Ha! Taking a leaf out of Jenson Button's book , I've moved-on from the Veyron - just like him I've bought a SMART Roadster (for the wife) instead (apparently he got fed-up with Veyron bills).The Nun wrote:You're nearly there then, only another 3.8 seconds to go and its faster than a 2 million quid VeyronLotus-e-Clan wrote:Nah -still 0-60 in 5.8 secs (I guess) ...The Nun wrote:
(The 205/55/13s do slow it down btw!)
Clan JO JASON - New Mirror indicators
Re: Clan JO JASON - Bum-Tuck!
Re: Clan JO JASON - 1040 OUT!
Long time no post!
Well after 10 years or so tolerating a release bearing rattle I've been forced to remove the engine to fix a complete loss of function. I foolishly dislodged the clips (or so I thought) manipulating the slave cylinder whilst investigating a clutch slip causing the VW release bearing to rotate out of engagement with the clutch fork!
Well it serves a purpose because the valve guide clearances have always been at the extreme of tolerance from the get go so I can do an engine refresh whilst it's out.
Sorry about blurry picture - camera shake! (I needed a drink)
(...slurp...ah ..that's better..)
The eagle-eyed will notice the new rear light design (sequential indicators). More about that another time - there is so much to update thread-wise.
Well -- NO CLIPS FOUND! OK I could see their dusty remains in the form of iron filings around the inside of the bell housing .- I reckon they fell out from the get go. The more experienced of you will not be surprised - I confess that I know I never did the std mods for the VW release - ie drill the pivot holes deeper and lock-wire the clips - too impatient!
And boy oh boy, you can see how much the release bearing had been oscillating (cause of rattle) - just look at the pivot lug wear! Nicely bedded in though!
I think as well as lock wiring in the new clips I will add a retaining spring attached to the top of the bearing to stop the oscillation.
In other news ..my coil pack for the mapped ignition had suffered very bad electrode corrosion ...look at the difference in colour for the lower two HT lead sockets - the internal electrode had completely eroded away in one. I deffo need a new coil pack and leads! You need eagle-eyes to see from the picture below.
It had been running OK - WOT power seemed ok but it was not as rock steady on tickover as it used to be.
I think I'll relocate the pack when the 875 sport engine goes in next month. Good times!
Peter Kalamity!
Peter Kalamity!
Yes I'm falling back in love with her (or is it him? Jo JASON..it could be either!)... Cheers!Dave ' Linwood ' Lane wrote:Glad its getting some love
- Has thanked: 151 times
Good to see progress, my coil pack is mounted under the rear parcel shelf, away from the heat and soaking everytime I have to wash the engine
Yesh I'm now thinking under parcel shelf is best for the coil pack.
Hope to keep the thread more up to date from now on.
Thanks for comments everyone.
Re: Clan JO JASON - 875 Sport IN!
Good ol' standby 875 SPORT about to go in ...
Coil Pack relocation to original dizzy position. New Coil pack is Vauxhall/Renault therefore New HT leads off an ASTRA 1.8 ...note plug length designed for twin cam heads. Only a temporary solution to get the thing going.
New 60A off ebay (Denso sold as a tractor alternator) ..has a very small pulley diameter which really does pull down idle revs when heavy load switched on (esp. headlights, Rad Fan)
Easier to remove and replace alternator with brackets attached - saves messing about with pivot spacers in a confined space.
Alternator strap integrated with coil pack bracket location bolts so bolt holes are slightly slotted to allow radial adjustment of strap.
Hello Dave
The above pictures are from a month ago mind you. The Sport is in and running great too -albeit with half the power of the 1040 ...
And here is your pressure gauge adapter in situ - I fitted that yesterday - much better routing now thanks to Dave.
Much better idea i think , ive found one more since finding our twoLotus-e-Clan wrote:Hello Dave
Re: Clan JO JASON - COOLING
I need to fill in some of the many gaps in this readers car thread.
Some of this stuff is historic so may have been posted elsewhere - but perhaps it would be easier for me to find if it's under one roof.
Clan COOLING MODS:
From 2004 the basic system comprised:
MK 2 rear rad scoop
Next post will show recent (2014 -2018) updates to the rear rad and cowls
Clan COOLING MODS:
- Rear HE Rad
Temperature controlled EWP80 as main pump
2 X 10 row MOCAL rads located in the front spoiler fed by the heater circuit
Temperature controlled 13 L/min booster pump in the heater circuit
Rear rad air flow source:- ram air from under the car
11 inch SPAL rad fan temperature controlled from bottom hose
MK 2 rear rad scoop
Re: Clan JO JASON - Cooling mods
Disclaimer: These development mods ain't pretty - function is the priority. If and when I stop developing stuff I might use the time to make them look pretty!
