Imp sidecar unit
Imp sidecar unit
Post by Meltdown »
Spent a dry, sunny, mud-free day at the races today...no not Silverstone but Mallory Park for the Festival of 1000 bikes where we saw this tidy chair, supercharged plus BIG dizzy :o :D
Re: Imp sidecar unit
Post by ganderson888 »
Now if someone wanted to put THAT bike engine in an Imp I'd understand it!! :lol: :lol:
tzarrobin
Car Model: Imp Super
Post by tzarrobin »
That big dizzy is a Scintilla Vertex magneto. :lol:
'66 1220cc EFI Imp Super
'70 Skoda S100 (almost ready to return to the road)
classiccapsule
Car Model: Sunbeam Stiletto, MK2 Mini
Post by classiccapsule »
Wow, when you look at something like that, you realise why it hurts so much when you come off and the importance of knowing when to let go! :shock:
Making visual treats every day to adorn your oily loved ones!
Awesome! :o What a fabulous piece of kit. I bet it sounds lovely too. :)
I was thinking that looked like a magneto.
Post by Meltdown »
tzarrobin wrote:That big dizzy is a Scintilla Vertex magneto. :lol:
Aha, that'd do it :D Never seen a magneto on an Imp as far as I know.
long_gone_John
Car Model: 3 sal ('74/'64/'64)-all gone!!
Post by long_gone_John »
MY 998 - Ex Chair - drove through a big belt pulley on the flywheeel end - I discovered it had no Spigot Bush, as it had never been in a car!
Also..... it had been canted over the other way [from this one] & the racer had drilled 'through holes' under the camcarrier, through the head casting, to enable oil to run back to the timing chain :!:
Ports were enormous, matching the Works in/ex grey gasket... 8)
LGJ
875- GGR 640N - Scrapped
930- 533 KNX - Stolen
RoyBlunt
Car Model: 1966 Hillman Super Imp, 1981 Triumph Spitfire 1500
Post by RoyBlunt »
I was also at the Mallory Park Festival of 1000 Bikes (great day as usual) and was surprised to see the 'Impulse' sidecar sprint outfit as I have been following motorcycle racing since 1965, bought my Imp in 1969, and thought I knew most of the Imp powered motorcycles/outfits - but I'd obviously missed 'Impulse'. On contacting the Vintage Motorcycle Club sprint section I received the following info on Impulse from Chris Ilman:
Roy, I can probably help you with your queries as I have a huge archive of material and ‘Impulse’ is well known to me. The Machine ‘Impulse’ was built and ridden originally by a guy called Vic Phillips in the late 1960’s. Vic also built another Imp based Sidecar with a bigger capacity to attack World Records in the 1300cc Class. That one was called ‘Impetus�� and was successful in capturing World Records in 1966 at Elvington (Yorks). I do not believe ‘Impetus’ survives. ‘Impulse’ has been owned now for a good few by fellow Sprint enthusiast Paul Standing. He campaigned it extensively during the 1990’s and then put it into retirement. I has very recently been rebuilt/restored and Mallory Park was the very first time since the extensive rebuild that it ran under power again. It will appear again over the next couple of years at a number of VMCC Sprints driven by Paul Standing. ‘Impulse’ has a great pedigree and when running well is capable of outstanding performance. It is ‘Blown’ by a Shorrock’s C142 Supercharger. I hope this helps in your quest for further information. If you write a piece on Impulse, I would love to have a copy for my Archive. Kind regards, Chris Chris Illman – VMCC Sprint Section
In contrast to 'Impulse' I remember seeing (and hearing!!!) 'Impetus' at Santa Pod - probably around 1969. There is further info on this machine on http://www.imps4ever.info/specials/moto ... -1966.html
Imp011
I wonder if this is the same outfit that I took photos of at the Brighton National Speed Trials last month. I'll try to remember to take a look when I get home. I should post my pictures really. :)
oily bloke
Car Model: Impulse Supercharged Sprinter
Post by oily bloke »
Yes it is the same as you saw at The Brighton Speed Trials and it was me Piloting it.
I will post some more info later if anyone is interested but here is a brief prece' of what went on.
I first came across Impulse some 15-20 years ago, which was and still is owned by my good mate Paul. It was languishing in Pauls garage where it had been abandoned after suffering some reliability issues. Particularly with the Wills rings which seal the combustion chamber and the usual Imp issue of boiling up. I expressed interest then and continued to pester Paul on and off over the years to rebuild it as it is a really trick bit of kit. The years passed and out of the blue Paul called me in January this year and said "Fancy building the Imp for me? you can pilot it for me as well if you like"
It would have been rude to say no.
