Spaceframe Imps
leeboy44
Car Model: hillman imp
Re: Spaceframe Imps
Post by leeboy44 » Fri Jul 30, 2010 4:15 pm
many thanks :)
grahamdelooze
Re: Spaceframe Imps
Post by grahamdelooze » Fri Jul 30, 2010 10:59 pm
Hard to get a car under 400kg. I bought the spaceframe which became the Benoy Rawlson off Ian Toon he knows the history of the car.
If your building a new spaceframe then it would be better to choose a multi tubular design that resembles a triangulated roll cage than get hung up trying to poduce a true spacframe out of loads of small tubes, its also easier and cheaper and more robust.Dont get me wrong I still like bronze welded small tube frames ive done a few but they are very time consuming and expensive.Also consider a simple riveted alloy tub center section which doubles as the lower body with front and rear tube frames with something like the jedi grp body on top.
graham
speeddemon
Car Model: None
Re: Spaceframe Imps
Post by speeddemon » Tue Aug 03, 2010 11:46 am
All been a bit quiet on this post, However hoping to post some pictures soon. Body shell is nearly ready for primer, chassis needs a few days and powder coat , il put them up asap, thanks all mike
jonboi997
Re: Spaceframe Imps
Post by jonboi997 » Tue Aug 10, 2010 8:17 pm
hi all new to this forum been following this excellent thread for a while !!
and i really want to do a full space frame imp does anyone know how many metres of cds steel i will need roughly ?
i was thinking 75 metres ?? too much ?
jon
doc knutsen
Car Model: Sunbeam Imp Bevan replica
Re: Spaceframe Imps
Post by doc knutsen » Wed Aug 11, 2010 5:27 pm
jonboi997 wrote:hi all new to this forum been following this excellent thread for a while !!
jon
Get the weight of a bare tubular frame of a design close to what you are aiming for, and establish the weight per metre of the steel tubing that you are proposing to use. That should allow you to calculate roughly how many metres of tube you would be looking for. Calculate on some tubing having to be thrown away due to wrong measurements or shaping...unless you are very experienced :o)
Incidentally, I find Tig-welding the structures very efficient and with little heat distortion. Although the fit of the tube junction is fairly critical. (do invest in a good tube notcher if you haven't got one already).
big J
Re: Spaceframe Imps
Post by big J » Thu Aug 12, 2010 12:23 am
Jonboi,a guy I know is building a Lotus 7 type thing,he's got about 50m of 1" tubing in it he reckons.
Here's a chart I found that might help some with weight calculations.
http://i21.photobucket.com/albums/b288/ ... eights.gif
Hope that helps.
big J
Re: Spaceframe Imps
Post by big J » Thu Aug 12, 2010 12:43 am
Speeddemon Mike sent on some more pics,he's put a ton of work in by the looks of things.
Good man,Mike.
Re: Spaceframe Imps
Post by colimp66 » Thu Aug 12, 2010 8:29 am
Thats pretty impressive.
Alot of work put in there :mrgreen:
speeddemon
Car Model: None
Re: Spaceframe Imps
Post by speeddemon » Thu Aug 12, 2010 9:00 am
Im trying to keep this thead alive, so if anyone has new or old projects up and going add them to the thread.
My fibreglassing skills are fairly basic but thats all these things need. Its alot of common sense and having a go, lucky for me as ive said neighbour has helped me out but doing the new moulds was fairly straight forward.
Cars now in primer and we are painting this weekend. Cars going to be White ( the new ford white ) then with a mix of silver, kawasaki green and black graphics.
Most race cars are pretty basic, but we want the car to stand out. I still am unsure how many cars are still racing?
Hopefully the power unit is going to Andy at Shrigley engineering for pull down and inspection thursday, we already aquired one of there Billet light weight flywheels and we are looking to increase the power output if possible.
Next on the list is a new stilletto.
