NPB 646L - Update
tomcat
Car Model: Hillman Imp Super 1972
Re: NPB 646L - Update
Post by tomcat »
Progress has been very slow of late, due to me really feeling the cold weather.
Getting there though:-
Have had to strip out the cooling hose double take-off I fitted as it does not seem to be seating tight enough :!: :!:
Removed to photo. Are any bits missing :?:
Tom, the length of the shoulder on the spigot would seem to me to suggest that there is meant to be another washer between the spigot and the dowty seal (washer with rubber insert). I may be wrong. Are both dowty seals a good snug fit on the spigot? If not, it will be very difficult to get it to seal. :!:
The engine bay is looking superb! 8)
Are you sure the banjo was fitted with its widest opening towards the "hexagon"?
Don't ask me why I'm asking. :oops:
Last edited by Lars Hagermark on Tue Feb 26, 2013 12:24 pm, edited 1 time in total.
tomcat
Post by tomcat »
ImpManiac wrote:Tom, the length of the shoulder on the spigot would seem to me to suggest that there is meant to be another washer between the spigot and the dowty seal (washer with rubber insert). I may be wrong. Are both dowty seals a good snug fit on the spigot? If not, it will be very difficult to get it to seal. :!:
Hi Paul
I wondered if there should be another washer of some sort. The dowty seals 'appear' to be a snug fit but, when in place I could still rotate the secondary takeoff without too much effort :!: :!:
Thanks for your comments.
Tom
^^ Lars's comment is also worthy of note, Tom. :wink: The banjo needs to be the right way up.
tomcat
Post by tomcat »
Lars Hagermark(DJH705) wrote:Are you sure the banjo was fitted with its widest opening towards the "hexagon"?
Hello Lars
Your comment understood and appreciated. :)
Tom
Post by cov_climax »
I'd also favour copper or alloy washers over dowty washers for that application
tomcat
Post by tomcat »
cov_climax wrote:I'd also favour copper or alloy washers over dowty washers for that application
Is there some technical reason for that preference please?
Just personal preference, the rubber sealing area takes away area from the face so it can cause distortion on parts with thin walls or smaller faces like a banjo fitting.
The depth of the shoulder is to allow the washer and the flange of the banjo union to be located.
tomcat
Post by tomcat »
All in place and tight now.
Had purchased a deep socket which made things a lot easier.
Finished up using a combination of the dowty and copper washers. Copper for the smaller size and the supplied dowty against the shoulder.
We move on to getting the exhaust on now, then the Weber fitted. :)
tomcat
Post by tomcat »
Some progress since last time but seems 1 step forward 2 back at times.
Was struggling with getting the sports exhaust on without it snagging on the heatshield. :roll:
As I was swearing and cursing suddenly a 'saviour' appeared in the form of Ibbo Snr. He had come to show me a picture of his latest purchase. However next thing he was under the car, the heatshield came off, and the exhaust with some struggling was in place loosely. My thanks to him for that. :)
On reflection I decided to go back to tweaking the heatshield so it could be in place, so off came the exhaust. :!:
I very very nearly can get the exhaust back. Decided to leave exhaust and concentrate on other things. I know the Ibbo's are busy with James trialling etc.,
So have trial fitted an oil catch tank with some heath robinson bracketery.
Question is do I run straight from oil fill point to the tank or utilise the original system and then run to the tank, instead of to the Solex :?: :?: The Weber 28/36 DCD has no connection for the oil mist.
Hi Tom,
I'd just use the standard outlet and plumb that into your catch tank.
Yea as Baz says, you can run a pipe from the oil filler neck breather stub to the input of the catch tank and ideally you would run the output from the catch tank to the carb air box. In the absence of an airbox connection, some would simply vent the catch tank to atmosphere through a filter - but this isn't a socially responsible thing to do, and you loose out on vacuum assistance to help evacuate the crankcase.
When I use to use open K&N type filters, I plumbed in the catch tank output to the K&N filter coverplate...
What type of filter are you going to use on the Weber?
tomcat
Post by tomcat »
Thanks for comments. :)
Plan is for a K&N filter so will investigate connection.
tomcat
Post by tomcat »
The K&N filter I have does not have an inlet for the feed from the catch tank.
Thinking about drilling a hole for a 9mm dia feed and then using superglue to fix it in.
Anyone used some other system please?
tomcat
Post by tomcat »
More work done, all slow and with minor :roll: frustrations but:-
Minilite wheels fitted, some rear panel paint work done.
had terrible trouble getting one of the rear Weber fixing nuts on correctly, then suddenly bingo!!
Need to do check-list before starting up. Fingers crossed :wink:
Will you be able to get some video of the first start, Tom? :?: The car is looking great!
tomcat
Post by tomcat »
ImpManiac wrote:Will you be able to get some video of the first start, Tom? :?: The car is looking great!
Hi Paul
Will see if that can be arranged.
Just returned from a week in New Forest so 'catch-up' is needed :roll: :roll:
Leumas
Post by Leumas »
What a transformation. Amazing, Tom. Allan
Allan Carty, Bicester, Oxon.
1966 Singer Chamois, forest green (green truck paint)
tomcat
Post by tomcat »
At long last car starts and runs. Still requires some tweaking but progress at least :)
Had 2 oil leaks though. 1 from the oil pressure gauge take-off on the block which after much fiddling is now sorted.