RADIATOR CHANGE:
The 2004 HE rad bought from Malc @ the National that year worked really well!
However, the air vortexing pattern within the cowl on the front of the rad produced interesting copper fin erosion - exacerbated by lots of commutes during several hard winters of salty gritty roads up to 2014.
Also the hotter weather, plus no proper exit air management into the engine bay, pushed me to develop the rear cowling and add a 'diffuser' to the rear of the rad.
Out with the old in with the new! 10 years service and still worked reasonably - but hot days in summer did expose the deterioration in performance cooling the 1040.
Thicker core too - (not necessarily good news)
Alum Fan Cowl fitted to Alum Rad
Rad exit air needed management to keep engine bay cooler and to prevent warm air entering the DHLA air intake..
And of course the Exit air needs help all of the way out and away from the car.
Next time - under floor scoop change and front spoiler mods to optimise the ram air ... ( need to photo the spoiler)
RADIATOR CHANGE:
Re: Clan JO JASON - more Cooling mods
Under floor AIR management
Air is a fluid so it follows that the rate of flow within air streams, like water streams, tend to be fastest at the centre of the stream, and stalls toward the edges.
I learnt with the mark1 rear rad scoop that it's best to position the opening near to the centre of the car to catch the fastest moving air. The scoop is between the rear wheels, so need to keep it away from the dirty turbulent air and spray exiting the inner rear wheel arches.
Hence the latest mK3 rear rad scoop is skewed towards the centre of the car more than the mk2, - it even overlaps the transaxle bottom a tad.
The rad scoop is detachable from the main rad cowl - as is the diffuser floor - this means I can leave the rad and main rad cowls on the car when removing the engine.
Latest front spoiler mod directs and greatly improves air to the rear rad.
Previously with the uncut full width spoiler I lost a lot of cooling capacity compared to running with NO spoiler at all. I've also opened up the air vents to the front Mocals which improves low-speed cooling.
Mk3 Rear Rad Scoop is skewed toward the centre...
... even overlaps the tranny!
Rad scoop and rear diffuser floor is easily removed from below to aid engine removal.
Hardly notice the rear diffuser from the rear ... new rear LED lights (sequencial indicators)!
Next time - summary of cooling system performance using Evan's waterless coolant.
Interesting and informative .
So now its been like this for a while do you think the reverse ram air flow a better system than standard , is this more suited to a Clan or do you think a standard imp would benefit .I see lots of development going on here.
Thanks for posting
Thanks for posting
The devil is in many details. Many of my mods are marginal gains that all add up.Dave ' Linwood ' Lane wrote:Interesting and informative .
Thanks for posting
It is difficult to compare to the std system because I don't have/ need a rad FAN running at all times (unlike the std system). I guess where the 'reverse' ram system could be better than the std fan blower is at very high speed (illegal) when the exit air on the std system is said to be stalled by the changes in air pressure under the car near the inner rear wheel arch.
The rear rad diffuser ensures the air can't enter the rad in the std direction - ever! Also my engine bay cover 'rear lighting grill' is 'semi- sealed' against any significant low pressure air moving 'forwards' into the engine bay at any speed too - it all helps. And I guess the Clan is a better development horse than the Imp for my type of system.
One thing leads to another. When most folk remove their mechanical water pump to fit an EWP (to release engine power/torque), the std mod is to fit a front radiator.
So it is more relevant to compare my system to a front rad system.
Is cooling MORE efficient than a front rad system? - Of course not! - I have had to do a lot of (mainly hidden) air flow mods to get it to cool AS GOOD AS a front rad system cooling a 1040 with 100+ BHP.
Why not fit a front rad like everyone else?
The only significant advantages I guess are:
- 1) The air flow over my Clan is as good as a std rear rad Clan. - When a front rad is fitted. most just cut slots in the body, stall the air flow at the front and increase front end drag. The better front rad installations will manage the air better AND increase front end downforce too even without a front spoiler fitted. But to vent a front rad Clan well, the exit air needs to be nearer the windscreen which means bonnet mods which significantly reduce the usefulness of the front compartment.
2) I have full use of the front compartment - it's essentially a road car! I have filled the front with camping stuff on occasion - and I can pop the shopping in there too! A lot easier than throwing it over the high back seats, and then worse still, retrieving it! One job on the list is to fit a full plastic liner in the front boot - a bit like a SMART Roadster. I'm also very soon fitting a solenoid popper to open the boot from the outside with a remote (and shopping) in hand. Adds to refinement and pleasure in use.
3) The flat floor system has greatly improved high speed downforce. The aero improvements of the flat floor compressed the suspension so hard at 100 mph it pushed the front dampers onto the bump stops - so I recently fitted stiffer front springs etc to compensate. - You can fit floor panels to a front rad Clan too of course, but I guess the clean front end of a std Clan is an advantage over the front rad 'ers for clean aero providing quicker progression of air to the rear of the car - where managing the exit air is ultra important too.
