Front top Koni type spring seats
Nigel Webster (anrw)
Car Model: None currently
Post by Nigel Webster (anrw) » Fri Nov 25, 2011 7:25 pm
I am looking for a pair of steel cups / spring sdeats used with Koni wide body (HD) front shockers. They are the cup that the top of the springs fit into and sit under the wheelarch top spring mount. They have a similar function to the rubber upper spring seats used as standard but the inside dimension is designed for the Koni shock absorber. They are the black parts in the photograph.
Anybody got a pair?
Nigel Webster
