HRSR AGM
apeximp
HRSR AGM
Post by apeximp » Sat Nov 06, 2010 7:00 pm
Do any of the imp racers know anything of the possibility of the weight limit currently set at 680kg being changed for 2011 ?
Mike Hanna
Car Model: 2 ZIMPS, 2 SINGER CHAMOIS, 6 HILLMAN IMPS
Re: HRSR AGM
Post by Mike Hanna » Sat Nov 06, 2010 10:26 pm
Hi. Unless you are going to propose the Imps get heavier I doubt there is any chance of a change in weight as the Imps are getting too damned quick for em!!!. Mike
Re: HRSR AGM
Post by SimonBenoy » Sat Nov 06, 2010 10:40 pm
Jim
If someone proposes a rule change ahead of the AGM, it will be discussed and then voted on - but previous attempts to reduce the weights for class E have not been successful. We have been promised that the committee will review the weights regularly.
If you are going to 1040, you will have to be 710kg. Will you be down to 710 for the new season?
Thanks - Simon
apeximp
Re: HRSR AGM
Post by apeximp » Sat Nov 06, 2010 11:26 pm
Hiya Simon , car was found to be nearly 750 at my last event ! I hope with the change of doors and removal of my very nice but heavy door cards I should get to the 710 mark !
You going to the agm ?
