Cam question
Cam question
Postby J.DURÁN » Sat Dec 20, 2014 4:51 pm
I would like to know your opinions about the best cam for a 998 fast road engine with sport inlet valves, 1,125 exhaust valves and 2 x DHLA
sport cam,R17,BP285,...?
Thanks,
Jorge
Jorge
Hillman IMP
BMW 1602
BMW E30 M3
J.DURÁN
Car Model: Hillman Imp deluxe
Re: Cam question
Postby The Nun » Sat Dec 20, 2014 5:03 pm
R17
Re: Cam question
Postby ibbo » Sat Dec 20, 2014 5:06 pm
if you can get one r20 best allrounder and kinder to valve gear than r17 as has flatter lobes
mark ibbotson
ibbo
Re: Cam question
Postby Lotus-e-Clan » Sat Dec 20, 2014 5:55 pm
Just make sure you match the static compression ratio to the cam to get the best out of it...
For a given cam ...
Standard SCR = 10.0:1
Sport SCR = 10.3:1
R17 SCR = 10.7:1
BP285 SCR = 11.0:1
R20 SCR = 11.6:1
Then, if you want good road manners using twin DHLA's on a combined inlet/exhaust in hot weather (your location!) fit 1 cm insulator blocks between the carb and manifold or otherwise the carbs WILL get hot after 20 mins driving on part throttle and it'll run rough (fuel evaporation).
I'm running a GB72 (BP300 equivalent) with an 11.8:1 SCR on twin 40 DHLA's and it' runs like a pussy cat OR a TIGER when provoked. :D
And there is no reason why you shouldn't get perfect running from any of your choices ...but the devil IS in the DETAIL! Many DIY tuners of the past tended to fit go faster bits off someone else's spec sheet and then wondered how they tolerated such a bag of $h1te in traffic. :)
Re: Cam question
Postby bks974c » Sat Dec 20, 2014 5:57 pm
My recommendation for the R20 too, although it not simply a case of slapping in any cam, the compression ratio needs to be altered to suit each of the cams
to get the best from them.
Re: Cam question
Postby J.DURÁN » Sat Dec 20, 2014 6:57 pm
Thank you for your opinions
I will see what I can get
Jorge
Hillman IMP
BMW 1602
BMW E30 M3
J.DURÁN
Re: Cam question
Postby J.DURÁN » Wed Jan 14, 2015 9:32 pm
I already have a good second hand R20 cam but i do not have the carrier and multi hole sprocket
has anybody some multi hole sprocket?
I have a sport cam, anybody knows the modification to make a .360" cam?
Thanks,
Jorge
Jorge
Hillman IMP
BMW 1602
BMW E30 M3
J.DURÁN
Re: Cam question
Postby J.DURÁN » Tue Jan 20, 2015 8:58 pm
Jorge
Hillman IMP
BMW 1602
BMW E30 M3
J.DURÁN
Re: Cam question
Postby bks974c » Tue Jan 20, 2015 9:25 pm
Don't think its for an Imp
Re: Cam question
Postby J.DURÁN » Wed Jan 21, 2015 9:25 am
Thanks Scott,
Yesterday a friend of my father who has an IMP ( Rally ) provide me this cam. He told me that this cam is for IMP, I see that he is on a mistake
Jorge
Hillman IMP
BMW 1602
BMW E30 M3
J.DURÁN
Users browsing this forum: No registered users and 3 guests
cron