4) The under floor panels protect the suspension and a lot of the engine bay. At the front (due to aero factors), the Clan is MUCH more susceptible to suspension corrosion compared to the IMP. Also all of the Clan's inner wheel arches lack the lower extensions you find in an IMP. This allows a lot more muck into the suspension areas. Wheel arch liners are the full answer -and this is a project on the todo list for mine. .
Thanks for the explanation , makes sense to me ( kind of )
Re: Clan JO JASON - some lecky mods
Bored of cooling updates, I've turned attention to a few electrical mods:
Common Issues for Clan Owners
* Clan doesn't have hazards as std so I guess like many classic owners, you tend to shite yourself just a little bit if/when you breakdown on a motorway/dual carriageway.
* Similarly, pulling out of a parking space in reverse can be a bit of a pant-shite-r without a reversing light to warn passing cars + pedestrians (have all the bits to fit rev light at a later date).
* Driving in Fog is a nightmare in any low-slung car. FOG penetration in the Clan is made worse for having headlights that are set back within slots - dip beam doesn't light the road immediately in front and the glare back you get from eye-level dips is debilitating! I had to drive 20 mph in fog with modern's impatiently overtaking wondering what all the fuss is about.
* When I do a 'supermarket shop' I prefer to use the front boot, but it's a pain to have to open the door, pull the bonnet catch etc -especially if it's raining. Better to pop the bonnet lid from the outside using a remote control / 'bumper button'.
* A boot light can be useful too!
So I've done the following mods which are designed to have some integration/interdependency:
The RCM needs to receive a TRACE SIGNAL (12v) for the remote control to operate. So changeover relays are used to ensure the remote control operates the BOOT POPPER using the hazard circuit 12v as the trace signal, and that the remote control operates the FOGS when the side light circuit 12v is the trace signal.
FOG LIGHT LOGIC
- 1) HAZARDS (my own version using a relay and spare flasher)
2) AUTOMATIC LED BOOT Light
3) BOOT POPPER SOLENOID (remote control)
4) FOG LIGHTS (remote control)
- The LED BOOT LIGHT is energised via a MICROSWITCH integrated with the boot catch. Boot LEDs are ON when the boot lid is OPEN.
The above microswitch also energises a BUMPER PUSH BUTTON - but only when the boot lid is CLOSED.
The above bumper push button, when held ON, temporarily operates the HAZARD lights.
The HAZARDS (when ON) energise the REMOTE CONTROL MODULE and also, via a series of logic relays, ENABLES the BOOT POPPER circuit.
When the REMOTE CONTROL is PRESSED with hazards flashing - the boot lid springs open!
This allows you to pop the boot lid from outside the car with the remote control - but only when the bumper switch is simultaneously held. Without the remote control, the bumper switch will just flash the hazards, but not open the boot. WORKS GREAT!
IF you switch the hazards ON from within the car (dash switch) AND press the remote control, the boot lid will pop. ie for security and safety, the boot lid pops using the remote control but ONLY IF hazards are ON (via dash switch or bump push button).
BTW. Direction indicators + remote control will NOT pop the boot lid - you have to have hazards switched ON.
FOG LIGHT LOGIC
- Simply put, when the side lights are ON the RCM remote will ONLY operate the FOG LIGHTS - not the boot popper.
The side lights energise a changeover relay to swap the trace signal source from hazards --> sidelights.
The hazards energise a changeover relay to swap the trace signal source from sidelights --> hazards.
The changeover relays are wired such that:
It is impossible for the boot to pop open when the FOGS are ON.
It's impossible for the FOGS to light when the hazards are ON.
If the FOGS are already ON when the HAZARD switch is pulled, the FOGS extinguish automatically.
- The changeover relay connected to the DIRECTION FLASHER makes sure it's impossible for both flashers (HAZARD and DIRECTION) to operate simultaneously.
If the direction indicator stalk is ON (LEFT or RIGHT), when the HAZARD is pulled the DIRECTION FLASHER disengages and the HAZARD FLASHER takes over.
IF the HAZARD switch is then pushed OFF, the HAZARD FLASHER disengages and DIRECTION FLASHER re-engages to operate the LEFT or RIGHT indicators as previously set.
Sounds complicated but very good , your as mad as me re. electrics
Oooo yeah!
Forgot about that one. I'd even posted something about certain pull switches to avoid (cheap/bad quality).
Yer but you are much neater.Dave ' Linwood ' Lane wrote:Sounds complicated but very good , your as mad as me re. electrics
You'll see when I post pictures of the hardware installed in a couple of days time!
Re: Clan JO JASON - refit of 'improved' comp transaxle mount
Gear change has been a bit hit or miss recently and I've been getting an annoying random rattle /knock from behind the rear firewall.