It wil be a new breed of chassis called the ( Keimer chassis )
big J
Re: Spaceframe Imps
Post by big J » Thu Aug 12, 2010 11:09 am
Sounds good Mike.
Where does the name come from?
speeddemon
Car Model: None
Re: Spaceframe Imps
Post by speeddemon » Thu Aug 12, 2010 4:56 pm
Top secret name, but i think its catchi in a japanese type of way hahahahh :D
jonboi997
Re: Spaceframe Imps
Post by jonboi997 » Thu Aug 12, 2010 9:12 pm
hey your bodywork looks sweet speeddemon be nice to see it in paint
thanks for the advise doc knutsen and big j :D
this a really good thread lets keep it going
jon
Re: Spaceframe Imps
Post by ImpManiac » Thu Aug 12, 2010 10:24 pm
Awesome, Mike! Fantastic work! 8) Keep it up!
big J
Re: Spaceframe Imps
Post by big J » Mon Aug 23, 2010 5:07 pm
Latest update from Speeddemon,car's looking great.Nice work Mike! :D
Re: Spaceframe Imps
Post by ImpManiac » Mon Aug 23, 2010 8:45 pm
:shock: Very nice indeed! It's going to be a great looking spaceframe racer! 8)
speeddemon
Car Model: None
Re: Spaceframe Imps
Post by speeddemon » Tue Aug 24, 2010 8:10 am
Im really happy with the car, its taken quite a bit of work , but mainly labour time and patience. We are just waiting on the frame which is due back this week in Kawasaki green. We hope it will be one of the best prepared.
Dependant on circumstances we may sell the car but initially the car will be shown and raced at Oulton Park in next years local race series.
Once we have finalised a few things we are moving onto the stilletto.
Regrads
Mike
leeboy44
Re: Spaceframe Imps
Post by leeboy44 » Sun Sep 05, 2010 10:32 am
mr george gunn has set off from sunny scotland toe not so sunny wales with hes stunning jedi imp
we have the lovely job of getting it running, doing all the wiring and a few other bits and bobs
george must of been happy with the work we done fitting the engine and has booked the imp in for a few weeks work!
ive made my mind up and i will be placing an order for a shell and i will be building a imp very soon
all i need is the shell as ive prtty much got the rest
i will keep you posted with the jedi imp
lee
spaceframecars
speeddemon
Car Model: None
Re: Spaceframe Imps
Post by speeddemon » Mon Sep 06, 2010 7:08 pm
Lets see the pics when you get the job done and join the HTS, please ask my Gunn to as well. Thx
Mike
Re: Spaceframe Imps
Post by benwick3 » Mon Sep 06, 2010 9:31 pm
Why not join the Imp Club while you're at it?
leeboy44
Re: Spaceframe Imps
Post by leeboy44 » Tue Sep 07, 2010 7:01 am
how do i join? i tryed to have a go i wile back but didnt know how
Re: Spaceframe Imps
Post by ChrisBenoy » Tue Sep 07, 2010 10:01 am
ubergam3r
Car Model: Hillman Californian
Re: Spaceframe Imps
Post by ubergam3r » Fri Sep 10, 2010 6:07 pm
colin rooney wrote:Rawlson panels now ready rear wings £300 a pair and complete front £400 contact Marcus on 07780967692 or me on 07515533742 or PM me via club site
What size of wheel (Front/Rear) can you run with something like these ^^?
Re: Spaceframe Imps
Post by colin rooney » Fri Sep 10, 2010 6:58 pm
col[/quote]
I run 13 inch wheels but you could probably get away with 15 inch
cheers col
doc knutsen
Re: Spaceframe Imps
Post by doc knutsen » Sun Sep 12, 2010 6:30 pm
When we ran with Rawlson panels like these, they would accommodate 8"x13" fronts with 10"x13" rears just about, though most folks ran 7" and 9" wide rims. Contemporary F3 tyres worked a treat on these rims. The cars were v quick until the Maguire space-frame jobs came out, and they were lighter, and significantly, a whole lot stiffer.
