector, hoses & cables were off, it was time to weld up any rust on the shell, and re-seal the underside of the car.
Welding took place over a few weeks, after ordering a new rear arch and near side cill, we got to work replacing the rear spring mount, and the rear arch.
That's it for this post, apparantly you can't have more than 4 attachments, and they have to be small and low quality
Will update you all soon
Ollie
Sunbeam Stiletto JEY 464G Resto Thread
- Car Model: Sunbeam Stiletto
Sunbeam Stiletto JEY 464G Resto Thread /2
We welded up each part of the car needing work for the next few weeks, until we had the cills, arches, roll panel (near where the spoiler normally goes) and a few other bits and pieces... we ended up with a solid shell. Once we had a shell it made sense to seal it up again, so we set about priming and undersealing...
Next up, (Just before priming and sealing) I welded in a strengthening brace at the front, to put back some strength taken out when I front-rad the car.
Now with the car sealed and welded, i could move my attention to the matter of a bonnet... very quickly I realised that it was shot to the point where I couldn't see any reason to weld it up, and bought a fibreglass one off ebay, it is of full fibreglass construction meaning that it is considerably lighter than a steel option, and since i wasn't going to mend it i sure as hell was going to mod it
Now, i turned my attention to the crossmember: requires a little filling with the dents, a few pin holes needed welding up and of course i welded a plug into the starter handle hole (why would anyone ever use a starter handle in 2012?)
Now for all those hoses and cables we took off the underside of the car, also the gear shifter needed putting back.
Next post:
Suspension, handbreak, gear selector, and more lovely cupronickel hoses....
TTFN
Ollie
Next post:
TTFN
Ollie
Sunbeam Stiletto JEY 464G Resto Thread /3
So next we got on with reconditioning the handbrake and gear selector, then assembled the front suspension and fitted that, then the rear and the newly re-conditioned handbrake, gear selector, throttle cable and choke cable.
We also sprayed the engine bay in stone chip to make it less likely to chip when working in there, and also stopping any need for rubbing it down later
So recap, hoses are in, back brakes are rebuilt & ready to go, and the underside is essentially done, front suspension is all built and polybushed, rear got the same treatment, and then once it's painted, the only jobs remaining on the underside will be engine, springs & front breaks.
Here's a shot of the underside almost done:
With the underside complete, it comes off the roller and the most boring, long, hateful and generally tiresome job of rubbing down the whole car down is upon me
Before this, i did take some paint off with a really good angle-grinder, bare metal disk, ages before any suspension work was done:
So once it was on it's own four wheels we got some primer or anti rust compound on everything, but you'll have to wait to see that, because of the four image maximum
Ollie
Ollie
Sunbeam Stiletto JEY 464G Resto Thread /4
Now the car was primed:
And ready for the body shop, I worked there for 6/7 months for free so i could take my car in there when it was ready, however i still have to work on it while it's in there so it may be a very long time before it even sees primer again . So this may be the last update for a while because it's kinda 'sat' in the shop now not getting anywhere very fast, firstly because bodywork is seriously time consuming to get prepped, but also because i don't go in enough to actually get the massive amount of work required done, probably due to my bitter hate of bodywork
Now it's in the shop with primer all rubbed down and filler in it in some places, such as the rear quarter on the drivers side, where the lines pulled in when we welded on the new arch...
I roped some friends in to try and make the job less boring and we managed to get a bit more rubbed down and prepped, but it's still a drop in the ocean of work left to do, still i think it looks kinda almost mean in this shot:
anyhoo-
This is probably the last post for a while as it's not leaving the body shop for a good number of months now i reckon, although that said there is still the engine build to report
Ollie
anyhoo-
Ollie
- Car Model: Sunbeam Stiletto and Imps
- Has thanked: 5 times
- Been thanked: 6 times
Re: Sunbeam Stiletto JEY 464G Resto Thread
Great post Ollie.
How many hours of prep do you reckon before spraying?
68 Stiletto/65 NAS Imp Mk 1
64 NAS Mark 1
67 Imp Mk 2 from Bury St Edmund's!
73 Clan Crusader
64 NAS Mark 1
73 Clan Crusader
Re: Sunbeam Stiletto JEY 464G Resto Thread /5
A very serious update... paint is on the car...
Got it in the paint shop at Classic & Custom works, on axle stands to get to the underside of the cills etc etc
Always good to get a base white down for my future plans...
Masking well underway... note the laser aligner...
Bootlid masked up...
Third colour coat...
Masking removed...
Laquer on....
Fiberglass bonnet looking smart
Can you say mr sheen?
Engine Hatch....
Note the stripe following into the dash.... all paint bleed was fixed prior to lacquer...
What does everyone think then?
Ollie/Roger
Nb/ Many, many many thanks to Rob at Classic and Custom works, without his help and hospitality this never could have been a reality.
Masking removed...
Laquer on....
Engine Hatch....
Ollie/Roger
