Turbo Test Engine - Test Completed
skamanfrank
Car Model: 1972 Imp Super
Re: Turbo Test Engine - Test Completed
Post by skamanfrank » Wed Aug 31, 2011 11:52 pm
Great reading as always Eric.
Any photos of the RR readout with power/torque curves. Would love to see the shape of the torque curve with combination of turbo and R20 cam!
Frank
pimpdriver
Post by pimpdriver » Thu Sep 01, 2011 6:21 pm
Tom
I'm only out one more time this year, 17th September at Thorseby Park near Nottingham.
Frank
The RR readout from the tuning session. The red lines were at 13 psi and the blue lines were at 11 psi ( i think, not really sure).
The spike at about 6300 revs is the slight over boost as the boost control opens and then settles at about 1psi less
Eric Morrey
Rawlson Imp Turbo
'Irish' Clan
Rover 75 waft-mobile
Hillclimb Clan - Resting
skamanfrank
Post by skamanfrank » Fri Sep 02, 2011 1:22 am
Cheers Eric.
Everyone talks about nice flat torque curves with forced induction... I was intrigued to see what the effect of the R series cam would be.
Frank
Post by Turboimp » Fri Sep 02, 2011 9:43 pm
I had a R 17 in my first turbo imp engine in 1983 with a fairly big IHI RHB5 turbocharger and 8:1 compression ratio .I went up to see alan allard for advice and this was nearest size available at the time . There was no off boost torque at all up until 3500 - 4000 rpm when things started working seriously , It came on very strong after that all the way to 7500 + rpm . At the time, by the huge performance and 0-60 time of around 6 seconds and weighing not far off 900 kg i estimated around 170 bhp . looking at the curve above i rekon it was very similar except for my lack of torque up to 4000 rpm .. I didnt have the luxury of mapping and dyno sessions in those days , i judged the performance by which type of cars i could pass :-) .My latest untested incarnation is a higher compression ratio , emerald M3D managment ( injection and ignition ) and a sport camshaft , aiming for about 130 bhp this time with a lot more torque using one of a pair of Mitsubishi water cooled turbo chargers from a Volvo T6 ( 3 litre 6 cylinder ) That leaves me with a spare turbocharger for my clan one day , i already have the CBR throttles and manifold made ... but the clan cries out for higher gearing already , so will try to fit the Skoda estelle 5 speed transaxle i accquired ten years ago in the clan if not too much surgery is needed . Has anyone tried these tiny turbos off 1000 c - 1400 cc modern engines Diesel or otherwise ?
must be some kind of record !
apeximp
Post by apeximp » Sat Sep 03, 2011 6:50 pm
Hi there pimpdriver , can you tell me , did you use btec in shipton apon Cherwell to do your rolling road run ??? It's just that I plan to use them in a few weeks and I see the btec logo on the print out you posted !!!
Jim
pimpdriver
Post by pimpdriver » Sat Sep 03, 2011 8:35 pm
Jim
It was done by Andrew Bradley and Btec at Shipton Under Wychwood. I assume this is the place you meant. Very friendly garage and knows what he is doing.
Eric Morrey
Rawlson Imp Turbo
'Irish' Clan
Post by Meltdown » Sat Sep 03, 2011 8:54 pm
What turbos do people fit to Hayabusas? Might be suitable.
apeximp
Post by apeximp » Sat Sep 03, 2011 9:09 pm
Hi Eric , yep that's the place / guy ! Don't know if you have read my posts & thread about my fraser imp replica have swapped from a 998 to 1040 engine and fraser b cam to a R23 same ignition system but carbs were swapped over without change ! Car was set up on rr for the 998 but not the 1040 and have / am experiencing lack of top end power , are they able at btec to make jetting adjustment (do they stock parts & able to do the work) your advice and recommendation is very helpfull . Jim
pimpdriver
Post by pimpdriver » Sun Sep 04, 2011 7:06 am
Jim
That's a good point, I don't know if he has jets etc for carbs, as i'm running on Fuel Injection so it was tapping on a laptop. Unfortunately for most cars they see now, its all laptop based. For interest, Andrew at Btec was quite happy for me to alter the settings under his guidance. I would give them a ring and confirm whether they can do what you want, it would be a waste of time if they don't have any jets. The place is a Garage first with a rolling road added so I can't see a problem with them fitting jets, its just if they have them.
Eric Morrey
Rawlson Imp Turbo
'Irish' Clan
Post by cov_climax » Sun Sep 04, 2011 4:54 pm
as eric says above give him a call, I know BTEC has done Jonathan Gomm's (no relation BTW) lotus cortina that runs in the HSCC so may have a selection of jets
Post by Meltdown » Sun Sep 04, 2011 5:46 pm
cov_climax wrote:as eric says above give him a call, I know BTEC has done Jonathan Gomm's (no relation BTW) lotus cortina that runs in the HSCC so may have a selection of jets
That cort would I believe be running on carbs not injected so sounds promising. Best let Apeximp know too :D
TTK 25L
Post by TTK 25L » Sun Sep 04, 2011 6:39 pm
Meltdown wrote:What turbos do people fit to Hayabusas? Might be suitable.
There is not a cat in hells chance of a turbo destined for a Busa being suitable for an Imp engine, turbos for big bike engines are big bu99ers due to the high rpm of the engine and the high air flow requirements at that engine speed. Even a turbo from a Mitsibushi Evo whatever has to be modified to increase the flow to suit a Busa!
Well done Eric, sounds like yours is going well, especially going by your times at Gurston!
Greetham
Car Model: zx12r turbo imp
Post by Greetham » Sun Sep 04, 2011 7:00 pm
gt28r gt35r gt40 all no good for the imp but gt 28r can be speced to suit eg by atp turbos usa
zx12 turbo killer imp zcars 1 off
Post by Meltdown » Mon Sep 05, 2011 5:53 am
/\/\Aah I see. Ok.