Inspection of the very old STD transaxle mounts revealed delamination in one mount plus sinkage. The sinkage in the rubber meant the transaxle had dropped such that the gear change rod had sunk towards the bottom of the central hole within cross member (but not touching). Thinking this might be the cause of the poor gear change and maybe also the cause of the random rattle/knock, I decided to bite-the-bullet and re-fit Mike's competition mounts.
Moose's Mk1 transaxle mounts...
The rubber within these mounts is minimal making them very stiff but unfortunately they transmit nearly ALL of the transaxle noise into the cabin. This made input-shaft bearing rumble plus the inherent whine from straight-cut CR cogs on 3rd and 4th last time I used them, a bit wearing. A noisy cabin is OK for a single purpose competition car but mine is very much a road car atm.
So this time I decided to fit Mike's Mk1 comp mounts onto a bed of rubber in an attempt to cut down the noise transmission through the rear cross member.
A rough computer sketch of the 'faux rubber' gaskets fitted between transaxle mount and rear Cross member (gaskets coloured orange in the sketch....)
A solid proper rubber pad about 1/8th inch thick would be ideal but unfortunately I had nothing like that in the garage to hand. Found a spare 'rubber' car mat about 1/16th inch thick and cut out 2 sets of gaskets. Not ideal - especially as the mat is made from a 'faux rubber plastic' (albeit relatively soft plastic ) which obviously won't be as good at insulating sound/vibrations as real rubber. Given the lack of thickness in the mat, I made 2-ply gaskets for each mount.
I also enlarged the cross member bolt holes quite a bit to ensure that the comp mount bolts don't touch the cross member. Finally I added a third 'faux rubber' gasket between the washer and the cross member.
Result. A moderately-major reduction in noise transmission - I think a set of real rubber pads would make it a step better.
Now my 70's cassette player is louder than the transmission (and exhaust) ! If I ever stumble across a suitable proper rubber pad I'll change the gaskets to see what's what. But I can at least now live will this level of noise.
Happily, the stiffer competition mounts have restored the gear change to probably better than new - very positive and precise! The comp mounts plus rubber gaskets have raised the line of the gear-change mech back into the middle of the crossmember central hole.
However the rattle /knock behind the firewall is still present - albeit less so .
Since found the source of the rattle ...BOTH rear Protech dampers are knocking (they are nearly new ). Discovered the knock by grabbing/pulling each drive shaft up and down with one hand on the damper body (whilst standing below the car on a lift). My GAZ ones went the same way and that's why I changed to Protech . Must be some poor quality valves in these dampers !
I'll just have to live with the damper knock unfortunately ... maybe they will quieten down when the weather gets warmer and the oil thins a bit ...who knows?
Re: Clan JO JASON - recent REAR light changes
Previous round rear LED lights were a bit too big a diameter for the engine cover and they were not particularly well-fitted and eventually worked loose.
So decided to go back to a more fitting shape for the Clan with regard to the rectangular nature of the STD Clan rear lights. The new lights are less than half the weight ..
I had to make new alum sheet inserts and intended to buy EXACTLY the same as the old perforated sheet but EBAY pictures FOOLED me in terms of the scale of the perforations - the new stuff has tiny holes so it almost looks like a solid sheet. Look carefully and you can see the older larger perforated sheet in the centre underneath tha CLAN badge ... the new stuff was too short to reach the centre d'oh !
These are all LED ... understandably purists will hate them regardless...sorry!
1. Lights OFF
2.TAILS
3. BRAKE: centre low level -easily seen from distance - High-level brake light in rear window is mainly visible in traffic from above (cant see it in this picture)
4. DIRECTION Right - begin sequence
5. DIRECTION Right - END sequence
6. DIRECTION Left - begin sequence
7. DIRECTION Left - END sequence
8. HAZARDS - begin sequence
9. HAZARDS - END sequence
10. REFLECTORS below the raised (from std) bumper
I have changed the front PODS recently too ..more later.
1. Lights OFF
2.TAILS
Re: Clan JO JASON - recent light changes
Like the latest Audis but based on an old idea from the 60s when the Ford Thunderbird had the first sequential indicator lights but using separate light bulb of course, always thought it a good idea, makes you take notice more.
Nice work.
Nice and clear unlike some of the modern ones where you can't see the indicators when the brake lights are on.
- Car Model: Super
Hi Peter, hope you are well?
Putting the lights in the lid has the added advantage of fooling the rest of the population that your car is on its side - when you're roadside in the dark with engine lid up tweaking the beast.
cov_climax wrote:Hi Peter, hope you are well?
Been waiting for someone to spot the flaw in the idea! Wonder what plod would think ?
