Oil cooler pipes
apeximp
Oil cooler pipes
Post by apeximp »
Does anybody know the spe /. Size of the fittings on the oil cooler pipes on a imp ???
Am getting a new mocol cooler and new hoses for a new project
Thanks in advance for any advise help
Jim
Re: Oil cooler pipes
No idea on the pipes but a mocal cooler is no good on an Imp unless its fitted in the front
Mocals rely on ram air , The Imps bog brush cooler is a heat sink type and work much better fitted at the rear
apeximp
Post by apeximp »
Will work fine , after duckting is constructed around cooler :D
Englander
Car Model: '67 Sunbeam Sport, G15, Davrian
Post by Englander »
I think they are 1/2 BSP, and you can get the oil coolers with those fittings.
You might want to consider converting to the Dash fittings on a race car.
==>Why, Mr. Anderson? Why? Why do you persist?
==>Because I choose to.
Think Matrix, not Malcolm
doc knutsen
Post by doc knutsen »
Englander wrote:I think they are 1/2 BSP, and you can get the oil coolers with those fittings.
Use Aeroquip or similar, -10 ("dash ten") is the size to use. A bit expensive, but once fitted, there is one less thing to worry about. And, of course, the hose ends are fitted using normal hand tools, and are re-useable.
Post by moose »