The bike was duly collected and brought back to my workshop where the build began in earnest. Having been through a house fire and a leaky shed the old girl was in a bit of a state. Thankfuly the motor and the fairing had been stored elsewhere and had simply suffered the ravages of time and had not succumbed to flame or water. The blower was siezed solid and a tide mark could be seen where it had been full of water. The frame and cycle parts together with the transmission was very rough. The idea was to get it running and ready for the Festival of 1000 bikes at Mallory in early July. We just about made it and it ran for the first time about a week before the event.
In the mean time, Paul had managed to locate the guy who built it, Mike Pierce, and got tickets to him for Mallory.Vic Phillips the origonal driver/rider is still with us but was unnable to attend. Mike duly turned up and it was worth all the agg just to see his face. We ran the bike up and Paul attemped a gentle run (First dibbs to the owner) as it has not moved under its own steam since the build. Low oil pressure, an oil leak on the righthand side of the block and a badly burned left foot (Paul innadvertantly put his toes over the end of the exhaust burning a hole in his boot) The shakedown was declared a success.
We entered the Bike at the Wroughton Sprint and it was my turn to have a go. 1st run badly slipping clutch. 2nd run and 2nd set of plates cooked. 3rd run set clutch alight. bother!
Next up was the Brighton Speed trials. New clutch and Mick Pierce in attendance we suffered the same Clutch problems. Very heavy springs fitted and the adjusters wound right up I managed a half decent launch but the clutch cried enough about halfway up. I had to shut off anyway as the bike felt unstable and was pulling hard to the left.
Back in the workshop we decided that the gearing was too tall and that radical clutch mods were required. We have fitted a Bewley clutch and are about to attend to the handling problems.
The Wills rings are sealing fine and the addition of a rad and an electric pump have solved the cooling issues
A bit less brief than I intended but hopefully gives you the idea.
Sincere thanks must go to Paul (who owns the bike) Steve (who pushes the bike a lot and makes me laugh) and Juan and Jane for their encouragement and last but not least Deb my ever suffering wife.
So, if you want some more and perhaps some piccies say so and I will oblige.
Andy.
Post by bks974c »
Yes please we like pics and more info would be good.
RoyBlunt
Post by RoyBlunt »
All (including, in particular, Andy),
Great info - and I would love to see the pics too. Just to let you know that (at Graham's suggestion) I contacted Paul Standish about the possibility of bringing 'Impulse' to an Imp Club event in 2013. The reply was essentially positive and was copied to Andy for his information & opinion. We could be going round in circles here......
Roy Imp011
It is so cool that you have posted! :mrgreen: :mrgreen: Welcome to the forum!
oily bloke wrote:So, if you want some more and perhaps some piccies say so and I will oblige.
Yes please! 8) I am going to post my Brighton pics tonight, inspired by your post. Keep the info coming! :wink:
oily bloke
Wow. Thanks for the response. That will be a yes then :D
I will get some pictures and more words together and post them soon.
I was aware that Paul had had an email regarding bringing Impulse to one of your events. Mention was made of a 50th anniversary of the Imp. Subject to where you want us as we are based in Kent & Surrey, we would be more than happy to bring it along.
Andy
Andy, next year's (2013's) 50th anniversary Imp international meeting is being held at Perth racecourse in Scotland. :D If you could bring the outfit up to that, it would be brilliant! If not, there are other 50th anniverary events happening closer to Surrey and Kent, such as in Coventry in early May. Some information has appeared about these events in Impressions, the Imp Club's excellent magazine. Are you and/or Paul members of the Club? :?: It is brilliant value for money. :wink:
oily bloke
Hi Paul,
I think that Scotland may be a bit too far and cost prohibitive. We are not members of the Imp club as, primarily, a motorcycle sprint/drag rider my allegiences have a at least 1 less wheel. Usually 2 less :roll: I already belong to too many clubs and am on the committee on one as tech official. Sadly, time and funds are tight.
If you or someone within the club can let me or Paul know when and where your events are, we will do our best to attend at least one of them. Paul races grasstrack as well as sprints and I race sprint meetings so the diary fills up fast but I am sure we can find an event that doesn't clash.
Our race season is just about over so I will post the dates and venues that Impulse will be competing at in the new year.
Andy
Keep an eye out for events and meets in celebration of the Imp's 50th anniversary next year. :wink: I shall try to remember to send you a list next time I see one. It will be via a Private Message (PM) on this forum. :)
I am certain that I am not the only one looking forward to more details and photos of Impulse. :mrgreen:
Hi Andy,
There's a list of our events for 2013 in the attachment below.
If Impulse is available for any of them that would be great and please let me know by email to: chairman@theimpclub.co.uk
Look forward to hearing from you
Exp of interest form.pdf
(246.64 KiB) Downloaded 274 times
Post by Meltdown »
Great to see such a positive reaction to my photo's from Mallory. Yes please to some more, maybe 'in action'?
Post by bks974c »
^^ What an amazing find! :shock: Thank you for sharing it, Scott. :mrgreen: I wish it had sound.
