water pipes
water pipes
Postby roperdev » Wed Oct 10, 2012 8:48 am
Can anybody confirm if the water pipes passing through the car to the front rad,have to be metal ?.
Could I just use red silicon hose?
roperdev
Car Model: hillman imp 1971 rally car
Re: water pipes
Postby Duk » Wed Oct 10, 2012 9:28 am
They don't have to be metal, anything will do aslong as it's resistant to the antifreeze/coolant and a bit of heat. I use a combination of silicon bends and oversize rubber heater hose
MRG 734G - Deceased!
FYL 900J - Still being welded!
JKO 15N - Sharkmouth
Duk
Car Model: 70' stupidlow super, 74' not so low super
Re: water pipes
Postby bazzateer » Wed Oct 10, 2012 9:44 am
For a road car you can use anything really. For competition you'll need to consult the Blue book.
Car Model: 68 Chamois Sport, 72 Imp Sport, 72 Deluxe
Re: water pipes
Postby Richard Claydon » Wed Oct 10, 2012 9:53 am
bazzateer wrote:For a road car you can use anything really. For competition you'll need to consult the Blue book.
Blue book says on page 145, Section J 5.10.1 - "Have any fluid lines or tubes carrying coolants through the driver/passenger compartment painted red, and if non-metallic to be internally or externally metal braided hydraulic pressure hose."
Rich
Richard Claydon
81 Sport
67 Preproduction Stiletto
65 Works Rally Car
Richard Claydon
Car Model: 65 Ex Works Rally Car
Re: water pipes
Postby Duk » Wed Oct 10, 2012 1:12 pm
Sorry didn't realise it was in the motorsport section :oops:
Duk
Re: water pipes
Postby colin rooney » Wed Oct 10, 2012 1:54 pm
pipe in the car should be 1 piece most people seem to use copper pipe i can make them in alloy not cheap but very lite
Re: water pipes
Postby Turboimp » Wed Oct 10, 2012 5:48 pm
metal best as it gets rid of some heat from the coolant on it's way through , Every little helps ! Imp009
must be some kind of record !
Return to Motorsport Forum
Users browsing this forum: No registered users and 3 guests
