BKS974c
Re: BKS974c
Post by bks974c » Tue Sep 04, 2012 9:13 pm
Video from Berwick Classic Me at 7.40
The miss you can hear has been cured by changing the carbs although still 40 webers, something to do with fuel sloshing. It now means when you handbrake it and then apply power you can actually slide the car. :D
Re: BKS974c
Post by Lotus-e-Clan » Tue Sep 04, 2012 10:36 pm
It's good to be lucky. Every one deserves their fair share. 8)
What kind of oil filter are you using?
Re: BKS974c
Post by bks974c » Wed Sep 05, 2012 7:48 am
WAS using spin on filter actually the large Volvo type. Will be going back to cartridges as never had a problem and have close on 80 in stock.
Part of the problem may have been we had been sitting for quite a while waiting our turn and the temp will have dropped, we were commited to a have a good go - high revs coldish oil = high oil pressure which may be responsible for the partly blown out seal.
Re: BKS974c
Post by Lotus-e-Clan » Wed Sep 05, 2012 8:41 am
Very useful info Scott for those using spin-ons.
IMO it's more evidence to support the unsuitability of the Volvo spin-on filter for the Imp engine.
I have a large diameter Volvo one on the Imp sport motor and it had very high cold oil pressure. Clearly, as discussed on other threads, the cold oil is bypassing the filter matrix via the internal "blocked filter" valve and apart from the resultant high systemic oil pressure's potential for blowing the seal, it's not good that some (or all) of the oil is bypassing the filter matrix when cold.
I reckon the original canister oil filter blocks will soon attract a premium on eBay! :o
Re: BKS974c
Post by benwick3 » Wed Sep 05, 2012 11:34 am
Out of interest, do you have an adjustable oil pressure relief valve? Why do I ask? If adjusted too high at high revs the original oil canister holding the paper element can be blown off its seat with subsequent oil loss. I would expect the same to happen to a canister type filter as well.
Re: BKS974c
Post by bks974c » Wed Sep 05, 2012 4:56 pm
Yes it had an adjustable PRV but has not been adjusted in 6000 miles, but could be a factor as I've never adjusted the valve.
Re: BKS974c
Post by Lotus-e-Clan » Wed Sep 05, 2012 6:41 pm
So approximately what level of hot oil pressure have you been running for the past 6000 miles?
If your hot pressure is way too high then the adjustment is probably the issue.
But if you are in the range 60-75 psi when hot above 4000 rpm then I'd say the finger points back to the filter matrix not coping with cold 20/50 oil, rather than too high a setting on the PRV.
Re: BKS974c
Post by bks974c » Wed Sep 05, 2012 8:02 pm
Hot oil pressure was about 60 psi - however if that was the max pressure generated by the pump and the PRV was say 90 then how do we decide if the filter is also a problem :?
Never mind we have moved on - the cars running and got a few mile on it - any recommendations on running in new bearings - apart from dont rev it to 9500 immediately :lol:
The oil pressure is much more stable now - cold 52 psi mildly reved 60psi hot idle 45psi hot running 52psi so I guess the standard PRV is working correctly.
The last time it was rebuilt I reused the old oil pump as it checked out OK but I guess it wasn't as at idle it dropped to 20psi so although normal and acceptable the bottom end is now healthier than it was :D
Couple of worrying noises upon starting the engine - the first a metallic grinding noise - very worrying :evil: but turned out to be the Alternator when tightening the pivot bolt it was straining the casing and causing something to rub internally - sorted by loosening the rear mounting to block bolts then tightening it all up before the rear mounts.
The other a knock but using the old screwdriver stethoscope its not internal :D and besides it was there before so not important.
Tomorrow check it over and set it up properly and get a few more miles on it before the weekend. Oh and wire the ignition through the oil pressure sender Scott
Re: BKS974c
Post by Lotus-e-Clan » Thu Sep 06, 2012 10:43 am
bks974c wrote:Hot oil pressure was about 60 psi - however if that was the max pressure generated by the pump and the PRV was say 90 then how do we decide if the filter is also a problem :?