Talking of health Brian- no, I'm not well atm - came down with this nasty flu bug yesterday and took to my bed.
Otherwise I'm as 'fit as a butchers dog' (but you have to imagine the vegetarian version of that). I guess you are doing well. Maybe get to a National again one day ...
Thanks for comments peeps. More bits and bobs on developments as soon as I'm fit again.
You could split the engine lid half and half so it opens like a book then the lights would be vertical each side when open, folk might think it was a bus in the dark then and give you more room
Not such a bad idea . Save banging my head when working on it too. And i wouldn't have to put the lid down when raising it on my ramps (low garage roof)The Nun wrote:You could split the engine lid half and half so it opens like a book then the lights would be vertical each side when open, folk might think it was a bus in the dark then and give you more room
Re: Clan JO JASON - EVANS chat
Copied & Pasted from Dave's readers car to prevent clogging his thread with high viscosity Evans coolant..,
I do understand your point about flow and pressure ..I had the same thoughts.
In practice the main issue with Evans flow is the increased viscosity. I have tried lots of different coolant hose routings through my Laminova. At one point i had a load of right angled bends and a 3/way (central heating) valve in the 5/8th heater hose circuit. There is an additional 13L/min coolant booster pump in this circuit and it couldn't cope with so many restrictions so I had to simplify the system to recover flow.
The main EWP80 copes fine with Evans BUT it is much much more difficult to get rid of air locks from the front of the car despite using the EWP80 at full flow to push it through. The answer was to leave it overnight and try again.
In addition to this, I've had personal email from Davies Craig to say that they would expect their EWP80 to fail earlier in service using EVANS due to the higher viscosity. I've since been using Evans for a number of years in two cars that have identical EWP80 pumps. So far no sign of impending doom and it's a risk worth taking given the benefits of using Evans in an infrequently used car. BTW, DC were gob-smacked to hear that I'd been using an original spec EWP80 for 12 years. They didn't expect that kind of service life out of the original bearings and seals - they had subsequently uprated units to ceramic bearings!
The main problem with Evans is the lower Specific Heat compared to water which means you need faster flow through the entire system to compensate. Evans picks up heat very quickly but absorbs less heat per unit volume than water. The answer to this problem is to tune the system for faster flow - fortunately the EWP80 easily meets this requirement. I haven't tried it but I expect the Imp pump would not flow enough at lower revs to remove heat in traffic.
Yes that's more the case with water based coolant ..the pressure raises the boiling point. Evans boils at 180 C so you already have more head room than water @ 10 psi.moose wrote:I have never been able to make my mind up about EVANS. I prefer the idea of some pressure to pack the coolant onto the hot areas inside the engine. From all the info i have read and what i have learned is if there is the correct amount of pressure to allow the water to flow efficiently and keep it packed onto the back of the exhaust valve seats it will remove more heat and prevents localised boiling .
Peter.
Yes another issue with Evans is oil temperature control - Oil at 125 C for long periods is a disaster for an Imp. Fortunately the Clan is currently running at normal temps using Evans. This winter I had to turn down the EWP80 flow because it was running too cool at 70C.
So, basically what we are concluding here then is that Evans can be a superior product, over and above standard water/antifreeze, but ONLY if there are significant additional modifications. Therefore more suited to an Imp specifically modified throughout for competition work ?
A bit of a tortuous route to take for the average punter with only light personalisation of his steed, me thinks. I'll stay with Bluecol and a temperature gauge !
Yes I think you are right. But that said I haven't tried it in a std Imp system and I don't know anyone who has.617sqn wrote:So, basically what we are concluding here then is that Evans can be a superior product, over and above standard water/antifreeze, but ONLY if there are significant additional modifications. Therefore more suited to an Imp specifically modified throughout for competition work ?
Evans have got bad press because it has two essential differences in material properties compared to a water:glycol mix that, ON PAPER and IN THEORY, appears to be disadvantageous compared to PURE water and folk latch on to theoretical half truths to support their case. Namely, lower specific heat and higher viscosity. In practice, these properties can be equalised/neutralised/harnessed if you understand how.
The fire-risk thing is mainly folk making installation mistakes for use within extreme applications.
The '180C seizure' issue is folk misunderstanding/not making the link between water and oil cooling and some folk are just feckless ....the most famous example of that can be found on YouTube - a chap 'hill trailing' off road at very low speed using high revs on a dirt bike in 30+C ambient heat -he thought it would be OK with Evans at 180C! It's not meant to run 180C 'systemic' - the 180C Evans advantage is to prevent LOCAL boiling and delamination of coolant at the interface attached to combustion chambers, liners etc etc.
A personal demerit for those who thought 180C was an upper systemic limit.