The 2nd one is at the oil cooler itself. It appears to be from 2 locations, at a lower junction to the finned section and at the top of the vertical cylinder. Both on the same side.
Have a request in 'Wanted' if anyone has an oil cooler for sale please.
Is it possible to get these points welded up? Anyone experience on this please?
eebiegeebie
Car Model: Singer Chamois Sport
Post by eebiegeebie »
tomcat wrote:Is it possible to get these points welded up?
If it is the standard "bog brush" type cooler, I've a feeling they might be soldered joints, so might be repairable with normal plumbing equipment??? (or take it to a place that re-cores radiators?)
John Hall
tomcat
Post by tomcat »
Yes understood.
Thank you. :)
It's great to hear you've got it running, Tom. :D :D
tomcat
Post by tomcat »
having solved, or located, leaks in engine compartment now have to solve the leak at oil pressure gauge. :o
One soggy leg!!!!!!!!!! :roll: :roll:
tomcat
Post by tomcat »
Sorted I think. Amazing what an o-ring plus the fibre washer can achieve :!: :!:
Took long enough as could not move the steering wheel for some reason. :roll:
Never mind what else would I do on a nice sunny day :?: :) :lol:
tomcat
Post by tomcat »
Frustration continues as whilst car starts it does not run at anything resembling idling speed. :roll: :roll:
With choke out it runs furiously. Choke in a bit and it just cuts out.
Have had ibbo over and he is as mystified as I am.
Any ideas guys and gals :?: :?: :?:
Inlet air leak? :?: :? That might explain why it only runs with cold start enrichment and only then at high revs. Air could be leaking through the joint between carburettor(s) and inlet manifold, manifold and cylinder head or even through badly worn throttle spindles or bushes (although I am sure you would have repaired the latter, Tom, knowing you :wink: ).
Is there an inlet manifold vacuum pipe off somewhere?
Just some initial thoughts.
Post by impmann »
On a 28/36, the choke is effectively a separate carburettor... for want of a better way to describe it. Therefore when you push the choke in, you transition the fuel/air mix into the first choke - if the main jet is blocked, that could cause it to stall.
As Paul says, air leaks can be a trouble spot too - check that the manifold is properly lined up and bolted up the head. 28/36 plus manifold is *very* heavy and therefore this joint can be troublesome - I've had lots of trouble with bad sealing on some manifolds. I've also had one manifold that had mounting faces out of true - I'd paid a lot for it from a "specialist" and it ended up in a scrap bin as it was poorly made and would have never worked... worth checking.
Good luck! 8)
eebiegeebie
Looking at the photos, it seems you have the Mangoletsi type inlet manifold, arguably the best of the DCD manifolds for the Imp, so I doubt that's a problem. If the dizzy vacuum pipe hasn't come adrift, I'd say the most likely culprit is a blocked primary idle jet, not the main jet (I bet Tim meant the idle jet). Failing that, the starter mechanism on the DCD can give trouble, as has been said, but you need to take it to pieces to investigate that, so check the other things first.
John Hall
tomcat
Post by tomcat »
Gents, thanks for your comments.
Answering points raised:-
Paul,
Carb was totally rebuilt by Carburettor Exchange at Leighton Buzzard using jets etc., as listed earlier in this posting. These were obtained from Northampton Motorsport. I would say, from my previous experience with Carb Exchange, that I have as good as new item. Carb Exchange did make a comment that the flange was straight and true.
Pretty sure there is no leak between carb and inlet. Mark was uncertain about the original gasket I had so I got a replacement [plus spare] from Fast Road Cars. Highly recommended. Ordered at 1530 and with me at 0930 next morning. Something about post from Somerset to MK :roll:
I am fairly sure everything is tight between manifold and block but will double check again. Have take-off for vacuum gauge in manifold but that is blocked off at the moment. Vacuum connection to distributor is also tight.
On Mark's visit he checked timing and even had rocker cover off to make sure all OK.
Tim,
Will check jet is not blocked. Yes manifold and carb do weigh a lot so will check everything properly lined up. Point on mounting faces noted.
Point on main or idle jet noted. Will investigate.
Tom
tomcat
Post by tomcat »
After a very bad summer health and family wise am getting things in place again.
Imp in for MOT and is running OK. Fine tuning needed.
More to report after result :roll: :roll:
Sorry to hear about your summer, Tom. :( I hope you're health situation is under control at the very least.
Equally, it's good to hear that the Imp is about to make it back to the road! :D I for one look forward to updates and pictures in due course.
tomcat
Post by tomcat »
After minor hiccup at MOT and then additional items added vehicle has MOT; lowered springs and dampers and a front disc brake conversion fitted. :)
Now to tidy up the bodywork areas.
Pictures to follow.
tomcat wrote:Pictures to follow.
8) Excellent. Glad the car is all legal again, Tom. :D
tomcat
Post by tomcat »
Picture as promised a month ago.
Where is time going??
Car sits better now. Time to tidy up the bodywork
8) Looking really good, Tom! :mrgreen:
itsshelby
Car Model: imp californian,imp estate
Post by itsshelby »
nice wee car tom :)
Will we see you and the Imp at a few events next year Tom?
tomcat
Post by tomcat »
bazzateer wrote:Will we see you and the Imp at a few events next year Tom?
Hi Baz
I hope so. have a certain Ibbo plus son, who is bigger than me, 'suggesting' I will be.
