Good Imp Racing news from Norway! (video)
knutspeed
Post by knutspeed »
It's been a long time coming, but yesterday we finally managed to get both Imps to the finish! In style as well, as we netted 3rd overall, 1 class win (1300cc pre 71 FIA) and 1 class 4th. 20+ cars in the race, finally got to give the Minis a good fight!
Saturdays races were looking good until the last couple of laps when both cars stopped for truly silly reasons - one broken rotor arm, and one dead condenser. Gotta love those far-east spare parts...proper items now fitted of course.
George, the Bevan tribute car has a new Norwegian, locally built engine which ran perfectly. Most impressive was the fact that it was so clean post-race, I'd have no problems serving a 3-course dinner on it!
Videos etc, and some tech/set-up questions to follow!
Matthew Birger Patrick (Knutsen)
Sarpsborg, Norway
FIA App K Historic Racing Imp - Bevan Tribute - www.shag.no
knutspeed
Re: Good Imp news from Norway
Post by knutspeed »
The camp & cars. Hoping for some action shots in a few days.
Sarpsborg, Norway
pubcrawler
Post by pubcrawler »
Very impressive set up and so clean :o , well done :D .
Look forward to seeing some action footage soon 8) .
Congratulations! Well done. :D
Excited to see more. :)
Nice work! :mrgreen: Looking forward to the videos. :wink:
Impecunious
Car Model: Clan Crusader Singer Chamois Sport Audi A4 Quattro
Post by Impecunious »
Lovely cars guys :D
All the best to you and Fredrick.
Dave W.
Clan003
Gaffer
Car Model: Sunbeam Stiletto and an Imp project
Post by Gaffer »
Love to look of the Imps. 8)
Nice to hear 'arched' Imps doing well. Looking forward to any vids you may have.
Pete
Trying to keep the faith.
knutspeed
Post by knutspeed »
Thanks for the positive feedback!
Managed to hack some video from this weekend, both cars, various camera angles. The blue car sounds like a mini-DFV when off the throttle!
https://www.youtube.com/watch?v=_KTCL9qeEu4
Sarpsborg, Norway
pubcrawler
Thanks for posting, great battle with the yellow mini towards the end :o (he cracked under pressure eventually :D )
Re: Good Imp Racing news from Norway! (video)
:D :D :D :D :D :D
knutspeed
Post by knutspeed »
Anything stiffer than 800lbs rear springs available?!
Sarpsborg, Norway
Post by SimonBenoy »
You've got too much grip! With Dunlop historic crossplies, 800 is OK.
knutspeed
Post by knutspeed »
Trouble is - here I'm running Yokohamas, but I would have been running the much wider Avon ACB10s if I had the clearance...we run those on the other car no problems, and the grip is fantastic. Period G (71) - no chance to run the (fun) Dunlops - i'd be way off the pace.
The Yokos didn't feel that grippy, believe me I'd like more! Gimme Scalextric performance!
Sarpsborg, Norway
Post by colin rooney »
Great result and nice video
Indeed he did : And it wasn't too far away from a whole bunch of Armco, by the looks of things :o
Andy G. Image
Post by 19James »
knutspeed wrote:Anything stiffer than 800lbs rear springs available?!
Maybe try a relatively soft rear anti-roll bar?
I think George Bevan used the narrow springs inside the normal ones to achieve some sort of progressive action. On some occasions anyway.
The rightmost one is an 800 racing. Sorry I don't know specs for the smaller one.
knutspeed
Post by knutspeed »
We had a look at the rear, and everything seems ok. Fredrik has fitted Bevan-style helper springs with shims, we'll see what that does. The car sat very low at the rear on the Yokohamas, might be that the R/F weight distr. was offset even worse which amplified the one-wheeling. Previous springs were softer, but taller than the 800s.
We'll also bring some other dampers to try if this doesn't cure it. The plan is to run the fat ACB10s at Velodromloppet in just over 3 weeks. Challenge is, they're not much good if it rains compared to Yokos so we'll need to get the rear ride height set up for both sets of wheels which are quite a bit different in circumference. Should be a hi-lo kit available for Imps :wink:
Sarpsborg, Norway
knutspeed
Post by knutspeed »
Theres also video from a Norwegian sports channel covering the races with good shots of both Imps (norwegian commentary, but good video). http://vimeo.com/66625469 (go to about 10 mins into the film to bypass the rather ugly locosts).
Rally champ and legend Stig Blomqvist ran a Ford Galaxie, and of course, won overall after a good battle with an Elan.
Sarpsborg, Norway
Post by benwick3 »
You can make the rear height adjustable very easily. In involves drilling and tapping the the bottom of the spring holder in the trailing arm at three equidistant positions. You then cut a rigid thin steel disc to fit in the bottom of the spring seat. Bolts are then screwed into the previously tapped holes to raise/lower the plate and thus the spring. You will also need to fit nuts to bolts so that they can be locked off against the underside of the spring holder. Hope that makes sense. Works fine at altering the rear ride height on my Clan.
knutspeed
Post by knutspeed »
Sounds a good idea, thanks! Will have to check if it's allowed in app K, or maybe somebody knows?
Sarpsborg, Norway
Post by benwick3 »
I think it's not if it's allowed but if its specifically not allowed!
doc knutsen
Car Model: Sunbeam Imp Bevan replica
Post by doc knutsen »
Lars Hagermark(DJH705) wrote:I think George Bevan used the narrow springs inside the normal ones to achieve some sort of progressive action. On some occasions anyway.
Thanks Lars, the secondary springs will be fitted to Matt's (blue) car for Velodromloppet. I have a pair which came with the ex-Chrysler Sweden Imp run in the mid-Seventies, for Slim Borgudd (originally built by Ivor Goodwin) and purchased by me from Mats Warg of Falun...just about to finish machining an alloy "top hat" for twin springs, to fit in the chassis spring towers in order to locate the inner spring properly.
Incidentally, with Matt's car and mine being entered for Karlskoga, there will also be a pair of Danish Imps for the Historic Grand Prix as well.
However, the organizers have seen fit to amalgamate saloons and GT cars in the up to 1972 class...so we now face taking on a Ford GT40, no less, in our race...which may prove to be a bit of a challenge, even if our Imps are pretty quick :roll:
