byb610b-benji alloy rad fitted
capriman
Car Model: GREETHAM IMP
Re: byb610b-benji a change of colour
Post by capriman »
That looks like Rover nightfire red - i always wanted to do my Imp that colour but never got round to it.
13" diamond cut superlites, some tinted glass and the later wide chrome strips with the centres painted white and it would look the business infact forget what I just said I might go and paint one of mine like that now :D
Looking good
Darren
Darren Boden
1974 GREETHAM IMP
1967 COMMER IMP VAN
1964 Consul Capri GT
stuartrf
Car Model: singer chamois mk 2 singer chamois mk1
Location: swanley, high brooms, tonbridge, hildenbrough,hadlow
Post by stuartrf »
ist not a rover colour im not going to say the colour as i want it to be the only imp out there like it
for the wheels i will be using the 13 inch wellers im having banded up to 7 j
i am going to have a nice big thick white stripe going down the sides getting bigger towards the rear
i havent really thought about tinting the windows but it would look the muts nuts if i had them dont in red
child: 'why do you wear a full face helmet on your bike'
me: to protect my head, cause thats where the happy thoughts are made
stuartrf
Post by stuartrf »
hi guys
quick update
i started stripping off the underseal from the engine bay totally grim slow job but needs to be done pleased to report that so far it is totally solid
i have a bad feeling that at least one of the wheel arched might be beyond saving so i am considering buying some grp ones and modding them to they quite subtle
ill hopefully get some pics up later
stuartrf
Post by stuartrf »
spent this evening stripping some more undersael off :shock: will look into getting the car blasted
good news though the front suspention is allmost off i just need to undo the top damper bolts and it should fall off :D
strangly it came apart easyer than the suspention on the daily even though it hasent been on the road for 10 years and the suspention on my daily was rebuilt 2 years a go
Post by impmann »
/\ Sounds like you need to invest in some coppaslip, Stu. 8)
stuartrf
Post by stuartrf »
front suspention is off :D was surprisingly easy
im pleased to report it apears to be compleatly solid
so the car is no longer a rolling shell and is just a shell :D
ive still got plenty of work to do including flipping it on its side and removing all the underseal and sorting out some of the few rusty places
stu
Re: byb610b-benji stripped suspention
The car is looking good, Stu. :D Good work.
stuartrf
Post by stuartrf »
ive spent most of the week stripping underseaal off :roll: nasty job but it looks like it has done its job well and the floor including the engine bay and 3 out of the 4 wheel arches are solid
i decided that it would be a good idea if i got the car as high so i have staked 3 wheels and tyres under each corner
fortunatly only the engine bay was redone in seam sealer it is taking a bit of time to get off but again it has done a good job protecting the car
most of the floor now stripped of underseal i will usr a wire wheel when the car is flipped on its side to make sure there is no rust at all
the one and only rotton wheel arch that i will replace
hopefully i should beable to flip the car on its side with in the next few weeks
Re: byb610b-benji underseal removal
Great work, Stu. That is a really unpleasant chore. You have my sympathy! :?
stuartrf
Post by stuartrf »
this weekend benji has been a bit neglected cause i was fitting a replacement engine to my other imp but i managed to get some work done
fuel tank and pedals out
i also managed to get most of the dash out just got the card left to remove
hopefully i should beable to get it flipped on its side next weekend so i can carry on removing the underseal and start welding the holes up
im also toying with the ides of fitting a front rad as this would be the perfect time to get it all cut out and mounting brachets made
ben
Car Model: imp deluxe
Post by ben »
Hi Stu you might want to think abut modding those wheel arches now as well so You can access the dampers easier and protect it from the muck in the years to come, you can see what I mean on this photo of mine
let me know if you want a hand flipping your imp over onto its side.