Re: Spaceframe Imps
Post by ImpManiac » Sun Sep 12, 2010 6:53 pm
So what are the differences between the Rawlsons of this world and the Maguires? Are the latter full spaceframes, constructed from scratch, whilst the former are built from Imp shells?
Megapin
Car Model: Suzuki SC100 , Modsports Lotus Elan, Jarvis Stilet
Re: Spaceframe Imps
Post by Megapin » Fri Oct 01, 2010 9:52 am
Just to try and spark a bit more interest in this thread. Below are a couple of pics of my spaceframed Suzuki SC100 in which I have been competing in the Northern Saloon and Sports car Championship this year. Although the car is totally outpowered in the up to 2.5litre class I have always finished in the top 8 and have broken the old 1400cc NSSCC class record at Croft no less than 4 times so far this year. Taking the record down from 1:35.4 down to 1.32.1. I know it's not an imp or imp based car but it is an out and out modsports car and just shows what can be achieved with a lightweight spaceframed car against much bigger and more powerful machinery. The car finished 4th overall last saturday out of 36 cars ahead of 450bhp Porsches, Seat touring cars and a host of westfield and other more powerful cars.
There are very few championships that allow in Modsports cars these days, but it just shows that they can still be competitive and excellent fun to drive.
My spaceframed Stiletto is patiently awaiting some dark long winter nights to complete the body fitting and will hopefully be out next year in NSSCC.
Modsports Suzuki SC100,
Modsports Spaceframed Stiletto
Re: Spaceframe Imps
Post by bazzateer » Fri Oct 01, 2010 10:23 am
I've always liked the SC100, not unlike an Imp in many ways.
speeddemon
Car Model: None
Re: Spaceframe Imps
Post by speeddemon » Fri Oct 01, 2010 12:34 pm
Hey well done to you, im competing in that championship next year as well as pushing the HTS. Shame you havnt got anything 1.0 ltre powered.
How about you turfing that owd busa out of the new imp and puttin in an imp motor then you can come race with us.
good luck
mike :D
Megapin
Re: Spaceframe Imps
Post by Megapin » Fri Oct 01, 2010 12:41 pm
Can't afford to buy an imp motor that will give me a reliable 226bhp !!!
HARRY
Car Model: davrian mk 8 / hillman imp
Re: Spaceframe Imps
Post by HARRY » Fri Oct 01, 2010 5:52 pm
well done dave ,the car looks great .
kayjay
Car Model: RACE IMP
Re: Spaceframe Imps
Post by kayjay » Fri Oct 01, 2010 9:12 pm
In reply to Clive Browns notes about Rawlson spaceframe imps, after Fred Hendy crashed the spaceframed sister version to
John Homewoods Davrian based car, Trevor Willcocks and myself Keith Josh purchased the car from Fred ,complete with new front end repair panels, the car being rebuilt and painted yellow almost the same as Homewoods car.
This was used for a season or so with an 850 cc ultra short stroke Clive Brown engine and a Bevan 850 cc.
The rolling chassis was then sold to Pete Halls who put i think a larger 1220 engine in it ,last time i saw it race he had an accident on the bottom straight at Brands .
Re: Spaceframe Imps
Post by colin rooney » Sun Oct 03, 2010 12:03 pm
kayjay wrote:In reply to Clive Browns notes about Rawlson spaceframe imps, after Fred Hendy crashed the spaceframed sister version to
So do you still have contact with pete hall or do you know what happened to the car after the accident
speeddemon
Car Model: None
Re: Spaceframe Imps
Post by speeddemon » Sun Oct 03, 2010 7:36 pm
Hey col, i just dopped the body over my chassis, cars loks the bollocksksksks , i will put pics on tomoz through john.
