Tow points
Nigel Webster (anrw)
Car Model: None currently
Tow points
Post by Nigel Webster (anrw) »
Is there a generally accepted best method for attaching front and rear tow points to a competition Imp? Is using one of the bumper mounting points considered to be strong enough or is local strengthening deemed necessary?
anrw
Nigel Webster
apeximp
Re: Tow points
Post by apeximp »
Most of the hscc guys use chassis points ! I use o/s/r chassis leg and tuck the webbing tow belt into the battery area , front is also on the chassis , same side and tucked up into the front boot area as I have cut the floor area out for the front rad ! I live not to far away from you in Oxfordshire but my car is currently away having work done on it , am happy for you to come and have a look over it once she is back home !
johnh875
Re: Tow points
Post by johnh875 »
Have seen a towing eye mounted to the front wishbone pivot points.