Ben
Two odd socks do not make a pair.
stuartrf
Post by stuartrf »
hi ben cheers for the pic i was unsure if you could do that to a mk1 because of the extra metal on the front inner arches
but i will crack on with it
any idea what thickness metal was used?
i will text you about flipping it over
Bevan IMP
Car Model: Bevan IMP Group 2
Post by Bevan IMP »
Hi Stuart,
Leave the inner arches as they are, all that work just so you can change dampers !!!!!!!
Its probably weaker with them cut out........
Jonathan
Bevan IMP wrote:Hi Stuart,
Jonathan
The only advantage I can see is theres no mud trap , copper grease on fitting your shocker nuts means they shift easily years later , not a weekly job changing shocks one hopes
stuartrf
Post by stuartrf »
hi guys
looks like the car will be getting flipped on its side this sunday
i supose your right the only real benifit is that no mud will get up there and sieze the nuts but if i use plenty of coper grease they should be ok
ChrisBenoy
Car Model: Clan 'E' 998
Post by ChrisBenoy »
I had always assumed it was done to stop the bodywork rusting out rather than the nuts being hard to shift?
TAGORAMAN
Car Model: stiletto - chamois - californian - super
Post by TAGORAMAN »
If you make the front inner wing mod..it is advisable to weld a closing piece on to the other side of the h bracket this way it adds strength and also stops the crud getting to the top mount.
I'm guessing they're not finished in Ben's pic.
bazzateer wrote:I'm guessing they're not finished in Ben's pic.
Correct. I am going to do this to my Chamois. It keeps the shock absorber mounting nuts nice and clean, as well as eliminating a rust trap.
Duk
Car Model: 70' stupidlow super, 74' not so low super
Post by Duk »
I've just done this to my newest one, the top of the h brackets were filled with crud and another couple of years would have completely rusted through :!: I don't understand why they didnt just build them with the mount enclosed on the inside in the first place :?:
MRG 734G - Deceased!
FYL 900J - Still being welded!
JKO 15N - Sharkmouth
ben
Post by ben »
:) Yep cheers Baz , Duk Chris and IM the crud muck problem is the reason for this and yes it wil get a bit of extra strengthening once I get round to sorting out the brackets for the front mounted rad. 8) need some lessons in Welding before hand tho... oh and the equipment to do it. :lol:
Ben.
chris
Car Model: g15 turbo
Post by chris »
Yep silly not to do it if your modding an imp no water trap is always a good thing!
Wanted..... FREE STILETTO...... PM Me...........worth a try haha :)
My G15 page
https://www.facebook.com/groups/398397523543681/
Duk
Post by Duk »
This is on my super that has completely solid floors & arches, repaired before (badly) on the inside by a previous owner, probably wouldnt have ever got this bad if they had done the mod in the first place :roll:
stuartrf
Post by stuartrf »
i had a visit from ben this morning :D he came round to do this to my new car
im so happy we finally got it on its side it is soo much easyer to clean up the underneath
most of the floor so far is solid
apart from this :o
i know it really isnt that bad fortunatly all the important camptive nuts are stil totally solid so i just needs a plate welding over the top
flipping the can also gave me a chance to have alook at the passenger side as this was the worse side of the car
loverly filler and fibreglass combo in the rear wing
nice bodge ally plate rivited to the inner arch
even though there is a load more work then i was exspecting to do im not rally disheartend about it as its still twice as solid as my daily was lol
ben
Re: byb610b-benji hello rust
Post by ben »
:o Wow you made some real head way on that floor pan after i left 8) keep it up Stu.
Ben
stuartrf
Post by stuartrf »
yer it was easy burning most of it off then using the grinder really shifts it
That's a lot of work for a day, Stu! 8) Great stuff! So it'll be ready for paint by... Thursday? :wink:
Post by james »
stuartrf wrote: Image
Will you be chopping out all the rust and re-building it layer by layer? It looks like the vertical strengthening bit is probably a bit thin to weld to. I wouldn't want you to get it on the road and then have to do it all over again in a couple of years.