Clive Brown
Car Model: Mini, tricycle or shanks pony
Re: Spaceframe Imps
Post by Clive Brown » Tue Oct 12, 2010 8:35 pm
kayjay, I remember you well. How are you doing?
Fred Hendy used either one of two 850cc motors, one of which was a bitsa of the standard 68.0 x 58.0 format, and the other was a semi-short stroke motor with a 69.5 bore using stock one litre valve sizes. This engine, which I loaned to Fred, went like the manure of a trowel.
I did build an ultra-short stroke motor with a stock one litre bore, 51.2mm stroke, and huge valves for Fred to use, but sadly, the accident at Silverstone that ended his UK racing career occurred before it was finished. It did later race, but as a one litre, giving away 150 cc!
speeddemon
Car Model: None
Re: Spaceframe Imps
Post by speeddemon » Wed Nov 24, 2010 6:10 pm
Just a few lines, my build is almost there and were are just waiting on dynoing the motor with Shrigley Engineering. All the alloy work is now done and the body looks great on the chassis. Set of tyres and im almost there.
Will post some pics this weekend if possible.
Mike
speeddemon
Car Model: None
Re: Spaceframe Imps
Post by speeddemon » Mon Nov 29, 2010 6:23 pm
Just been contacted by a new/old enthusiast of the Imp. It seems a a chap from down south who runs a motorsport business has purchased the only believed solo davrian stilleto. The car was in the Uk for quite a few years then went to Ireland. Pics are on here and its a well known car.
It was for sale on the forum some time back , however its on its way back to the uk for full inspection and rebuild.
The new owner has informed me that he will be racing in the cnc heads series which is hopefully being campiagned by quite a few of the imp members as well as HTS members.
Its starting to look good for this series and i hope to see about 5-10 cars competing :D :D
Its all good news.
Mike
spares
Car Model: Califormian, Mirage, K9
Re: Spaceframe Imps
Post by spares » Sat Dec 04, 2010 3:11 pm
The yellow Rawlson Stiletton with red wheels above was mine for a while. Believe raced by Nick Creswell, e.g. at Loton Park, but don't know any more. Ian Toon said he'd seen it racing and it was quite quick. As I didn't use it, I sold it. Soon after some idiot broke it and sold all the parts on e-Bay. Don't let this happen to any more! Fortunately I kept the Hartwell engine and box.
Its not actually a spaceframe, but a very pared-down Imp with glass fibre Rawlson panels and complete nose section. Was good to drive!
Sincerely, Bob (Imp Club Spares)
Contact me for any Imp and related spares requirements or technical advice.
E-mail: spares@theimpclub.co.uk
Mike Hanna
Car Model: 2 ZIMPS, 2 SINGER CHAMOIS, 6 HILLMAN IMPS
Re: Spaceframe Imps
Post by Mike Hanna » Sat Dec 04, 2010 5:35 pm
Hi. The yellow imp in the previous post is I understand the one referred to as the "Custard Bullet". I bought the doors from it on Ebay, and collected them from a guy in Gloucester ; The body tub (floor/bulkhead) was sat on his drive. It was rusted well beyond repair. The doors had more paint than fibreglass! If I remember correctly he had a partially built space frame on his rear patio. Cheers Mike
Swimpster
Car Model: Hillman Imp Super / Clan Crusader
Re: Spaceframe Imps
Post by Swimpster » Sun Dec 05, 2010 11:04 pm
Hi Bob
I remember that car very well. I knew Nick Cresswell and I bought a Wendy Walls Imp off him. I'm afraid I did nothing with it and sold it a couple of years later. Somewhere in my attic I have a couple of photos of it in Nick's garage in Oakamoor, Staffs, taken in about 1992. I'll have to dig them out and post them.
Tim Swift
Swimpster
Re: Spaceframe Imps
Post by Swimpster » Sun Dec 05, 2010 11:08 pm
Of course, what I meant to say was Wendy WOOLS, but my Stoke accent got the better of me!!!!!!