I think for Evans, it would be a different story if it was less-expensive. Most folk cannot afford/don't want to do the spend to develop their cooling system to suit, or risk any loss of a premium-priced coolant. Others worry about not having spare Evans easily available for top-ups if leaks do occur on trips. Evans is re-useable which helps. When engine swapping I needed about 100ml extra Evans to account for losses when removing hoses etc. I guess less-careful mechanics will make you pay through the nose if you left it with them to do.
Some folk simply don't want to modify their classic...and why should they? That said, there are cars that have std systems quite suitable for Evans conversion (sufficient flow rate/low heat generation) and other that do not. I know folk with Lotus 912 engines that use Evans in an otherwise unmodified system with no apparent issues.
It's a shame, because one of the biggest advantages for the classic car owner that use their car infrequently is Evan's extremely low-degradation impact on cooling systems during inactivity. HGs /WRs /steel liners do not corrode and water pump seals don't stick and tear on re-start recommissioning, alloy & cast iron waterways don't corrode, heater and rad internal matrices remain in tip top condition. I think that must be why Jay Leno uses Evans in his fleet. With that many cars lying inactive -it's a big money saver in the longer term. This is a big plus for me having previously suffered a failed water pump (Lotus) and WR corrosion (Clan) due to 'storage deterioration' on more than one occasion in my classics.
For the racer, apart from tuning the cooling system to suit, there are safety issues concerning spillages - Evans is massive slippy! Track -owners /stewards don't like it. But the storage advantages of Evans applies to race cars that lie dormant too.
- Car Model: imp 875
Hi its me again.
Sorry , I didnt realise you had to do so many changes to get Evans to work. I'll post the graph on cooling again. (why did photobucket become charge a lot for nothing ?)
The problem is lack of cooling, you are only getting at most 60% cooling versus water. Old half broken cooling systems on old cars is the last place you need evans ! A neighbour put Evans in his Sunbeam Tiger with predictable results, one cooked engine covered in slime lol.
Recent news is BMW's problems with fire caused by the OE cooling system leaking onto the the manifold. No car car manufacturer uses Evans as OE standard cooling ( a few say DO NOT USE EVANS, you will lose your warranty)
https://www.dailymail.co.uk/news/articl ... lames.html
BMW with their crook helping 'keyless' car stealing craze, have now managed to bring fire to rise insurance costs !
Fluids take the easiest route, in a engine perhaps EVANS cooling will not flow like water based coolants ? causing hot spots, who knows ? is it worth the risk ?
The next point is Evans really take the piss with pricing ! I am sure tesco/costco/aldi /liddle cheapest gycol based antifreeze at 100% no water would be just as good as Evans at not cooling your engine !
We will just have to disagree on Evans, ps nice car !
- Has thanked: 159 times
- Been thanked: 40 times
Just a (hopefully useful) bit of chemical info on this subject.
Our 'normal' antifreeze mixtures contain ethylene glycol whereas I believe (have't used it so please feel free to correct me if I'm wrong) the Evans product is based on propylene glycol. There is quite a difference in properties between the two.
1. Ethylene glycol: Melting point* -13 degrees C, Boiling point 197 degrees C. Very toxic if ingested.
2. Propylene glycol: Melting point* -59 degrees C, Boiling point 188 degrees C. Very low toxicity if ingested (it is actually used in foodstuffs as E490).
I've put an * by the melting point as it might appear to the uninitiated that ethylene glycol wouldn't be a very good antifreeze as it freezes at -13 degrees C. However adding these glycols to water lowers the freezing/melting point of the mixture very effectively which is why it is used with water as an antifreeze. 100% ethylene glycol wouldn't be particularly effective as an antifreeze and coolant in a road car used in cold climates because of its relatively high freezing/melting point- the most you would want (for optimum antifreeze properties) is a 55:45 ethylene glycol:water mix. I can't comment on whether using 100% ethylene glycol as coolant would cause other problems but don't really see any point for normal cars.
Dave,Dave ' Linwood ' Lane wrote:Interesting and informative .
Thanks for posting
This is what I used as the basis for LNK's old set up. Once tweeked and perfected it worked really well.
- benwick3
- Been thanked: 2 times
I did use a 100% Ethylene Glycol as coolant in my original Clan as I was having problems with boiling when I started racing. With it's higher boiling point it did work. However, when the hose failed to the heater as I finished practice at Lydden Hill I can confirm that the drenching of my feet with it a 100 degrees plus was extremely painful. I fitted a larger radiator instead and went back to a normal concentration of antifreeze and water.
GR88... I will not try (or indeed want) to convert you.
My Journey with the EVANS:
I don't tend to take the word of others I prefer to examine practical effects for myself.
You can only get control and problem-solve effectively if you understand the problem.
So I recreated the problem by performing a simple experiment (a very simple, reproducible, experiment).