Yes, it is a bit of a judgement call because there is the potential for more than one variable influencing the systemic oil pressure (oil temp, bearing condition, PRV operation, filter matrix pore size and blocked filter bypass valve operation).
Because you have re-built the engine it's difficult to directly compare the effect of the two filter blocks especially as you were running modified PRVs. Noddy however, did a straight filter block change (std PRVs) and it cured the very high cold oil pressure he was getting with the spin-on, so my questions were based on his direct evidence, plus mine and other folks high cold pressure issues with spin-ons.
To my mind as long as the PRV is working AND your bearings are (were) good, 60 psi HOT oil pressure is not the maximum pressure that your oil pump can deliver per se. You can be fairly certain that if you were getting a maximum of 60 psi hot all the way from 4000 rpm to 9000 rpm then the PRV IS working and set to (approx) 60 psi (assuming your bearings were not already knackered and acting as multiple pressure relief valves!).
If however, the HOT pressure is 60 psi @ 4k rpm but rises to 90 psi @ 9k rpm then I'd say the PRV setting is set to 90 psi (or higher) or was never going to open at all. ie You only see the max pressure that the pump can deliver when you get to maximum engine revs in the absence of pressure relief.
When the oil is cold, IF it is able to pass through the filter matrix, then the max cold pressure you SHOULD see is equivalent to the PRV setting. In the case of unmodified PRVs (Noddys and on my Sport engine) that should be about 55 psi. I was seeing 80-90 psi during winter cold starts with a std 55 psi PRV because it would seem that the cold oil bypassed the spin-on Volvo matrix and therefore bypassed the PRV too.
If you haven't adjusted the PRV in 6000 miles and the bearings were good at the time of adjustment, then I'd say that 60 psi hot should approximately represent the PRV setting and so the high cold pressures you were getting points to the blocked filter bypass valve opening.
BTW AFAIK bearings should not need to be run-in - they shouldn't be touching the crank! :wink:
Re: BKS974c
Post by bks974c » Thu Sep 06, 2012 4:58 pm
The bearings were new replaced in the last 1000miles so may have contributed to the story.
Can't tell you what the PRV was set at regards pressure but was set at 3 1/2 turns from contact with the spring maybe someone else has info they can relate this to.
Re: BKS974c For Sale
Post by bks974c » Thu Sep 06, 2012 5:16 pm
Well I've not been able to convince myself that the knock (maybe more of a tap) is insignificant and rather than risk the engine I'll be pulling it back out again :shock: and see whats up.
I'm fairly scunnered (look it up if don't know the meaning) and the car is now for sale at £7000 which will include the engine being sorted and a new MOT but not the reg - the Imp is fully sorted having made lots of changes to address issues that have arisen so if you fancy a competion IMP get in touch.
I'm not giving up on Imps need the time to sort the other projects and moving this car on will give me the time and money to do that.
TJB69
Car Model: Bevan recreation/imp Super/Imp Van/Commer Van
Post by TJB69 » Thu Sep 06, 2012 5:25 pm
That's a pity Scott. Hope you change your mind. Watching it on video and it looks a quick wee car. :)
Tom Blackwood
Post by bks974c » Thu Sep 06, 2012 5:56 pm
Cheers Tom, if I get an offer for the asking price I'll let it go and rebuild the Clan as a trackday car as it will be quicker being lighter. If I had the budget to stage rally I have a 66 Chamois that I could build as a proper historic rally Imp so no shortage of options.
If I don't I'll mothball it - I recon the bits on the car are worth more than the asking price so not the end of the world if I have to keep it but I had already decided this was to be my last year of the rallying I have been doing.
Re: BKS974c
Post by bks974c » Sun Sep 23, 2012 8:05 am
Got BKS Mot'd before pulling the engine back out, stripped it and nothing leapt at me but no. 3 rod felt a little tighter in some spots when assembled on the crank out of the engine, so dropped the crank and rods at the machine shop for proper checking. Will see what the story is when I get it back.
