Spa Summer Classic 2011
- Car Model: DINKY 138 SCALE 1/1
Francorchamps,sun12,2011,
TROPHEE MAXI 1000
Final Results
Class2(1001-1300)
1st:Philippe Gandini (F):Morris Cooper
2nd:Michel Frenoy(F):Datsun Sunny
3th:Olivier Legriffon(F):Matra Jet 6
Class1:(0-1000)
1st:Michel CHAPEL(B):CLAN CRUSADER
2nd:Cyril Fornage(F):Austin Cooper
3th:René MICHEL(F)GINETTA G15
Jac
TROPHEE MAXI 1000
Final Results
Class2(1001-1300)
Class1:(0-1000)
Jac
Re: Spa Summer Classic 2011
Superb! Great results - first and third in class! Well done to the drivers!
- Car Model: Sunbeam Chamois 1969
Great Michel, congratulations!!!
Michel's Clan and a couple more of imp based "racers" can be seen at the "Montée Historique du Maquisard" (http://www.ecurie-ardennes.be/images/fi ... uisard.pdf). Great fun and a glass of Gales Héritage for all Imper's on our stand.
See you at the "Montée"
Jean-Marie
Jean-Marie
I'll be there,early in the morning,with my son and the Opel Kadett C (GTE replica)N°36.
The Aston 1925 on the publicity poster" Maquisard 2011" will be there too.
It's a real race car(only 3 in the world)...a long time before David Brown.
a vanguard technology
2 overhead cams (3 ball bearings)
4 cylinders-16 valves
forged crankshaft, timing gear and driveshaft (no timing belt,no chain sprocket).
No headgasket
Jac.
No headgasket
Jac.
/\/\Looks bizarre! Do you put the valves in through the cylinders before fitting the pistons?
Yes,but I put the guides after the valves,with 2 fingers(don't need tools for the guides).
The angle of the valves(cross flow)is a problem,the big hole(guides) is the solution.
The lubrication of the camshafts is also a problem(ball bearings).
The solution is the 3 copper pipes in front of the engine.The driver can control or change the oil pressure on the dashboard,in each camshaft and in the timing driveshaft separately.
Jac.
Jac.
Clever stuff. Looks like the driver has plenty to do besides drive, mind!
Fabulous photos, Jac. Thank you for sharing them.
Monoblock engines were common in the 1920s and 1930s - and before. Not so common post about 1940, I believe.
Thank you IM,ImpManiac wrote:Fabulous photos, Jac. Thank you for sharing them.
except after WWII engines DB4 to 6,XK120 and Typ.E,I don't know the golden years of the british technology.
No workshop manual for the fabulous 1925 16 valves,no help and no parts from Aston workshop,they were too busy with the succes of the DB9s.
Jac.