For me, the turning point in understanding followed this simple experiment which demonstrated the essential characteristic differences of EVANS compared to WATER when equal heat energy is applied to both for a set period -(followed by a cool-down phase) (see graph below).
Key Observations:
Because water IS an excellent heat buffer, it releases heat VERY SLOWLY. This is the principle reason why the climate at the seaside is less extreme than inland areas. It's also the reason why, if you pass water through a radiator TOO quickly it will not efficiently release its heat. So car manufacturers tune their cooling system flow rates with the compromise set between heat pick-up and heat release. They are not inclined to fit oversized radiators for obvious reasons, -so coolant flow rates have to be specified to suit...not too fast, not too slow.
The practical limitations of EVANS as a coolant in a water-tuned system because EVANS is a POOR heat buffer.
If you replace a water-based coolant with EVANS in a MARGINAL cooling system tuned (flow-rated) for water, the temperature of EVANS will rise much quicker than water which means oil temperature will rise more quickly too. However, because EVANS is a poor buffer of heat it will release proportionally more of its heat than water at the radiator (flow-rated for water). That sounds like a 'swings and roundabout' situation where possibly there is no sum-difference between the two coolants. But there is more BAD NEWS for those doing EVANS conversions into MARGINAL cooling systems specifically tuned for water. Evans will also release more of its heat into the walls of ALL of the waterways on the way to the radiator- which means SYSTEMIC HEAT SOAK occurs more quickly compared to water. And oil temperature rises more quickly as a result.
THE SOLUTION: - Tune the cooling system to suit the characteristics of EVANS by Increasing the coolant flow rate. Increasing the flow rate of EVANS increases the transfer of heat to the radiator and increases the heat pick-up from the water jacket too. EVANS picks-up heat energy just as quickly as water but 'runs hotter' for the same energy input. Bear in mind that 'temperature' is simply a measurement of the heat released (from the coolant) transferred to the measuring device. Evans will show a higher temp (demo'd in the experiment above) because it is releasing its heat more quickly than water.
Fortunately electric water pumps are easily tuned for flow rate so are very suitable for Evans conversion.
Increasing the rad size alone is not the solution ..all you will do is create a large temperature delta between rad and water jacket with the potential for catastrophic heat/cool shock damage... particularly bad for engines with NIKASIL coated alloy liners (like the Lotus 900 engine and others -eg BMW). For the same reason, increases in flow rate needs to be gradual. Large shifts from no-flow to full-flow is not a good idea.
Oil temperature:
Folk I know who have converted to Evans have reported that oil temps are higher - and oil pressure falls proportionate to temperature increase. You therefore need to increase oil cooling when using EVANS. Increasing the coolant flow rate helps to reduce heat transfer to the oil - but as I said. EVANS will heat soak the system more quickly than water so it's sensible to increase oil cooling IF necessary. I run a Laminova. I've had to flow-rate it for EVANS too. If you run an oil radiator then optimise air flow through the rad etc.
The good points once the system is tuned to suit EVANS.
1. Quicker warm-up than the previous water-based system. Including quicker oil warm-up.
2. Predictable and reliable cooling performance.
3. No significant pressure within the system.
4. No corrosion.
5. Reduced cavitation - the Imp head tends to pit badly between No2 and No3 when using water as a coolant.
6. Excellent protection during periods of inactivity (preserves pump seals, WRs etc)
7. Re-useable
8. Exclusivity - not for cheap skates - therefore has snob appeal!
EDITED: for spelling as usual!
Key Observations:
- 1. Evans heats-up MUCH quicker than water (same energy input applied) which is related to the difference in specific heat.
2. Water proved it's an EXCELLENT heat buffer compared to EVANS. The rate of temperature rise for WATER began to plateau above 60C, thus demonstrating it's an excellent buffer of heat energy and a good insulator (common knowledge).
3. The temperature of EVANS rose at a more linear rate compared to water and continued to rise AFTER heat was REMOVED! Evans is a poor buffer of heat compared to water and a poor insulator.
Oil temperature:
4. No corrosion.
7. Re-useable
Re: Clan JO JASON - DOOR PICS for DOM
FOR DOM
1 Door cards ON.
2 Door Cards and door end ( Latch)
3 LATCH
4 INNER Door release handle REMOVED
5 INNER DOOR HANDLE fitting
6 OUTER door card REMOVED.
7 DOOR BEAM at door latch end
8 DOOR BEAM at door HINGE end
9 WINDOW mech - UP position
10 WINDOW mech DOWN
11 INNER door card with batterns for end trims
12 INNER door card with end trims fitted
13 OUTER door card with handle trim and ASHTRAY
14 OUTER DOOR CARD REVERSE side (showing trim clips etc)
1 Door cards ON.
3 LATCH
10 WINDOW mech DOWN
- Car Model: clan crusader
Oh my your door beam is a bit rusty! Mine must have been replaced at some time ...