Looking good though - mostly cosmetic rust by the looks of it, which is always nice. Hope it all goes well.
stuartrf
Post by stuartrf »
right i got a bit bored today so i started to make a repair section for the floor
to fit here
not to bad for a first attempt but i might make up annother not i know what to exspect making the bent section
or i might jsut keep working on this one to get it to fit well
ben
Post by ben »
Hi Stu, To Quote blown imp it's time for some "C.A.D " Cardboard aided design :lol: :lol: get some empty cereal packets and get making a template.
I need to do the same to close off the top of my front suspension mounts.
Ben.
Stu, I'd bash seven shades out of the one you've already made. :D Make that sucker fit! When I saw the corrosion on your Imp's floor, the panel I imagined making looks exactly like the one you made! :mrgreen: Maybe there is hope for when I attack mine with the welder in the future. :P
stuartrf
Post by stuartrf »
well i gave the passenger side of my imp a bit of a dig with a screw driver today :| not too happy with what i found :(
rear 1/4 went from this
to this with the help of a screw driver and a chissel and hammer
the fromt wheel arch rear section went from this
to this using no other tools than a screwdriver!!!
i am also goign to replace the sill as i managed to get my phone inside to take a photo and saw this
the rear where the lights go is starting to worry my now
there is a few small holes but the area between the lights isnt the right shape so it might have had an accident at some point :cry:
so i am abit fed up with it atm as there is just soo much more work than i thought there would be
but on the bright side i know im not goign to bodge it back together and the only thing going back into that car is metal with the least amount of filler possable
ps any one know what repair section i need for pic 4
Re: byb610b-benji damn thats not good!
Post by colin rooney »
If your going to do it right you will need .2 full sills best type is express steel ,2 front sill extensions express dont do these on there own but if you buy a front arch repair it come on it ,2 rear sill extensions and 2 lower rear corners all express panels ,malcolm does stock some of express panels ,you may also fint that the inner sill will need repairs when you undo the outer sills ,tools you will need is a few spot weld removing drill bits try ebay i get mine on there ,
stuartrf
Post by stuartrf »
cheers for the help col i will look out for some of the spot weld drill bits
ive already got a rear 1/4 and have started to weld up the rear inner wing
all rust cut out^
inner rear pair sections welded in
so hopefully i should beable to get the rear 1/4 fitted up tomorow and welded on later this week
Neatly done. Did you make the repair section or use a bought one?
stuartrf
Post by stuartrf »
i made the repair section the inner wing is now solid and i have started working on the inner arch then when thats dont i can get the outer wing welded on :D
quick question when i cut the sill off will i have to brace the car to stop things from flexing or should it be ok
stu
basil imp
Car Model: imp super 1975, imp super 1973, imp super 1971
Post by basil imp »
stuartrf wrote:i made the repair section the inner wing is now solid and i have started working on the inner arch then when thats dont i can get the outer wing welded on :D
stu
Nothing a bit of glass fibre wouldn't fix!
It's best to brace the car especially if it's rotten in other key areas around the sills
stuartrf
Post by stuartrf »
ok well it is mainly the sill that is rotton the arches both will need replacing but other than that all structial bits seem solid so i will get some old metal pipes and brace the floor where would the best place be to fit the braces?
i jsut went out to the car in hope that i will find the wings are solid as a bit of a mojo boost sure they are solid but they are quite dented and full of filler
:( tomorow i will go down to machine mart and look at dent pullers
so if any one can offer my some sort of mojo boost it will be quite welcome atm :)
bungi
Car Model: 74 super
Post by bungi »
could these help?
http://cgi.ebay.co.uk/Hillman-Imp-front ... 23100f8cac
and i could collect them for you ther not too far from me and get the sent through the imp post or collected at the national :D
If at first you dont succeed HIT IT WITH AN HAMMER
bungi wrote:could these help?
Need to make sure they are the correct ones unless youre prepared to work on them a little, the height of the sidelight/indicator varies depending on early or late model or indeed four headlamp or two headlamp are different around the headlight aperture for the seal on two headlight and none on the four headlight models. worth bearing in mind, but if theyre only 99p well?