Had a look at the head and noted no.1 inlet was further into the head than the others and after removing the valve it appears that the seat is on the move as the top is no longer flush with the combustion chamber and there appears to be swarf at the base of seat so will need to be sent away and see what needs done.
Re: BKS974c
Post by bks974c » Sat Oct 06, 2012 8:34 pm
The machine shop found after polishing no 3 big end that it was undersize so crank was reground plus 10 and they resized no 2 & 3 rods once they were torqued to 30 lbf as per the current spec for ARP bolts.
Whether the resizing was necessary because of the ARP bolts and 30 lbf or a result of the bearing being run is debatable but 1 & 4 were OK so more likely a result of the former.
Engine has been rebuilt now after checking the clearances with pastigage and it now turns over beautifully smooth :D.
The head will be sent away to get a new seat and be checked over and will be reunited with the block when its back, although I'm thinking of changing the R17 for the R20.
Re: BKS974c
Post by bks974c » Sat Oct 06, 2012 9:35 pm
With the Gretham/Chessman on the back burner I turned my attention to the other 998 its short motor has already been rebuilt but the head still needed a little attention.
Its slightly unusual in that it has large ports with a fully reshaped chambers but running sport valves, I'll post up some pics later. The Chessman head has large valves but standard shape chamber and slightly smaller ports.
I ordered some new sport valves and after grinding them in, checked the combustion volume 18cc which probably would have been OK when it was running an R21 but as its now running the reprofiled sport high lift cam it will be too high a compression however as I'm not sure exactly the timing or duration to calculate the required volume.
Tomorrow will set up the valve clearances and order a degree wheel so I can find out the spec of the cam before opening up the chamber.
Re: BKS974c
Post by bks974c » Fri Oct 26, 2012 6:41 pm
See viewtopic.php?f=7&t=23127&p=216861&hili ... ng#p216861
for discussion on the timing of cam.
Its now been built with R20 as this will suit the head, as too revy for the events I do in the Imp its going in the Clan.
TJB69
Re: BKS974c
Post by TJB69 » Fri Oct 26, 2012 6:51 pm
Looking good Scott :D
Tom Blackwood
Re: BKS974c
Post by ImpManiac » Fri Oct 26, 2012 7:10 pm
^^ As Tom says: looking good! :D Those exhaust ports in particular look huge! :shock: Are they the same size as the inlets?
Re: BKS974c
Post by bks974c » Fri Oct 26, 2012 7:15 pm
Since its going to be a wee while before I get the Chessman head back (not even sent it away yet :shock: ) and reunite it with the now rebuilt short motor decided to fit one of the rebuilt ported L4 engines that I did earlier in the year. I chose the one that I built without the cam dowel and see how it fairs.
See viewtopic.php?f=7&t=20512&start=40 for discussion re not using the dowel.
Lovely day, sunny and warm in the sunshine to get on with reinstalling an engine in BKS - had to prepare the engine taking off the heater hose and bypass outlets and blanking them, fit clutch and ancillaries, had to sort out a Sport dizzy and weld up a Sport exhaust manifold.
Tomorrow I'll finish getting the exhaust system sorted, oil in and get it fired up hopefully.
Re: BKS974c
Post by bks974c » Fri Oct 26, 2012 7:50 pm
ImpManiac wrote:^^ As Tom says: looking good! :D Those exhaust ports in particular look huge! :shock: Are they the same size as the inlets?
The exhaust ports are slightly smaller .9 in what's interesting is the finish on the inlet ports is particularly rough up to the guides and beyond a normal finish. Its obviously deliberate and I assume to do with turbulence and keeping the fuel/air mixed.
Its also interesting working with the various heads how the Sport valves "look" better particularly in a reshaped chamber to 1.4 valves as there is room around them for the fuel mixture to enter the cylinder rather than being squeezed to the side. Mind you that might help as its then entering in the centre of the cylinder, but what do I know. :?
Re: BKS974c
Post by ImpManiac » Fri Oct 26, 2012 8:02 pm
bks974c wrote:...but what do I know. :?