On picture 8 there is a rod going to a bell crank with a Black metal pin attached ,I am assuming that is the internal lock ?
Mine is missing ....
M-Power Clan Crusader
Saab Turbo X
Saab Turbo T16s
Saab Turbo X
Saab Turbo T16s
Yes that short black bell crank rod is the internal door lock latch. If your beams have the weld-on boss the system would be easy to reproduce.ylee coyote wrote:Oh my your door beam is a bit rusty! Mine must have been replaced at some time ...
This is the first time I've seen the inside of the door of this Clan tbh, and was pleasantly surprised. I expected worse as the bodywork of the car is largely unrestored apart from a respray in the late nineties by the PO.
Pictures are as requested for DOM who hasn't seen the inside of Clan doors before - he's rebuilding one atm.
I got this Clan in 2000 and have never had the door cards off. The doors haven never been restored from new so not 3 bad for a 45yo Clan.
It's not quite as bad as the photos represent. There is the usual small area of rot along the bottom edge of the beam close to the hinge post where water drips down the front of the window frame into the door. I had the same on my first Clan when that was only 7 years old. - an easy repair. All other areas are solid. The hinge post and hinges are solid but quite rusty and the hinge bushes have gone AWOL.
The main brown stuff on the main body of the beam is the dried out glue that stuck the OE full-width polythene sheet to the door beam. The polythene sheet was meant to protect the inner door card hardboard from a soaking and to direct water towards the door drain holes and away from door pocket.
Cheers ! ,My drivers door beam is in remarkably good condition with no rust at all ,I suspect it was replaced at some time as the passenger door beam is almost exactly like yours
As my door key is not attached to the lock in any way ,I fitted central locking with the actuator acting vertically on the locking mechanism on the door latch, It would be nice to have a belt and braces ....
Saab Turbo X
Saab Turbo T16s
Saab Turbo X
Saab Turbo T16s
I've used one of those £5 solenoids to open the front boot with a remote fob on both Smart roadster and Clan and they are very reliable. I've been thinking about door poppers too ...ie doors actually pop open with a remote ...not just unlock.ylee coyote wrote:Cheers ! ,My drivers door beam is in remarkably good condition with no rust at all ,I suspect it was replaced at some time as the passenger door beam is almost exactly like yours
But I haven't thought through the consequences yet ..and its low on the list of things to do...but one day it's likely I'll join you/copy you with the electric door thing.
Another thought ..I do like the idea of sliding (mechanical) windows rather than a window winder or electric window motors. I've seen a Davrian with windows operated by a vertical slider on the inner door card...but when I thought about how to apply it to the Clan, the door beam would get in the way. Now the door card is off the drivers door, I'll sit and stare at the naked door beam for a while to see if I can work out how to do it.
Maybe the slider would have to form an arc to get the window travel from top to bottom? Would save a shed load of weight ..especially if I used polycarb for the windows.
- pimpdriver
- Car Model: Irish Clan, Luff Hillclimb Clan.
I am in the process of sorting out electric windows on my Irish Clan using the cable driven sliding system off a rover 75. I have managed to modify one to fit on the passenger side and got it to slide up and down nicely unpowered, and got it to work powered on the bench. I will be fitting them properly in the next couple of weeks and i'll take some piccies for you.
Eric Morrey
Rawlson Imp Turbo
'Irish' Clan
Rover 75 waft-mobile
Hillclimb Clan - Resting
Rawlson Imp Turbo
'Irish' Clan
Hello Eric - hope all is well with you. Yes piccies please. Can be sure it'll be a good solution if you are doing it!pimpdriver wrote:Peter
It'll be an ideal time to mod the window lifts when I do the hinge bushes on the driver's door.
Now THAT'll be another issue for me ..where to buy nylon hinge bushes?
Maybe I should try to source bronze bushes if possible? Anyone got ideas and opinions on that?
Could you buy a stick of nylon online and have someone machine you new ones ? Just a thought. I've bought short lengths of stuff from ebay sellers a few times over the years. Beats having to buy full lengths
Good idea! I'd need 4 bushes for each door so machining nylon should be fairly quick and easy...and keeps it original.617sqn wrote:Could you buy a stick of nylon online and have someone machine you new ones ? Just a thought. I've bought short lengths of stuff from ebay sellers a few times over the years. Beats having to buy full lengths
From what I remember (the last time I replaced my 1st Clan's hinge bushes was way back in 1980), they have a 'Top hat' conformation. So the nylon rod/stick would need to be fairly large to have enough material to form the 'brim'. IIRC the 'brim' diameter is about 5/8". Do you know if there is a range of diameters available?
- Car Model: Imp Deluxe, Imp Van
I believe Robin Human has made a batch of pins and bushes fairly recently.
