GRP 6 link pipes
GRP 6 link pipes
Post by moose »
Hi is anyone interested in group 6 stainless steel link pipes to mount an across the back silencer please do not ask how much yet as the more i have made the cheaper so need to gauge interest first the last ones i had made were £50-£60 ish the cost of pipe has gone up since then but as with all things the more pipe i order the cheaper it becomes.
regards mike
Re: GRP 6 link pipes
Post by Turboimp »
i just use a standard stainless 90 degree pipe from demon tweeks about £20 , attach the far end of the silencer to a bracket hanging from the water pump . The whole assembly is then part of the engine with no stress or noise transmitted through the body . i never did understand why people mount the transverse silencer to the body ! Imp009 Clan005
must be some kind of record !
Impecunious
Car Model: Clan Crusader Singer Chamois Sport Audi A4 Quattro
Post by Impecunious »
moose wrote:Hi is anyone interested in grp 6 stainless steel link pipes to mount an across the back silencer please do not ask how much yet as the more i have made the cheaper so need to gauge interest first the last ones i had made were £50-£60 ish the cost of pipe has gone up since then but as with all things the more pipe i order the cheaper it becomes.
regards mike
I just had this picture of a fibreglass exhaust pipe drift through my mind.... :lol: :lol: :lol:
Dave W.
allthingscars
Car Model: sunbeam sport
Post by allthingscars »
Hi yes please put my name down for one.
What we need is a stainless combined manifold to go with it but how much would that cost,just come back from gran canaria stainless must be cheap there all the railings and even the lamp posts are made of it
Kev
Post by Turboimp »
It is time one of the fabricators of Imp competition/combined manifolds spent their time more usefuly producing their art in stainless steel , price isnt a problem , there is no way £850 can be justified for a mild steel one which for me rots in 4 years .... but people do pay those kinds of price .
I have heard excuses that stainless will crack , well that's not the case with my combined manifold which i repaired with some stainless tube and still going strong years/miles later . Also my turbo manifold has stainless primary tubes and thats taken some stick with heat and salt over the years . Other makes and models use stainless manifolds especialy on turbo engines ...
so why is no one making Imp combined manifolds out of stainless , is it planned obsolensence like a lot of cars today ? I suppose they would be out of business within a coupule of years if they did start making them ... Imp009 Clan005
pubcrawler
Post by pubcrawler »
Turboimp wrote:i just use a standard stainless 90 degree pipe from demon tweeks about £20 , attach the far end of the silencer to a bracket hanging from the water pump . The whole assembly is then part of the engine with no stress or noise transmitted through the body . i never did understand why people mount the transverse silencer to the body ! Imp009 Clan005
If you get chance could you post a photo please :D
Didn't want to attach my silencer to the body because of the stress and your solution sounds ideal 8)
Thanks in anticipation :)
Martin Parkes.
Post by Turboimp »
Here is my Clan version which has been on there some years now , I have since removed the silencer in the "normal" position as the motor cycle silencer on there is very efficient at silencing . I used 2 L brackets made from 3mm x 19 mm steel strip , one mounted to the forward end of the lower water pump casing bolt with the lower L part facing back and the other at the rear end of the same bolt with both legs of the L over- lapping and a bolt going through an old poly v belt to secure the end of the silencer ...
Transverse silencer not mounted to the body ...
transverse silencer.jpg (104.15 KiB) Viewed 8125 times
Post by moose »
so far that is 1 then?
you can mount to body no problem so long as you rubber mount it, mine has been rallied like that for 15 years never had an issue, I will look into making a fibreglass one for Dave and other clan owners :lol:
the idea of using the complicated link pipe (compared to a 90 deg bend) as per the group six cars is the tuned length from manifold to silencer is maximised to increase torque something you want to get the most of on a small cc engine when used in competition work.
i have enquired about manifolds in both SS and mild the more you order the cheaper they would be but i am not prepared to invest thousands of my own money to have a batch made to spend the next 20-30 years to get my money back this is the problem with the imp tuning parts do not sell in the quantities of mini or escort parts so the parts are either expensive one off's or unavailable.
apeximp
Post by apeximp »
As you know mike I NEED one 100%
Jim
Post by moose »
i am on it Jim need a spare for myself so we are at three so far will put a post on facebook to see if i can stir up some interest
regards mike
Colin Valentine
Car Model: BS Nymph, Sunbeam Stiletto, Rally Imp
Post by Colin Valentine »
Moose,
Add me to your list for a S/S Link Pipe.
It looks good.
Thanks,
Colin Valentine - Comp Secy & Fantasy Historic Rally man ! We can all dream
brakedisc
Car Model: Clan Crusader, Sunbeam Imp Sport
Post by brakedisc »
I try and make as much as possible for my cars to keep costs down. This has made me a reasonable fabricator but having recently had a go at making a combined manifold I can understand why they are the price they are. The only way to do them cheaply is to spend vast sums on industrial tooling for the stubs and bends and then build a proper millimetre perfect jig for fabricating them. I doubt there is enough needed by the Imp community to warrant this. Perhaps if they were to be made where labour is cheap there might be a chance of this happening.
My next effort will be a cast inlet manifold and a stainless exhaust.
leadfoot
Car Model: hillman imp spring special
Post by leadfoot »
Hi Mike
add one for me please.
cheers Keith.
apeximp
Post by apeximp »
Must be nearly there mike :D
Jim