A great deal, my friend. A great deal. :wink:
You are right about valve shrouding by the cylinder wall. If I were commissioning a cylinder head for a 998 cc engine (72.5 mm bore), I might opt for 1.37" inlet valves rather than 1.4" ones. For a 1040 cc motor, though, I'd probably still go with the 1.4". I think I've got 1.34-inchers in my 930 cc engine. I've got the build sheet somewhere... :?
The roughness does indeed promote turbulence, tending to keep the fuel mist in suspension rather than allowing it to 'drop out' on to the cylinder walls.
Re: BKS974c
Post by Lotus-e-Clan » Sat Oct 27, 2012 8:21 am
Yes 1.4's are a bit tight even in a 1040 head. :lol:
They seem to work well enough though, even without de-shrouding ... :wink:
Re: BKS974c
Post by bks974c » Sat Oct 27, 2012 5:15 pm
A day of mix fortunes, finished the exhaust system off and went to start the engine - turned over but no spark
:oops: forgot to the connections back on the coil mind it only took abour 30 sec to realise the problem.
Try again, swinging the distributor while cranking it coughs but doesn't catch. Try again but the battery dies, get out a spare and jump leads turns over but still bit slow. Ok try jumping off the Skoda after an initial burst the starter motor makes some odd sounds.
Change the starter motor an easy job with no radiator or water pumps in the road and guess what YES its exactly the same -
the problem was with the jump leads. :oops: Take the Skoda battery out and connect direct to the Imp and it splutters in to life :D
Set the timing and start adjusting the carbs (twin strombergs) making progress when it goes off a bit. rev it and black smoke rechecked everything and it appears to be the needle valve has failed on the overhauled carbs :evil:
Oil on the ground below the drain plug - what do you think ? Plug loose/knackered washer NO crack in the brazing :shock:
that will be a job for tomorrow for the quick steel.
Start over again on the carbs and just about there when it dies, restart it and give it a rev and it dies again - run out of fuel :lol:
Tidy up that enough for today, leg starting to hurt - tripped over the engine thats waiting to be sent away and rattled my shin this morning and its swollen up nicely now. :roll:
Re: BKS974c
Post by Lotus-e-Clan » Sat Oct 27, 2012 5:25 pm
Just one of those days! :lol: :lol: Clan004
Re: BKS974c
Post by Dave ' Linwood ' Lane » Sat Oct 27, 2012 6:02 pm
Its nearly Halloween so if you believe in all this stuff (which I dont ) then things will just go wrong or make no sense whatsoever,
Re: BKS974c
Post by ImpManiac » Sat Oct 27, 2012 9:16 pm
Tough breaks, Scott. Another session and you'll get it there. :wink:
Re: BKS974c
Post by bks974c » Sun Oct 28, 2012 9:35 am
ImpManiac wrote:Tough breaks, Scott. Another session and you'll get it there. :wink:
Its OK no breaks just bruised :lol:
Re: BKS974c
Post by bks974c » Fri Nov 02, 2012 4:55 pm
:D :D :D :D :D :D :D :D :D :D :D :D :D :D :D
Yes I'm happy again - not that I was unhappy at an point :wink:
After 3 days trying to get the new engine to idle sweetly finally I'm there :D resorted to building a second set of carbs and fitting them.
Several issues firstly ignition scatter traced to wrong magnetic ring (loose) fitted to the dizzy - my fault as several electronic ignition types lying about.
Main problem on the carbs - there should be a little button on the bottom of the piston that hold it open very slightly and allow air to flow over the jet orifice at idle and pick up fuel but on one piston it had worn away and so was effectively closed, so it was impossible to get a smooth idle.
As soon as I put the other carbs even from base setting I new it was better, set up was going great until rear carb started pouring fuel out - sound familiar thats because I reused the ones that had failed previously :oops: at least I can throw it away knowing its definately dud :lol:
I also changed the oil due to fuel contamination.
Not able to try it out as currently on Sorn so trailer it to the PCT on Sunday but once round the car park it seems good.
Re: BKS974c
Post by bks974c » Sun Nov 04, 2012 8:52 pm
Woke to brilliant sunshine :D might have mentioned that elsewhere and set off to Forrestburn for the PCT - only about 15/20 mins away from me but as trailering the Imp found some of the access roads to the site were sheet ice making it interesting with the trailer but arrived safely.
The current engine seemed ideally suited to climbing the hills without having to resort to high revs, cleaned hills 2/3 all day and improved greatly on 1&2 in the afternoon when they altered them slightly as high penalties due to the difficulty of them. Achieved 1's on both which was equalled by the trials special but not beaten. :D
Video of the Imp on test 2 - gave the marshal a shot sorry about the quality.
Re: BKS974c
Post by bks974c » Sun Nov 04, 2012 9:42 pm
Put the Imp away after washing the mud and grass off.
Then put it in the Clans space
Couple of pics of the modified air filter box allowing use of the remote air filter with strombergs and the extended throttle cable using brake pipe so can be easily swapped whether using webbers or strombergs.
Still think the Clan would look good in yellow - got some wheels already :D
Re: BKS974c
Post by ImpManiac » Sun Nov 04, 2012 10:40 pm
Sounds like you had a fun day PCT'ing. :D
Yellow suits Clans. Just my opinion. :wink:
Re: BKS974c
Post by bks974c » Sat Nov 10, 2012 4:51 pm
Not strictly BKS news but close enough
Got the rebuilt engine and CR gearbox back into the Clan and bolted up yesterday a relatively painless task as it turned out but missing a number of bits that were at home.
Today put most of the missing bits on and tried to fire it up - backfires indicated timing out - absolutely sure I had timed the cam in correctly not 180 degrees so rechecked the leads. I had cable tied the leads together to keep it tidy and what I thought was 2 & 3 were actually 3 & 2 so put little dots on the lead tops to prevent a reoccurence.
It then fired up :D probably easier than any rebuilt engine I can remember but then the carbs are the webers taken of the Greetham engine and are fully set up so one less variable. Not run it for any length of time as still to sort an alternator and filled the cooling but starts on the key, tomorrow fit the alternator and set the timing, flush the cooling system and take it for a test drive. :D :D :D
GeoffFarthing
Re: BKS974c
Post by GeoffFarthing » Sat Nov 10, 2012 6:21 pm
When removing plug leads, take some poly bag wire ties. No.1 wraps once round the HT lead and twist, No.2 twice and No. 3, 3 times. There is only one plug left for the other one to go on.
Geoff F.
Peter Hurst
Re: BKS974c
Post by Peter Hurst » Sun Nov 11, 2012 10:28 am
GeoffFarthing wrote:When removing plug leads, take some poly bag wire ties. No.1 wraps once round the HT lead and twist, No.2 twice and No. 3, 3 times. There is only one plug left for the other one to go on.
Geoff F.
Or even small cable ties like this for a permanent marker
Re: BKS974c
Post by bks974c » Sun Nov 11, 2012 7:13 pm
Personally I like my tipex dots :) my problem was not knowing where they went 1-3-4-2 firmly etched in my my mind and the location of no 1 on the dizzy cap, rather because I had tied them together I was unable to accuately follow the leads.
Today fitted the alternator and filled the cooling system and fired it up and settled quickly to a smooth idle :D but charge light not going out :( since its running large pulleys I did not expect it to go out at idle but despite reving it only a vague flicker. Removed it and stripped out the brushes pack and regulator and one of the brushes looked quite worn so replaced it and refitted the alternator which sorted the problem although charge light still on at idle.
Took it round the shed a few times and very tractible more so than I was expecting with the R20 but thats the benefit of the Clans lack of weight, sounds very nice too.
Re: BKS974c
Post by ImpManiac » Mon Nov 12, 2012 11:34 am
Great work, Scott! 8)
Re: BKS974c
Post by bks974c » Sun Jan 20, 2013 6:26 pm
Re: BKS974c
Post by bks974c » Mon Jan 21, 2013 9:12 pm
Re: BKS974c
Post by bks974c » Tue Jan 22, 2013 2:12 pm
